April 11, 2026, 12:04:18 12:04
Author Topic: Crack for mikroPascal dsPIC v2.0.1.0  (Read 18015 times)
meax98
-Given: 1376
-Receive: 52
« on: December 03, 2005, 11:26:23 23:26 »
quick and working solution
parallaxis
« Reply #1 on: December 04, 2005, 12:31:14 00:31 »
Yes! It works!!!
Thanks a lot, meax!
bayramonur
« Reply #2 on: December 05, 2005, 09:09:46 21:09 »
Thanks.This is the best forum.
« Reply #3 on: December 05, 2005, 09:40:38 21:40 »
Hello
Just to make sure the crack is working, Have you tested that on hardware yet.
parallaxis
« Reply #4 on: December 05, 2005, 10:39:23 22:39 »
Quote from: metal
Hello
Yes, just now, for the second time. It's working, as I wrote... My (simply) code has about 7.5kB, I'm testing on 30F2010 and everything seems to work fine...
Have you another experience? Please write and don't scare me... Smiley
« Reply #5 on: December 05, 2005, 11:06:32 23:06 »
Hello parallaxis
I had no other terrifying experience yet, but I downloaded this mikroPascal dsPIC  Version: 2.0.0.1, and crack didn't work for me, I tried to download that version: 2.0.1.0, but couldn't find it   :confused:
You may be able to provide some link to download the crackable version Smiley
Thanks in advance
parallaxis
« Reply #6 on: December 05, 2005, 11:40:13 23:40 »
Quote from: metal
Hello parallaxis
Thanks in advance
I've exactly the same experience... My installed compiler doesn't work, but crack says "done"...
My following steps was:
1. Uninstall the older version. Completely remove.
2. Download fresh setup from  http://www.mikroe.com/zip/mikropascal_dspic/mikropascal_dspic_201_setup.zip
3. Install
4. Use the crack exactly as wrote
5. Test.
And everything is OK...
Hope it helps
« Reply #7 on: December 06, 2005, 12:00:34 00:00 »
Hello parallaxis
Thanks alot for explaination, I say to people read the text file first when uploading some thing, then my self forget to do that  :p
« Last Edit: December 06, 2005, 12:02:43 00:02 by metal » Logged
meax98
-Given: 1376
-Receive: 52
« Reply #8 on: December 06, 2005, 07:27:32 07:27 »
No problem, metal!
I wouldn't post something what is not double checked.
olotill
« Reply #9 on: December 06, 2005, 03:07:37 15:07 »
Hello
so thanks guys..
You are the best, again thanks a lot for helping..
Best Regards from Ecuador
khai
« Reply #10 on: December 12, 2005, 06:22:11 06:22 »
Quote from: parallaxis
3. Install
5. Test.
Hope it helps
can't download dspic_201_setup.zip, please upload or other link for download.
thank
meax98
-Given: 1376
-Receive: 52
« Reply #11 on: December 13, 2005, 08:50:44 08:50 »
The reason is new version mikroPascal for dsPIC v2.2.0.0. I'll see is the crack still working. If not I'll upload later previous version somewhere.
