r.vittalkiran
« on: April 18, 2012, 05:41:42 05:41 » |
Hi, I want to build a Energy Meter(KWH Meter) for 220V input. Please help me in getting started.
sfiga69
-Given: 193
-Receive: 159
In the order is preserved, in the mess is created.
« Reply #1 on: April 18, 2012, 08:45:29 08:45 » |
You can start from here: AVR465: Energy Meter using tinyAVR and megaAVR devices http://www.atmel.com/Images/doc2566.pdfBye
r.vittalkiran
« Reply #2 on: April 18, 2012, 10:35:07 10:35 » |
hey, thanks .. but can i have the pcb designs. Any links more? I'm a kind of new person to this, so can i use Atmega 16.
kayvee
-Given: 98
-Receive: 101
« Reply #3 on: April 18, 2012, 10:40:14 10:40 » |
..or, if you have a foot in the Microchip camp you can try the MCP3905A. http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en028189. I would certainly recommend a dedicated front end chip such as these, a lot easier to get going with.
r.vittalkiran
« Reply #4 on: April 18, 2012, 11:57:07 11:57 » |
Similar to what i was looking for. Can i have it's diagram and PCB Layout? I had seen somewhere in this board, where there was complete PCB Layout and microcontroller code. The system had an LCD Display.
Pasca
-Given: 27
-Receive: 42
« Reply #5 on: April 19, 2012, 10:10:00 10:10 » |
I have completed project of Energy Meter a few year ago, with atmega324, LCD 4x20, 2 ads7813 and very sophisticated software + bootloader. It measure Veff, Ieff, A, P, Q, PF, frequency, Vthd%, Ithd% and energy. Energy is accounted for by time slots (italian F1 F2 F3) and stored day by day. The maximum measurable power is 4.5kW and has configurable acustic alarm that emits an audible beep every 1 wh or costant beep when power level exceeds 4kW. The accuracy achieved by this instrument is very high about 0.5% for P> 4W. I don't have the layout of the PCB, I have made on "millefori" (I dont know english name may be breadbord?). The schematic needs a few tweaks, couples phototransistor infrared LEDs should be replaced with commercial optocouplers. Bye Pasca
More I know, more I need to know. Less I know, meglio sto!!!
r.vittalkiran
« Reply #6 on: April 19, 2012, 02:50:09 14:50 » |
I want to use an LED display instead of LCD.
Pasca
-Given: 27
-Receive: 42
« Reply #7 on: April 19, 2012, 04:43:08 16:43 » |
Hi vittalkiran, This project is a good start point, if you prefer remove LCD and connect driver for LED display. I think that LCD can visualize more information, and more other i'd like to show. I am thinking to start new energy meter project with 18 bits ADC, ARM Cortex M3 and graphic LCD for visualize daily load chats. I have to clean-up the code, if someone is interested i can share it in a few days, take in account that code is compiled with IAR EWAVR and bootloader is compiled with WinAVR. Some photos of the prototype. Bye Pasca
« Last Edit: April 19, 2012, 05:14:50 17:14 by Pasca »
alexisnik
-Given: 25
« Reply #8 on: April 19, 2012, 05:38:30 17:38 » |
Hello,
I would be interested in developing a wireless based energy meter, could you share the code for the project so I can have it as reference?
Thanks!
Pasca
-Given: 27
-Receive: 42
« Reply #9 on: April 19, 2012, 05:54:52 17:54 » |
OK!!! alexisnik but you have to remember that I share it only for non commercial purpose and remember that you have to share your project, too. Give me a few days. Bye Pasca
alexisnik
-Given: 25
« Reply #10 on: April 19, 2012, 07:50:53 19:50 » |
Yes of course, but remember I don't intend to start this project in the following months, I will let you know once I get started...
Did you try to connect them to a central metering system, so that you can monitor the total power consumption?
Pasca
-Given: 27
-Receive: 42
« Reply #11 on: April 19, 2012, 09:41:01 21:41 » |
Currently, with the energy meter, control energy consumption of my whole house, including its own consumption (about 3W). The serial port allows you: 1 to read all the measurements 2 to download the records of daily consumption 3 to make the calibration 4 to change some settings eg. display light always on, set value of energy counter, data and time, etc. 5 to update the firmware It would be possible to connect the meter to a central energy measurement, but it was not necessary for me. If you want to control energy consumption in a large building, you need more energy meter, then it makes sense to connect them to a central measurement. I would suggest, however, the connection through power line or bus RS485 or Ethernet. Bye Pasca
alexisnik
-Given: 25
« Reply #12 on: April 20, 2012, 12:28:16 00:28 » |
You said that the maximum power consumption which can be measured is 4.5KW, which is lower than the power consumption of a medium house at peak times (unless all your power hungry appliances use alternative forms of energy). I was thinking of low-cost, low-power wireless modules which can measure energy in different parts of the house and then upload them online through a gateway (Zigbee home automation - WiFi gateway for example). And maybe at the same time you can control the measured appliance, for example the lights or the air-conditioning. As I said, at this point these are just thoughts, so feel free to comment! PS: Nice job with all the extra software features, like firmware update!
r.vittalkiran
« Reply #13 on: April 20, 2012, 04:08:48 04:08 » |
http://www.ebay.com/itm/Plug-USA-Energy-meter-Watt-Voltage-Volt-Meter-Monitor-Analyzer-power-meter-/190668078144?pt=LH_DefaultDomain_0&hash=item2c64b3fc40For those who have a confusion, i wanted to build a Energy Meter like one here. The price seems pretty competitive, so i think it'll be economical to buy rather than to build. But, i want to learn by doing the project. Can anyone start posting the Code, Diagram, PCB layouts here, so that we can decide which is better. I know there are many out there, but i'm ain't able to find any energy meter project anywhere. Any place where i can find it? A Simple, Basic Energy meter would help me to start.
darksky
-Given: 183
« Reply #15 on: April 20, 2012, 08:31:45 08:31 » |
I have a number (66) of Analog Devices single phase meter chips. Think they are ADE7762 if anyone is interested.
Prepared to donate a few free if requester pays postage.
Send me an email.
r.vittalkiran
« Reply #16 on: April 20, 2012, 04:12:36 16:12 » |
enzine, will have a look at it. I guess it's available on many blogs on internet. BTW, is this the Old version wherein a special chip(MCP3905A) isn't used? I need both the projects, so that i can compare with the two and understand them. BTW, which do you suggest me to do?
tanveerriaz
-Given: 42
-Receive: 298
« Reply #17 on: April 20, 2012, 05:54:20 17:54 » |
Pasca
-Given: 27
-Receive: 42
« Reply #18 on: April 20, 2012, 10:36:25 22:36 » |
hi all, As promised here there is the source of energy meter, make it good use, I worked hard for more than four months to get to this point.
@alexisnik Your ideas are very interesting, if you want I'd like to collaborate with you about The Energy Management System for Smart Home, innovative method for rationalize energy consumption in the home.
Bye Pasca
enzine
-Given: 649
-Receive: 57
« Reply #19 on: April 20, 2012, 10:41:41 22:41 » |
@r.vittalkiran: Both the projects (Silicon Chip and EPE) are the same. The schematic of this project has already been published on sonsivri: http://www.sonsivri.to/forum/index.php?topic=1929.0The main components are PIC16F628 and ADE7756AN Ciao
r.vittalkiran
« Reply #20 on: April 21, 2012, 03:12:39 03:12 » |
enzine, thanks. That was what i was looking for. I had gone through that thread sometime ago. This Energy Meter can only be used to measure resistive loads, and can't be used to measure power of inductive loads. So, i'm now thinking whether it's worth of doing it. Quote from the other topicSo here it is, everything that's required to get started!
enzine
-Given: 649
-Receive: 57
« Reply #21 on: April 21, 2012, 05:29:20 17:29 » |
@r.vittalkiran: This Energy Meter can only be used to measure resistive loads, and can't be used to measure power of inductive loads.I think this is incorrect: I will reprint a statement the article by EPE: "The result is an accurate power measurement which takes into account the phase angle and the shapes of the voltage and current waveforms." Ciao
r.vittalkiran
« Reply #22 on: April 21, 2012, 05:40:02 17:40 » |
Oh okay, Can you spray some information on it's working? How/Where can i make the suitable box for it? I'm not doing this for commercial purpose, but the Energy meter works along hazardous voltages. So, i thing i need a box too. One Box of that type will be to costly. It'll be better to buy the energy meter for 7$ on Ebay. What will you say?
enzine
-Given: 649
-Receive: 57
« Reply #23 on: April 22, 2012, 08:39:30 20:39 » |
@r.vittalkiran: I am attaching the two parts of the article published by EPE. It also contains detailed information on the theory of operation of the circuit, constructive description and mechanical assembly. I suggest you also read the datasheet of the ADE7756AN (Analog Devices). I recommend you, be very careful with the voltages in the circuit. I do not know the product sold on ebay, but since the price may be cheaper to buy it. Ciao
« Reply #24 on: April 23, 2012, 05:42:40 17:42 » |
Microchip has some good application notes and reference design for 1 phase and 3 phase energy meter.
r.vittalkiran
« Reply #25 on: April 24, 2012, 04:07:20 04:07 » |
Thanks enzine, i downloaded the pcb layouts from the above links. The one in the PDF file seems to be bit hard to understand. I'm not able to understand that, do you think an expert can understand where to place components. Since i don't have any machine, i'll probably goto a dealer/workshop where they can convert the pcb layout into PCB. I suppose, the computer/machine does all the job. Link: http://www.siliconchip.com.au/cms/attachments/show.html?year=2004File:Energy Meter - Both Pcbs (04107041 & 2) (PDF)
« Last Edit: April 24, 2012, 10:27:25 10:27 by pickit2 »
alexisnik
-Given: 25
« Reply #26 on: April 24, 2012, 04:47:28 04:47 » |
Thank you, I have thought about many features for this system! Right now I am swamped with other projects (which I get paid for ), so as soon as I am free I plan to start development on this. Who knows, something good might come out of it! Cheers, Alex
Pasca
-Given: 27
-Receive: 42
« Reply #27 on: April 24, 2012, 07:18:29 07:18 » |
OK!!! I am here if you need. Good job.
Bye Pasca
enzine
-Given: 649
-Receive: 57
« Reply #28 on: April 24, 2012, 08:15:20 20:15 » |
an expert can understand where to place components. Have a look at pag 53 - fig. 8 and pag.55 - fig.10 of EPE project in order to understand how to install parts on PCBs. Good luck! Ciao
r.vittalkiran
« Reply #29 on: April 25, 2012, 04:53:13 04:53 » |
Good luck!
Ciao
Oh thanks! should i have to place the components manually, or is there anyway i can do it with some machine? I'm new to this, so can i make it done somewhere for some dollars?
-Given: 826
-Receive: 4207
« Reply #30 on: April 25, 2012, 12:26:10 12:26 » |
your link for energy meter on e-bay sold for $4.75 to $20, many sold. you wanted to learn how to do it your self, but did not respond to advice given in posts ie: read app-notes from Atmel and Microchip. now you want to farm out your project, pcb to be made by someone else, pcb to be stuffed by someone else, with auto placement machine (my place of enployment charge £1000 to set up such work) how about testing to see if the product meets regulations, even for your own safety, do you by any chance stick your finger in to mains socket to test for power? my advice is take up knitting, alot more rewarding than the posts I have read in this topic.
Thiru09
-Given: 385
-Receive: 1164
« Reply #31 on: April 25, 2012, 06:43:43 18:43 » |
Dear Mr. Kiran, First, study the design posted by Pasca and provided application notes. Leave the whole project construction for a while. Construct small part of it, say, inputs section, do some experiments, and understand the application thoroughly. Ask doubts, if any, regarding the design. Though you can manage the electronics part, it may be difficult to obtain the mechanical enclosure (poly-carbonate or metal), terminals etc. Better buy the ready made product, if you have any urgency. do you by any chance stick your finger in to mains socket to test for power?
Regards, Thiru
enzine
-Given: 649
-Receive: 57
« Reply #32 on: April 25, 2012, 09:10:18 21:10 » |
@ r.vittalkiran I hope not to offend your sensibilities, but honestly, given the questions you ask, you probably do not have all the skills to carry out this project. In this case, buy this instrument and begins to realize simple projects and especially projects that operate with low voltages (less than 30V). I repeat, having your health care, in this project are lethal voltages present !!!. Be careful! Ciao
alexisnik
-Given: 25
« Reply #33 on: May 03, 2012, 10:58:22 22:58 » |
I agree.
I would say that I am quite experienced with electronics, but with high voltages you really have to know what you are doing! You can cause great damage if you are not careful, and more importantly, you could get seriously injured. This is the main reason I want to start this project when I have the time, and not be in a hurry.
My personal advice is to first study very carefully before you try anything!
Pasca
-Given: 27
-Receive: 42
« Reply #34 on: May 04, 2012, 12:08:20 00:08 » |
I do not hide the fact that in developing this project once I got the electric shock and another time I accidentally damaged a display that has touched the container connected to earth. yet I have 30 years of experience. The caution with this type of project is never enough. Bye Pasca
nordiceng
« Reply #35 on: April 17, 2013, 03:15:27 15:15 » |
I suggest to visit analog devices website and there you will find a lot of new energy meters (SAMRT METERS)
jumulab
-Given: 91
-Receive: 74
« Reply #36 on: April 18, 2013, 03:25:10 15:25 » |
Hi all, the device that you have seen in ebay is a commonly named sub-metering, an energy meter to make measures in a home environment, not for tariff and billing purposes or to be used by an supplier. You have some good examples in NXP and other not mentioned in Texas Instrumenst with their MSP430 family. Look at : http://www.ti.com/lsds/ti/microcontroller/16-bit_msp430/end_equipment/smart_metering.page?DCMP=MSP430Metering&HQS=Other+EM+430meteringAnd for NXP sub-metering with ARM devices : see NXP EM783. Today all the manufacturers have application notes and devices for this purposes. It is very easy to make the digital signal processing with an microcontroller with an AD converter. whit only 8 bits and a little OP. AMPs and good current trafos you can build an energy meter better than 1% class.
nordiceng
« Reply #40 on: May 21, 2013, 07:44:28 19:44 » |
please who have information about smart energy meter
