May 23, 2025, 11:28:20 11:28
Top
Fix for MPLAB® XC Compilers
http://www.microchip.com/pagehandler/en_us/promo/mplabxc/
Windows, Linux & Mac OS X
13-Aug-2012; Updated for v1.10 compilers.
14-Aug-2012; MPLAB XC32 C++ license activated.
01-Jan-2013; License info update.
12-Jun-2014; Updated for v1.32 compilers.
19-Jun-2014; Fixed issue with XC32 compilers.
« Last Edit: June 20, 2014, 11:00:49 23:00 by Top »
Pages: 1 2 [3] 4 5 6 7 8 9 10 ... 13
Author Topic: XC Compilers - Software ONLY  (Read 365671 times)
Diramo
-Given: 459
-Receive: 54
« Reply #50 on: January 22, 2014, 08:54:34 08:54 »
XC8 compiler works in "free mode". xclm.exe was replaced with the Top's medicine.
I changed back to the 1.21 - no any problems.
May be I did something wrong?
Interprog
-Given: 21
-Receive: 8
« Reply #51 on: January 22, 2014, 05:12:15 17:12 »
XC8 1.30 works
delete the XC8 1.21 folder,  install 1.30 and replace xclm
Catcatcat
-Given: 290
-Receive: 1753
« Reply #52 on: January 23, 2014, 07:50:21 19:50 »
I installed version 1.20, 1.21, 1.30, and at the same time all work. Smiley
ehnonymouse
-Given: 15
« Reply #53 on: January 24, 2014, 02:55:58 14:55 »
Now I'm thinking my issue is a compiler bug.
malinbay
« Reply #54 on: May 15, 2014, 11:09:52 23:09 »
C++ is include in XC32 from version 1.11. You can download a free license from Microchip. I never tested XC32++, I will try it with fake xclm.
EDIT
New version, now is supported also PRO for C++, just replace xclm in xc32/bin/ directory and works C and C++.
re-upload please..
green_paint
-Given: 12
« Reply #55 on: May 20, 2014, 11:27:25 23:27 »
I installed the medicine on a XC8 v1.30 compiled program.  The program memory used was reduced significantly, (from 75% to %22.5 in standard mode and to %16.5 in pro mode).
A problem arises when a function where strings are handled, stops working when its compiled in pro mode. In standard and free mode the algorithm works just fine.
Does anyone had this kind of a problem?
« Reply #56 on: May 21, 2014, 03:45:55 03:45 »
If the strings are in the program memory then i think it is packed as 7 bit characters. Me will try to find on the manual if there is a way to disable this feature.
Catcatcat
-Given: 290
-Receive: 1753
« Reply #57 on: May 21, 2014, 04:30:19 04:30 »
I think this is not a problem medicine is a problem of the compiler, "at the current stage of development"  Cheesy
« Last Edit: May 21, 2014, 04:48:33 04:48 by Catcatcat » Logged
h0nk
-Given: 250
-Receive: 234
« Reply #58 on: May 21, 2014, 07:55:38 07:55 »
Hello green-paint,
For midrange devices XC8 doesnt use the DA directive to pack 7-bit ASCII's into a 14 bit word,
because there is no generic way to access flash memory on a range of PIC devices.
If a variable is declared const, XC8 generates code to access the variable via RETLW instructions.
Otherwise XC8 reserves a chunk of memory (aka registers) and copies the string into this chunk.
This might inappropriate for large static text :-).
It would be helpful to separate Your source into relevant pieces and take a look
at the generated code and to separate out the part at which the compiler fails.
Best Regards
« Reply #59 on: May 21, 2014, 08:15:40 08:15 »
this is why we were hoping that microchip bought cc5x instead of hitech Cheesy
-Receive: 992
« Reply #60 on: May 21, 2014, 11:47:55 11:47 »
How do you decleare and access your strings. Can post some code showing your problem
Interprog
-Given: 21
-Receive: 8
« Reply #61 on: June 24, 2014, 08:13:50 20:13 »
XC8 1.31 works but  1.32  don´t works  Huh
Microchip MPLAB XC8 C Compiler (Free Mode) V1.31
License type: Node Configuration
Program Used: 1768 (0x6E8) Free: 31000 (0x7918)
--mode=pro
Microchip MPLAB XC8 C Compiler (PRO Mode) V1.31
Program Used: 1390 (0x56E) Free: 31378 (0x7A92)
Microchip MPLAB XC8 C Compiler (Free Mode) V1.32
Program Used: 1676 (0x68C) Free: 31092 (0x7974)
--mode=pro
Wannabe
-Given: 228
-Receive: 285
« Reply #62 on: June 24, 2014, 10:53:59 22:53 »
Are you using latest fix?
http://www.sonsivri.to/forum/index.php?topic=44014.0
Interprog
-Given: 21
-Receive: 8
« Reply #63 on: June 25, 2014, 08:50:53 20:50 »
Yes, i use the last fix.
date: 19.06.2014
Windows
MD5: 10ced13a23a1129ecf040c32556d4b99
« Last Edit: June 25, 2014, 08:55:58 20:55 by Interprog » Logged
« Reply #64 on: June 25, 2014, 09:17:31 21:17 »
upload ur code, can't reproduce ur results:
Memory Summary, free mode:
    Program space        used  1D8Ah (  7562) of  8000h bytes   ( 23.1%)
    Data space           used   135h (   309) of   800h bytes   ( 15.1%)
    Configuration bits   used     7h (     7) of     7h words   (100.0%)
    EEPROM space         used     0h (     0) of   100h bytes   (  0.0%)
    ID Location space    used     8h (     8) of     8h bytes   (100.0%)
    Data stack space     used     0h (     0) of   36Eh bytes   (  0.0%)
Memory Summary, pro mode:
    Program space        used  1654h (  5716) of  8000h bytes   ( 17.4%)
    Data space           used   12Ch (   300) of   800h bytes   ( 14.6%)
    Data stack space     used     0h (     0) of   384h bytes   (  0.0%)
« Last Edit: June 25, 2014, 09:25:12 21:25 by metal » Logged
Interprog
-Given: 21
-Receive: 8
« Reply #65 on: June 25, 2014, 09:45:41 21:45 »
Sorry, I do not want to publish the program.
I have test this code and the same result , 1.32 only free mode
http://ww1.microchip.com/downloads/en/DeviceDoc/11_Indirection.zip
Program Used: 124 (0x7C) Free: 8068 (0x1F84)
    Program space        used    7Ah (   122) of  2000h words   (  1.5%)
    Data space           used    1Ah (    26) of   400h bytes   (  2.5%)
    Data stack space     used     0h (     0) of   316h bytes   (  0.0%)
    Configuration bits   used     2h (     2) of     2h words   (100.0%)
    ID Location space    used     0h (     0) of     4h bytes   (  0.0%)
Program Used: 86 (0x56) Free: 8106 (0x1FAA)
Memory Summary:
    Program space        used    54h (    84) of  2000h words   (  1.0%)
    Data space           used    12h (    18) of   400h bytes   (  1.8%)
    Data stack space     used     0h (     0) of   31Eh bytes   (  0.0%)
Program Used: 125 (0x7D) Free: 8067 (0x1F83)
Memory Summary:
    Program space        used    7Bh (   123) of  2000h words   (  1.5%)
--mode=pro
but run in freemode
Memory Summary:
« Last Edit: June 25, 2014, 09:50:26 21:50 by Interprog » Logged
« Reply #66 on: June 25, 2014, 10:01:35 22:01 »
Memory Summary:
--mode=pro
but run in freemode
Memory Summary:
All I see is your running the same code in pro mode (freemode) and getting the same result as the free version.
So what are you expecting?
Interprog
-Given: 21
-Receive: 8
« Reply #67 on: June 25, 2014, 10:11:35 22:11 »
I think the crack does not work with the 1.32 version, it always run in free mode and not pro mode.
Can you test the xc8 1.32 version in pro mode.
Top
-Given: 53
-Receive: 1719
« Reply #68 on: June 25, 2014, 10:17:23 22:17 »
Open a command prompt, change to your install folder (CD C:\Program Files (x86)\Microchip\xc8\v1.32\bin\), type xclm and hit enter.
Do you see any output?
Interprog
-Given: 21
-Receive: 8
« Reply #69 on: June 25, 2014, 10:52:57 22:52 »
Thanks , you are right.
It is solved, xc8 1.32 run in pro mode now.  Cheesy
The problem was it not found the xclm.old.
The environment variable path was false.
Microchip MPLAB XC8 C Compiler (PRO Mode) V1.32
Memory Summary:
    Program space        used    55h (    85) of  2000h words   (  1.0%)
mitsos
-Given: 3173
-Receive: 4810
« Reply #70 on: July 04, 2014, 08:50:41 20:50 »
hi
after trying the last patches from Top,
I find these:
the previous xclm.exe (19968 bytes-12/6/2014) is working well in xc8-1.32 and xc16-1.21
and the last xclm.exe ( 26624 bytes-20/6/2014) is working only in xc32-1.32
mitsos
unistall/reinstall the compilers and apply the patch using the last xclm.exe (26624 bytes)
« Last Edit: July 05, 2014, 08:01:54 20:01 by mitsos » Logged
Top
-Given: 53
-Receive: 1719
« Reply #71 on: July 04, 2014, 10:57:51 22:57 »
The 'last xclm.exe' should work with all compilers; be careful when swapping xclm.exe, you must always rename the old xclm.exe to xclm.old and then run xclm.exe once as admin to maintain the correct hash in the compilers. If you have any problems then open a command prompt, change to your install directory and run xclm.exe, if you have a v1.32 compiler then you should see 'OK'.
folkeu
-Given: 129
-Receive: 331
« Reply #72 on: July 05, 2014, 10:32:09 22:32 »
It's not possible tu download the last fix for me. I have an error on the page to http://uppit.com/.
This error is when i generate the link :
Software error:
Can't exec:
Column 'ip' cannot be null at Modules/DataBase.pm line 55.
For help, please send mail to this site's webmaster, giving this error message and the time and date of the error.
Have I only this problem ?
It"s is possible to report this fix on another downloader ?
Thiru09
-Given: 401
-Receive: 1188
« Reply #73 on: July 06, 2014, 06:19:11 06:19 »
Uploaded to Mirrorcreator
Regards,
Thiru
jannie
« Reply #74 on: August 14, 2014, 09:40:05 21:40 »
Ok for others that still only getting free mode when build project
not sure if it is mentioned in previos post's
remember to change your optimizations operation mode to PRO after medicine MPLAB X
