May 25, 2025, 11:21:59 23:21
Top
Fix for MPLAB® XC Compilers
http://www.microchip.com/pagehandler/en_us/promo/mplabxc/
Windows, Linux & Mac OS X
13-Aug-2012; Updated for v1.10 compilers.
14-Aug-2012; MPLAB XC32 C++ license activated.
01-Jan-2013; License info update.
12-Jun-2014; Updated for v1.32 compilers.
19-Jun-2014; Fixed issue with XC32 compilers.
« Last Edit: June 20, 2014, 11:00:49 23:00 by Top »
Pages: [1] 2 3 4 5 6 7 8 ... 13
Author Topic: XC Compilers - Software ONLY  (Read 365953 times)
Top
-Given: 53
-Receive: 1719
« on: March 29, 2012, 12:08:30 00:08 »
« Last Edit: June 20, 2014, 11:00:49 23:00 by Top » Logged
LithiumOverdosE
-Given: 392
-Receive: 610
« Reply #1 on: June 04, 2012, 04:14:50 16:14 »
XC8 is based on HiTech PICC + PICC18 with compatibility mode for C18.
XC16 is ex-C30.
XC32 is ex-C32.
Since MPLABX 1.20 all XCx tool chains are present.
However, now my Proteus tool chain disappeared but that's hardly a problem for the moment.
MichelM
-Given: 31
-Receive: 95
« Reply #2 on: June 16, 2012, 10:28:08 10:28 »
Hello
You will find user guide and instruction to add compiler plugin to mplab X here
http://ww1.microchip.com/downloads/en/DeviceDoc/52053A.pdf
http://ww1.microchip.com/downloads/en/Market_Communication/addXC8ToMplabX.pdf
Top
-Given: 53
-Receive: 1719
« Reply #3 on: August 01, 2012, 01:21:24 13:21 »
The link in dl.txt is not working any more.
Original post updated; new links in dl.txt.
LithiumOverdosE
-Given: 392
-Receive: 610
« Reply #4 on: August 11, 2012, 12:11:37 12:11 »
I just tried this fix with XC8 1.10 and the compiler stays in Free mode.
With XC8 1.00 and 1.01 everything is fine.
Top
-Given: 53
-Receive: 1719
« Reply #5 on: August 11, 2012, 12:50:39 12:50 »
Try replacing xclm.exe in C:\Program Files\Microchip\xc8\v1.10\bin folder.
LithiumOverdosE
-Given: 392
-Receive: 610
« Reply #6 on: August 11, 2012, 01:05:56 13:05 »
Ah, so that was the trick. In previous versions it was enough to replace it in C:\Program Files\Microchip\xclm directory.  Wink
marcodassi
-Given: 73
-Receive: 26
« Reply #7 on: August 12, 2012, 11:09:13 11:09 »
Just downloaded XC8, XC16 and XC32 1.10; tested with current fix; results:
- XC8 1.10 - fine, works in Pro mode with all optimizations;
- XC16 1.10 - fine, works in Pro mode with all optimizations;
- XC32 1.10 - DOESN'T WORK - the compiler stays in Free mode, no optimizations allowed
I've tried to copy xclm.exe in the "\Program Files\Microchip\xc32\v1.10\bin" folder too, with no luck.
Please fix it, if possibile Smiley
Thank you very much in advance! Smiley
cranor
-Given: 10
« Reply #8 on: September 13, 2012, 03:23:12 15:23 »
The version v1.41 of MPLAB® X IDE is available from here : http://www.microchip.com/mplabx-ide-windows-installer
It solves some of compilation and compiler detection issues with XC compilers but introduces new problems too..
SpaleKG
-Given: 19
« Reply #9 on: October 07, 2012, 11:44:27 23:44 »
Just to confirm that current fix works fine on Mac OSX on all XC compilers.
I have one question about MPLAB X IDE.
How to configure project when using bootloader in PIC. For example bootloader uses first 200 bytes of FLASH memory, so how to tell compiler to generate hex to start after that ?
jukinch
« Reply #10 on: October 07, 2012, 11:54:45 23:54 »
SpaleKG:
     you can use a project specific "linker script" to start after that memory location.
               Jukinch
odessa
-Given: 101
-Receive: 16
« Reply #11 on: October 08, 2012, 09:47:22 09:47 »
You can set a code offset from within MPlab X. If you right click your project - select properties - then click linker - Choose additional options from the drop down menu on the right you'll see a code offset option.
SpaleKG
-Given: 19
« Reply #12 on: October 13, 2012, 12:33:34 12:33 »
Does this move interrupt vector adresses too or I need to do that somehow?
« Reply #13 on: October 13, 2012, 05:36:53 17:36 »
I'm pretty sure you can't move the interrupt vector addresses.  Some of the PIC processors have alternate interrupt vector tables which follow directly in memory after the primary interrupt vectors but that doesn't help you much with typical bootloader related issues.
You can however point the interrupt vectors to a jump table that resides in your application memory space that can then be overwritten when you load a new firmware.  That way you can update interrupt function locations without overwriting the first segments of memory.
« Last Edit: October 13, 2012, 05:39:41 17:39 by Gallymimu » Logged
RedAlert
-Given: 170
-Receive: 302
« Reply #14 on: October 30, 2012, 08:11:07 20:11 »
Mplab XC8 v1.11
Download:
Windows: http://www.microchip.com/mplabxc8windows
Linux: http://www.microchip.com/mplabxc8linux
MAC: http://www.microchip.com/mplabxc8osx
« Last Edit: October 30, 2012, 08:30:26 20:30 by RedAlert » Logged
"Life would be easier if we had its source code"
marcodassi
-Given: 73
-Receive: 26
« Reply #15 on: October 31, 2012, 11:50:05 23:50 »
XC8 1.11 works with latest "medicine" too Smiley Smiley Smiley
j2mb
-Given: 6
« Reply #16 on: November 28, 2012, 03:48:26 03:48 »
I'm using MPLAB X IDE v1.51 and compiler XC8 v1.11 and is working well!  Cheesy Cheesy Cheesy
« Reply #17 on: November 28, 2012, 03:50:55 03:50 »
u'r kidding me!?
TucoRamirez
-Given: 257
-Receive: 115
Tuco ... dead or Alive
« Reply #18 on: November 28, 2012, 08:31:47 08:31 »
the thing that confuses me about mplabX is that even if my code is ok, mplab show me "!" signs ... (even with XC demos or the application libraries -that compile 100/100 ok ) ...  anyway, the config tool inside is quite nice Smiley
but, mplabx is crappy slow on my eeepc netbook (1G Ram ... )  ...but in a 4GB elitebook hp runs ok Smiley ...
LithiumOverdosE
-Given: 392
-Receive: 610
« Reply #19 on: November 28, 2012, 11:06:14 11:06 »
Well, same here on Win7 x64.
« Reply #20 on: November 28, 2012, 03:26:02 15:26 »
I have a lot of problems with this as well.  They don't have the parsing working quite right yet.  It's especially bad in XC8
gamegurus
-Receive: 64
Oh what a wonderful morning!!!
« Reply #21 on: December 03, 2012, 09:04:41 09:04 »
After install, How to check, if XC compiler is free or PRO versions?
I tried all ways 1) cmd 2) compile test and see output in MPLABX
but didnt find any such info.
Indian Gaming Guru
TucoRamirez
-Given: 257
-Receive: 115
« Reply #22 on: December 03, 2012, 01:07:32 13:07 »
check the project properties, in the part of compiler tou will see the options of optimisation
« Reply #23 on: December 03, 2012, 04:22:27 16:22 »
I don't think that tells you, all options always show in the properties.
You need to run the compiler and look at the output.  It should say it is running in free mode and omniscient code generation is disabled if it is in free mode.
ximo
« Reply #24 on: December 24, 2012, 09:37:32 09:37 »
XC8 v1.12 is working ok with this fix. Tested on Ubuntu 12.04.
