April 23, 2026, 03:29:08 15:29
Top
Fix for MPLAB® XC Compilers
http://www.microchip.com/pagehandler/en_us/promo/mplabxc/
Windows, Linux & Mac OS X
13-Aug-2012; Updated for v1.10 compilers.
14-Aug-2012; MPLAB XC32 C++ license activated.
01-Jan-2013; License info update.
12-Jun-2014; Updated for v1.32 compilers.
19-Jun-2014; Fixed issue with XC32 compilers.
« Last Edit: June 20, 2014, 11:00:49 23:00 by Top »
Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13
Author Topic: XC Compilers - Software ONLY  (Read 453050 times)
jcddcjjcd
« Reply #100 on: March 01, 2015, 11:18:44 23:18 »
Does the fix still work with XC8 v1.34 just released?
John.
Xwing
-Given: 624
-Receive: 1538
« Reply #101 on: March 02, 2015, 06:44:04 06:44 »
It works without problems.
idesign
« Reply #102 on: May 18, 2015, 10:00:15 10:00 »
I can't get it to work with
Win8.1
MplabX 3.00.02
XC32 v1.34
The output windows says "Corrupt executable file. Please reinstall the compiler."
Catcatcat
-Given: 319
-Receive: 1908
« Reply #103 on: May 18, 2015, 09:38:23 21:38 »
Already the Release MPLAB® X IDE v3.00. On W8.1 it works without problems.
Manuel
-Given: 793
-Receive: 206
« Reply #104 on: July 31, 2015, 09:41:42 09:41 »
XC8 compiler and part support patch too updated to V1.35....
...patch work!
XC16 to V.1.25 as well.
Manuel.
« Last Edit: July 31, 2015, 11:58:57 11:58 by Manuel » Logged
kaem1189
« Reply #105 on: September 09, 2015, 08:07:27 08:07 »
"medicine" worked with my xc32 v1.31 compiler..
i just followed the instructions in the README file..
be sure the replace the xclm.exe of xc compiler and not the xclm for mplabX ide
Ps. link is working as of today  Smiley
Thank you so much..
Rakky
« Reply #106 on: October 06, 2015, 08:07:50 20:07 »
Link isn't working anymore. For me anyway. getting a 404
Catcatcat
-Given: 319
-Receive: 1908
« Reply #107 on: October 07, 2015, 03:32:43 03:32 »
Link working, though antivirus NOD started to block this link
ehnonymouse
-Given: 15
« Reply #108 on: October 10, 2015, 09:23:21 09:23 »
I just tried it and had to use Adblock Plus to see the download link. Patch seems to work with MPLABX 3.10, XC8 1.35 on Windows 10 pro X64.
gamegurus
-Receive: 64
Oh what a wonderful morning!!!
« Reply #109 on: November 06, 2015, 06:47:16 06:47 »
How to crack XC compiler with pictures, How to check XC compiler license mode optimization and version and if its patched or not.
1) Open CMD as admin
2) CD to install path
3) Check mode without patch "xc8 --chip=16f1516 --mode=pro"
4) Copy patch and rename
5) PATCH
6) Check mode after patch "xc8 --chip=16f1516 --mode=pro"
« Last Edit: November 06, 2015, 06:50:02 06:50 by gamegurus » Logged
Indian Gaming Guru
PicKit3
« Reply #110 on: November 15, 2015, 02:44:06 02:44 »
some softwares that allows the user to connect to a virtual private network (VPN) could cause this effect like Hotspot Shield developed by AnchorFree, Inc. Just disconnect the application in that case and the link would work just fine.
hengfeb
-Given: 45
« Reply #111 on: November 20, 2015, 05:46:25 05:46 »
good tutorial about the crack xc8 compilier.
thanks.
Avataar120
« Reply #112 on: December 15, 2015, 03:50:53 15:50 »
...patch work!
Manuel.
Hello Manuel,
I cannot manage to use Medecine with XC16 version >1.22 ...
Can you confirm it's working with 1.25 ?
I get : elf-cc1.exe: warning: Attempt ....
Thanks for your help
Crackn
-Given: 133
-Receive: 565
« Reply #113 on: December 15, 2015, 04:42:29 16:42 »
yes I can confirm (for me at least Smiley ) that the medicine is working with latest versions from microchip website.
XC8 ver 1.35 OK
XC16 ver 1.25 OK
XC32 ver 1.40 OK
vovchik02
-Given: 43
« Reply #114 on: December 16, 2015, 05:29:12 05:29 »
All latest XC compiller good work with latest medicine. Tested on Linux (Ubuntu 14, Debian 8.2), Window 7.
Avataar120
« Reply #115 on: December 16, 2015, 01:00:01 13:00 »
Thanks for your answers.
Crackn has already confirmed to me that, in the same configuration than me (Win10 x64 + MPLABX 3.0 + XC16 1.25 + Medecine MXC1321 26kB) it is working on his machine.
So I don't understand ...
I replace the file in the bin folder of the compiler (not MPLAB) and it's working only with XC16 1.20 ...
Did you ever have the same issue ?
Sorry to bother you with my problems ...
Ava.
Top
-Given: 53
-Receive: 1719
« Reply #116 on: December 16, 2015, 01:57:51 13:57 »
If you have problems then open a command prompt  window, navigate to my xclm.exe and run it.
If everything is good it will reply OK, otherwise it should give you a clue.
Avataar120
« Reply #117 on: December 16, 2015, 02:16:58 14:16 »
Thanks for your answer.
I followed an old readme.txt ...
Forgot to rename xclm.exe to xclm.old and so on.
Great forum you have !
Ava.
gamegurus
-Receive: 64
« Reply #118 on: December 17, 2015, 12:59:13 00:59 »
Ava.
I posted entire process with pictures http://www.sonsivri.to/forum/index.php?topic=44014.msg175503#msg175503
Its Strange if people cannot follow that, How will they do programming on their own.
Indian Gaming Guru
jamen
-Given: 31
« Reply #119 on: December 24, 2015, 07:08:36 07:08 »
yes i path xc8 v1.35 test is ok. and code scale 20% ,it is wanderful
krayzeeman
« Reply #120 on: January 20, 2016, 12:57:36 12:57 »
Is there a doctor in da house that can help me apply the medicine to my XC8 v1.35 installation on my Mac?
I tried all the steps mentioned in this thread, but somehow can't get it to work.
This is what I did:
1) I downloaded the files from the top post
2) My XC8 is installed as a free license (not the time limited Pro trial)
3) opened up the terminal, and moved to the install directory of the XC 8 compiler, whis in my case is : /Applications/microchip/mplabx/v3.20/mplab_ide.app/Contents/Resources/mplab_ide/
4) tested the current state of the compiler with "xc8 --chip=16f1516 --mode=pro" and get the following (expected) result:
Microchip MPLAB XC8 C Compiler (Free Mode) V1.35
Build date: Jul  7 2015
Part Support Version: 1.35 (B)
Copyright (C) 2015 Microchip Technology Inc.
License type: Node Configuration
(939) no file arguments
(908) exit status = 1
5) I renamed the original xclm file to xclm.old
6) Copied the new xclm file from the download to my working directory
7) ran the new xclm using "sudo ./xclm", but got the (unexpected) result "Nothing to do"
8) when I recheck the status of the comiler again with "xc8 --chip=16f1516 --mode=pro", I still get the same result:
Am I doing something wrong?
PS. I'm running Mac OS X 10.11.2, with MPLAB X IDE v3.20, XC8 v1.35 with v1.35b part support.
Any help is greatly appreciated!
Krayzeeman
Top
-Given: 53
-Receive: 1719
« Reply #121 on: January 20, 2016, 02:13:07 14:13 »
Looks like the IDE's directory, try looking in "/Applications/microchip/xc8/v1.35/bin/xc8".
krayzeeman
« Reply #122 on: January 20, 2016, 02:36:13 14:36 »
[facepalm]You are right, I was using the wrong directory![/facepalm]
It should have been "/Applications/microchip/xc8/v1.35/bin"
After reverting the changes I made in the wrong directory, and applying the patch to the correct directory, it now shows the following after running ./xclm:
Patched 40 bytes in file ./cgpic
Patched 40 bytes in file ./cgpic18
Patched 40 bytes in file ./picc
Patched 40 bytes in file ./picc18
Patched SHA in 4 of 4 files
And verification of the patch with "xc8 --chip=16f1516 --mode=pro" returns:
Microchip MPLAB XC8 C Compiler (PRO Mode) V1.35
It now seems to work!
Thanks for your quick reply and solution!!!!
ferdok9
« Reply #123 on: February 16, 2016, 11:02:14 23:02 »
Patch work for xc8 v1.36
Catcatcat
-Given: 319
-Receive: 1908
« Reply #124 on: March 12, 2016, 06:35:05 06:35 »
MPLAB® XC16 Compiler v1.26
Medicine works! Smiley
