May 30, 2025, 12:06:28 12:06
Author Topic: Is there any literature regarding C18/C30  (Read 7637 times)
LithiumOverdosE
-Given: 392
-Receive: 610
« on: March 14, 2012, 05:50:03 17:50 »
I've done a number of projects in MikroC. Now I need to switch over to C18/C30.
Although there is a user guide for C18 covering mainly syntax and some basic examples, I wonder if there are any books, links, projects, whatever, available that contain practical examples. Syntax is not so much of a problem but it's surely much easier to catch on to the nuances of the different compilers if I can look at the description of the example projects.
Any suggestions?
Elmer
« Reply #1 on: March 14, 2012, 07:45:03 19:45 »
Microchip hosts loads of example projects. They keep redesigning their page so I'm not sure where they've put it right now, but look and you shall find Wink
EDIT: Try http://www.microchip.com/CodeExamplesByFunc.aspx
Some useful sheets;
dsPIC30F Language Tools Quick Reference Card
MPLAB C1X Quick Reference Card
MPASM/MPLINK PICmicro MCU Quick Chart
« Last Edit: March 14, 2012, 08:32:35 20:32 by Elmer » Logged
peace in the valley
SteveyG
« Reply #2 on: March 15, 2012, 11:53:48 11:53 »
If you look in your installation folder of C18/C30/C32, you should find and 'examples' folder with some examples/templates you can use.
You may also find the MPLAB® VDI Visual Device Initializer tool useful for getting started with a project, although this tool is no longer supported after MPLAB IDE v8.46.
jukinch
« Reply #3 on: April 10, 2012, 03:32:15 03:32 »
You can download the Microchip Aplication libraries with a lot of examples from here :
http://ww1.microchip.com/downloads/en/softwarelibrary/microchip-application-libraries-v2012-04-03-windows-installer.exe
I find this book:
 SD card projects using the PIC microcontroller - Dogan Ibrahim
I hope I helped
zorro123
-Given: 86
-Receive: 107
« Reply #4 on: April 29, 2012, 02:14:26 14:14 »
jukinch,
attached file for required book (tested).
« Reply #5 on: September 16, 2012, 04:09:36 16:09 »
"Programming 16-Bit PIC Microcontrollers in C, Second Edition: Learning to Fly the PIC 24"  Is a great book with many examples for c30 / xc16
odessa
-Given: 101
-Receive: 16
« Reply #6 on: September 17, 2012, 03:30:50 15:30 »
There are some useful tutorials on here
http://www.enmcu.com/guides    Mainly C18
http://www.bitguides.com/pic18-Guides   XC8
« Last Edit: September 17, 2012, 03:33:36 15:33 by odessa » Logged
