made spi with codevision but have error please help - Sonsivri
May 14, 2026, 12:11:27 00:11
Author Topic: made spi with codevision but have error please help  (Read 5923 times)
abdullahshawky
-Given: 8
-Receive: 19
« on: December 19, 2011, 03:07:39 15:07 »
hi guys
i made a project for spi between 2 controllers 1 master as reciever and 1 slave as transmitter
when i put the SPDR of both in a while(1) loop it works correctly but proteus gives a warning message about collision of data
when i put thr SPDR in the spi interrupt it stops the collision and sends the data shifted and 1 added to it
ex when i send 0 i get 1 when i send 1 i get 3 and so on
attached is 2 foleders with code and proteus simulation files please correct my error so that i can use spi in interrupt
thanks please help this time
BharatSujanani
-Given: 36
-Receive: 24
All is Well
« Reply #1 on: December 19, 2011, 06:05:03 18:05 »
I have faced the problem like you in which i also get data shifted.When i send 0XAA, i will get 0X55. If this is the problem then it is due to the SPI mode confliction between Master and slave. SPI has 4 modes to operate.
Check that 4 modes your problem would be solved.
Bharat Sujanani
abdullahshawky
-Given: 8
-Receive: 19
« Reply #2 on: December 21, 2011, 12:48:54 12:48 »
i thank u for even caring to respond
thats why i like sonsivri members
on other forums this exact post only got me mocked at as if all people where born educated and know all stuff
i will look into ur solution and if it work i will add the project  for newbies (like me)
abdullahshawky
-Given: 8
-Receive: 19
« Reply #3 on: December 22, 2011, 01:55:33 13:55 »
Dear friend,
i tried using spi mode 1 istead of mode 0 and the problem got solved thaks alot i will make a full project and upload it to sonsivri so that all get some tips
thanks again
