[Req] Arduino Duemilanove Atmega328 bootloader - Sonsivri
May 14, 2026, 12:10:35 00:10
Author Topic: [Req] Arduino Duemilanove Atmega328 bootloader  (Read 6150 times)
-Receive: 4459
« on: November 06, 2011, 10:22:46 22:22 »
Anyone have the Arduino Duemilanove Atmega328 16Mhz bootloader.hex
I'm having problems after original chip was damaged in a prototype board.
I tried all the bootloaders from the Arduino 0022 download, with the result I can't program sketches to the chip.
one bootloader on bootup flashes 6 times, then stops.
the other one flashes 3 times delay2 seconds, flashes 3 times and repeats.
The comms fault may be due to drivers not correctly installed.
« Last Edit: November 06, 2011, 10:28:37 22:28 by pickit2 » Logged
ppa88
-Given: 49
-Receive: 131
« Reply #1 on: November 07, 2011, 10:00:24 22:00 »
Try this one . Best of luck.
-Receive: 4459
« Reply #2 on: November 08, 2011, 07:27:08 07:27 »
Update: The hex files I was uploading to the chip, had erorors due to using a fualty pen drive.
When compared to the file you posted and a fresh download of Arduino confirms that was the problem.
I also found out the easiest was to program the boot loader is to use Arduino to auto select the file needed for the m328.
It solved a lot of problems with Arduino not finding the port to upload the sketches to the board.
