Fuji
-Given: 76
-Receive: 239
« on: July 02, 2007, 07:33:41 19:33 » |
Hitech PICC, PICC-18 &DSPIC tools http://lordn.hnc.ru/books/?get=Books/Electronica/mcu/%EF%E8%EA%F1%E8/Do not forget to read the file.txt, you can found the password inside, but in russian... between the quotation marks the password if you can see it. "НеДляЛиберастов"
mitsos
-Given: 3172
-Receive: 4810
« Reply #1 on: July 02, 2007, 09:13:31 21:13 » |
Hi is there a solution for the password to do unrar in the past I have the same problem any other links exist? (on the famous "sharers" rapidshare, megaupload,...)
regards mitsos
raham
« Reply #2 on: July 05, 2007, 06:59:25 06:59 » |
what is the password help
picbasic4
-Given: 24
-Receive: 30
« Reply #3 on: July 05, 2007, 08:07:00 08:07 » |
password:НеДляЛиберастов it ok.. thanks.
picbasic user
raham
« Reply #4 on: July 05, 2007, 12:37:15 12:37 » |
the password not working even when translated to english (translated eng pwd:NeDlyaLiberastov)
Fuji
-Given: 76
-Receive: 239
« Reply #5 on: July 05, 2007, 05:27:33 17:27 » |
No need to translate password in English, password works in russian only. Installs Russian langage onto your system...
Fuji
raham
« Reply #6 on: July 06, 2007, 11:08:14 11:08 » |
thanks fuji for nice support ,can you help me how to install russian in my system,i have english version of xp pro.thankyou.
raham
« Reply #7 on: July 06, 2007, 11:44:13 11:44 » |
thanks fuji i got it by installing fonts and by changing the reginol and language settings of my xp and also installed russian edition winrar.now got extracted.thanks to all members,And admin.
mitsos
-Given: 3172
-Receive: 4810
« Reply #8 on: July 06, 2007, 09:36:48 21:36 » |
Hi can you upload to rapidshare the three rars about picc18 pro 9.61 with an simple password?
regards mitsos
Zaphod Beeblebrox
-Given: 27
-Receive: 105
« Reply #9 on: July 10, 2007, 01:29:00 13:29 » |
Works fine with 7-Zip Manager, just copy & paste the password as it is. There is no need to fiddle about with WinRAR...
Black holes are where the God divided by zero... Don't panic!
khessamian
« Reply #10 on: July 10, 2007, 02:33:36 14:33 » |
thanks for file Fuji. extract file, for register run PICC9.60_REG.reg or *.reg but dont work in larg code.SerialNo (HCPIC-DEMO) and Licence (Evaluation only) how i can active or register software? thanks for help
50caliber
-Given: 174
-Receive: 863
« Reply #11 on: July 12, 2007, 09:47:13 21:47 » |
mitsos
-Given: 3172
-Receive: 4810
« Reply #12 on: July 13, 2007, 11:14:27 23:14 » |
thank you
mitsos
PICOL
« Reply #13 on: July 16, 2007, 02:17:13 02:17 » |
Gracias por compartirlo. PICOL
Kova
-Given: 172
-Receive: 24
« Reply #14 on: July 17, 2007, 06:40:14 06:40 » |
thanks for file Fuji. extract file, for register run PICC9.60_REG.reg or *.reg but dont work in larg code.SerialNo (HCPIC-DEMO) and Licence (Evaluation only) how i can active or register software? thanks for help  Quote! The .reg file works in evaluation mode!
50caliber
-Given: 174
-Receive: 863
« Reply #15 on: July 17, 2007, 07:03:09 19:03 » |
thanks for file Fuji. extract file, for register run PICC9.60_REG.reg or *.reg but dont work in larg code.SerialNo (HCPIC-DEMO) and Licence (Evaluation only) how i can active or register software? thanks for help  Quote! The .reg file works in evaluation mode!  These are all demo versions, from what I can tell. It appears a corresponding crack is needed for each one.
50caliber
-Given: 174
-Receive: 863
« Reply #16 on: August 31, 2007, 02:08:12 02:08 » |
An update - I finally got around to checking these and it appears they are pre-cracked. All show up as "not for commercial use" and will compile large code and not time out. Anybody else looked at them?
