May 18, 2025, 06:07:57 18:07
Pages: [1] 2 3  All
Author Topic: Proton+ Supports More PICs here !!  (Read 40024 times)
« on: November 28, 2005, 12:09:55 00:09 »
It did take me a long time to provide this one in deed, any way, hope you like it Smiley
Download From Rapidshare
P.S. Read the text file first...
Kabron
-Given: 67
-Receive: 145
« Reply #1 on: November 28, 2005, 10:05:26 10:05 »
Hi Metal, I've got "Missing security key" ERROR
« Reply #2 on: November 29, 2005, 05:22:05 05:22 »
kabron,
I don't know what you are trying to do here.....This is absolutely NOT what I made, it seems you are using another version of the compiler, may be posted by others, then you come here and say that you got a security error which has nothing to do with my version of Proton+, any way, this was a bad behaviour in deed, as you should have explained that this is NOT my version at the first place.....then say you got a different version of this damn compiler with which you got problems, and start asking for help after that...................
At the first glance, I started invetigating  :eek:  that problem  and why it appeared, it really took me a very long time to see what this problem was all about, but found nothing, till I discovered this was a different version you are using when I looked to your attachment, what is this, ha, why don't you just use the version I uploaded, or the version uploaded by other friends !!
This is the way my version looks like.................. :mad:
« Last Edit: November 29, 2005, 12:35:18 12:35 by rego » Logged
mredbautista
-Given: 31
« Reply #3 on: November 29, 2005, 08:42:05 08:42 »
Good Day,
I have to thank you Metal and the group behind the  scene and of course to sonsivri. Thanks men, I have tested the above progs and 100% working. I followed the instructions in the package. I have project which uses PIC18's project tested it is compiling and working. Includes command tested it is working unlike the one that have been posted by POSEC group. Actually I use XP sp2, in my Laptop, just for your info.
Once again men, thanks.....cheers!!!
More Power,
mred
If you don’t succeed you are consuming 100% of your ability, try to use 25%.  Cheesy
cubituz
« Reply #4 on: November 29, 2005, 12:16:17 12:16 »
metal 2.20 is not Proton dev. suite just ide upgraded but core is 2.20 not 3.0 then not compare....
bye
charlie
« Reply #5 on: November 29, 2005, 02:04:48 14:04 »
Its still the best we have got so far. I think we are now just one step before PDS
LazBoy
-Given: 78
-Receive: 25
« Reply #6 on: November 29, 2005, 10:11:30 22:11 »
Thank you Metal..For hard work on this project.
I tested on WinXP_Pro SP2. It works.
Kabron
-Given: 67
-Receive: 145
« Reply #7 on: November 30, 2005, 08:37:57 08:37 »
Metal, I apologize, you're right. The thing was that the IDE automatically find the compiler from PDS also installed on my PC. Now it's OK. Thank you very much!
ostemaden
« Reply #8 on: November 30, 2005, 10:26:45 22:26 »
un2000
« Reply #9 on: December 01, 2005, 07:57:40 07:57 »
WARNING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hi friends
for best install for proton IDE do not install for default dir
instal in short path for avoid ploblems before instal of too longer path
example      c:\proton      and Voila!!!!!!!!!!!
Yazi
-Receive: 23
« Reply #10 on: December 02, 2005, 05:44:57 17:44 »
why is not possible to debug with this version of proton on proteus simulator?
but with posek group version is possible:) is there sollution to debug on proteus with Metal version?
navy
« Reply #11 on: December 04, 2005, 07:44:01 07:44 »
Thank
« Reply #12 on: December 05, 2005, 09:09:31 21:09 »
Hello Yazi
I don't use Proteus, thats why I didn't pay attention to this edition being able to debug with proteus software. Also as some guys said, the core is 2.2.0....., so I don't expect it to debug directly with proteus, unless you use proteus with the .asm file after you compiled the .bas file.
Any way guys, you are all welcome, I am glad to see you able to use one of crownhill's products more successfully and freely now Smiley
bye
Yazi
-Receive: 23
« Reply #13 on: December 06, 2005, 05:32:10 17:32 »
Metal,
I think that we can  debug *. bas file under proteus only with new compiler as 3.0 of crownhills .
best regards
RA&RA
« Reply #14 on: December 06, 2005, 09:37:22 21:37 »
Good job. Thanks...
Aşağıda olan yukarıda olan gibidir, ve bir şeyin mucizesini gerçekleştirirler
picstudent
« Reply #15 on: December 08, 2005, 05:05:27 17:05 »
" I think that we can debug *. bas file under proteus only with new compiler as 3.0 of crownhills "
false !! you can compile the 2.20 bsa file in proton and D-bug it con proteus.
please read early posts ...
... rego ... who are are you really ?
jibun24
« Reply #16 on: December 23, 2005, 08:00:21 08:00 »
Hi everybody,
since version 6.7 you must add this line at the end of your code: F1_EOF:
So you can use *.bas directly in Proteus.
Bests regards
Breixo
-Given: 22
« Reply #17 on: December 24, 2005, 09:16:30 09:16 »
SOLO PARA HISPANOPARLANTES (Es que siempre tenemos problemillas con el "inglis", Shocked)
Hola a todos:
Como "aficionado" que soy, a veces tardo meses en volver a este foro, casi siempre con el susto de que Sonsivri nos ha abandonado, después de varios días sin que "Lair of Knowledge" apareciera en mi pantalla, al fin aparece y encima con nuevo formato, más minimalista pero más atractivo. Gracias Sonsivri ("Thank you very much, Sonsivri").
Naturalmente, despues de meses siempre encuentro novedades interesantísimas y entre ellas la de Proton DS, gracias MetaL, ("Thank you very much, MetaL").
No he tardado ni un segundo en bajármelo (bueno, rapidshare me hizo esperar 59 minutos) y lo único es que el fichero "readme!!.txt" de MetaL me resultó un poco confuso y me lié un poco con lo de la activación, así que para aquellos que tengan problemas, ahí van mis notas que espero os sirvan de algo.
Gracias nuevamente a Sonsivri y a MetaL y Felices Fiestas para todos,
Breixo
Breixo
-Given: 22
« Reply #18 on: December 24, 2005, 11:57:13 11:57 »
Hi, guys:
I've installed the Proton by MetaL and I've some troubles. Fisrt of all, see what it appears under Help-About:
*  mecanique                                                       FULL   *
*  PROTON IDE                                                               *
*  Proton IDE        *
*  IDE version 1.0.0.1                                                    *
*  (C) Copyright 2004 Mecanique UK                             *
*  PROTON+ BASIC Compiler                                         *
*  Loader version                                                          *
*  Compiler version 2.2.0.20                                         *
*  (C) Rosetta Technologies/Crownhill Associates         *
It's Ok or I've any problem in my installation?. I think Proton Plus Compiler integrated under Proton DS shall be 3.0. Or not?
Thanks,
:confused: Breixo
« Reply #19 on: December 24, 2005, 06:03:20 18:03 »
Hola Breixo
I am sorry if the readme!!.txt file was a little bit vague for you or other people, would you please upload the same document in english for the sake of other guys who don't understand spanish.
Estoy apesadumbrado si el archivo de readme!!.txt fuera un poco vago para usted o la gente, usted por favor upload el mismo documento en inglés para el motivo de otros individuos que no entiendan español. En hecho, tengo gusto de lengua española, yo deseo ser más capaz de usarla en mi vida de cada día.
Gracias
navy
« Reply #20 on: December 25, 2005, 01:08:11 13:08 »
thank you
Yazi
-Receive: 23
« Reply #21 on: December 26, 2005, 11:34:25 11:34 »
Hi jibun 24,
thanks for F1_EOF, now debug with *.bas file work fine under proteus.
best regards
Yazi
-Receive: 23
« Reply #22 on: December 26, 2005, 11:36:52 11:36 »
Hi jibun 24,
thanks for F1_EOF:, now debug with *.bas file work fine under proteus. its a magik label;)
best regards
lucasdark
-Given: 20
-Receive: 15
« Reply #23 on: December 26, 2005, 04:37:48 16:37 »
How can I add this line at the end of *.BAS File: F1_EOF:?
When I did it I can not compile the file.
Thanks and
Best regard
Yazi
-Receive: 23
« Reply #24 on: December 29, 2005, 09:37:51 09:37 »
DEVICE = 16F877
 XTAL = 20
 CCP1_PIN = PORTB.3      ' PORTC.1 is the CCP1 pin on the 16F877 device
 ici:
 HPWM 1,127,1000         ' Send a 50% duty cycle PWM signal at 1KHz
 DELAYMS 500               ' waite 500ms
 HPWM 1,64,2000           ' Send a 25% duty cycle PWM signal at 2KHz
 goto ici
 F1_EOF:
Pages: [1] 2 3  All
