April 29, 2026, 11:44:56 11:44
Author Topic: REQ: Serial Port with PHP?  (Read 15033 times)
smainj
-Given: 70
-Receive: 75
« on: August 12, 2011, 12:24:00 12:24 »
i try to read/write data from the serial port using PHP
but i can't find solution
plz anybody can help me and thank you.
zorx
-Given: 48
-Receive: 163
« Reply #1 on: August 12, 2011, 04:52:53 16:52 »
I think that googling will give you enough hints.
One of them:
http://code.google.com/p/php-serial/
titi
-Given: 4129
-Receive: 863
« Reply #2 on: August 12, 2011, 06:09:07 18:09 »
Hi smainj,
to complete the message of zorx, unfortunatly there is no download available at this time.
So by using SVN, this is the last source in attachment, i have not tested, but normally should be functional.
Best regards
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #3 on: August 12, 2011, 10:46:49 22:46 »
May I ask what you need PHP in connection with the serial port for ?
If you want to monitor, you can use any MySQL DB and a sniffer
Program ?
smainj
-Given: 70
-Receive: 75
« Reply #4 on: August 13, 2011, 10:12:48 10:12 »
Program ?
i will read temperature from many DS18B20 ,save them to databasse and plot the data
Posted on: August 13, 2011, 11:03:49 11:03 - Automerged
Hi smainj,
Best regards
thank you for your help, with this file i can send data but i can't read
titi
-Given: 4129
-Receive: 863
« Reply #5 on: August 13, 2011, 02:40:36 14:40 »
I have found a PHP instruction to read RS232 in library Direct IO. http://www.php.net/manual/en/book.dio.php
Here is an example:
<?php
exec
('mode com1: baud=9600 data=8 stop=1 parity=n xon=on');
// execute 'help mode' in command line of Windows for help
$fd dio_open('com1:'O_RDWR);
while (
1) {
$data dio_read($fd256);
  if (
$data) {
      echo
$data;
You can found more explications in : http://www.php.net/manual/en/function.dio-tcsetattr.php#51509
Best regards.
smainj
-Given: 70
-Receive: 75
« Reply #6 on: August 15, 2011, 11:49:35 11:49 »
thanks for your help
working code
<?php
    // Use this code to write directly to the COM1 serial port
    // First, you want to set the mode of the port. You need to set
    // it only once; it will remain the same until you reboot.
    // Note: the backticks on the following line will execute the
    // DOS 'mode' command from within PHP
    `mode com1: BAUD=9600 PARITY=N data=8 stop=1 xon=off`;
    $fp = fopen ("COM1:", "w+");
    if (!$fp) {
        echo "Uh-oh. Port not opened.";
    } else {
        $string  =   "Send"  ;
        echo $string;
        fputs ($fp, $string );
        sleep(5);
        $buffer = fgets($fp);
        echo $buffer ;
        fclose ($fp);
