December 10, 2025, 09:20:22 09:20
Author Topic: JDM programmer  (Read 5882 times)
tango
-Given: 28
« on: June 10, 2007, 12:22:34 00:22 »
First Hi to all .
Sorry for my bad English !!!
I was make pilot programmer JDM and find something interest !!!
On windows 98 SE it work 100% ok also like ICSP.
It need little modification to program new PICMICRO but it's OK.
But under windows XP SP2 it's not work OK !!!
When I programming 16F84A @ 4 MHz case problem in write to PIC and
also in ERASE PIC.
When I programming 16F84A @ 20 MHZ it's work 100% OK.
Also with 16F877A @ 20 MHZ it's work 100% OK.
Do somebody explain me that reasn ?
I look end if found why, I will post.
Best regards to all
« Last Edit: June 10, 2007, 11:33:54 11:33 by tango » Logged
pama
-Receive: 28
« Reply #1 on: June 11, 2007, 03:22:42 15:22 »
hi,
when i started playing with jdm programmer i had also some problems with this , but most of them was related to IcProg programs (it's just my opinion). After that i swap to using WinPic800, and i never had any problem with this.
good luck
pama
Rego
-Receive: 320
The power is back
« Reply #2 on: June 11, 2007, 04:08:35 16:08 »
i have the same opinion ....
go for winpic 800 (is the best)
Smiley ....THE POWER IS BACK.... Smiley
....REGO....
tango
-Given: 28
« Reply #3 on: June 11, 2007, 05:43:05 17:43 »
Yes I agree with that but I was have some problem with winpic800, ponyprog and winpic.
In all case of programming was JDM programmer and problem was with pic 16F84 @ 4 MHhz.
But in all case I sucess program pic 16F877A and 16F628A and 16F84A all @ 20 MHz.
I was probe with in socked and ICSP in all case.
My OS is WIN XPSP2.
Maybe have some modification for JDM.
I only use modification with MOSFET for 16F628A @ 20 MHz.
With or without modification for 16F628A and NEW generation of PIC problem is SAME.
Is some other modification for JDM Huh
Best regards to all  Smiley
shobhitkukreti
-Given: 50
Scientist 'B'
« Reply #4 on: June 11, 2007, 07:04:21 19:04 »
No der isnt any other modification required for d JDM.. i use winpic and it works well under both win98 se and winXPSP2
I love SONSIVRI
sheriefaly
« Reply #5 on: January 28, 2008, 08:43:55 08:43 »
winpic 800 is great do not miss it
