i wanna make an mp3 player with atmega8.....help with program - Sonsivri
May 14, 2026, 12:12:16 00:12
Author Topic: i wanna make an mp3 player with atmega8.....help with program  (Read 7943 times)
Tahmeed
-Given: 21
« on: May 22, 2011, 01:23:07 01:23 »
hello......
i wanna make an mp3 player of my own with an atmega8...is it possible only with 8 KB memory? or do i need bigger memory?? and what kind of programs (what functions) sud i learn?? pls help with ideas...programs..link...all u do have.....
thanx
-Receive: 4459
« Reply #1 on: May 22, 2011, 01:54:41 01:54 »
The answer to this has been posted so many times, use the search function, before starting a new topic
ALLPIC
-Receive: 72
« Reply #2 on: May 22, 2011, 09:03:58 09:03 »
vlsi vs1011 or vs1053 lot of options or else go with avr32 that has DAC and atmel has source code also
xatax
-Receive: 69
« Reply #3 on: July 05, 2011, 03:58:57 15:58 »
Also MikroElektronika released a board with VS1053 and Atxmega128a1.
Here is with some examples for download
http://www.mikroe.com/eng/products/view/688/mikromedia-for-xmega/
BR.
mr_byte31
-Given: 75
-Receive: 144
« Reply #4 on: July 24, 2011, 05:16:11 17:16 »
u want my idea?!!!
ok ,...
look , u can pay mp3 player from market , u will find it very cheap nowadays
remove the plastic cover and interface it with the micro-controller u want
u will find it very easy and can put many things to play
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #5 on: August 02, 2011, 02:14:12 02:14 »
u want my idea?!!!
ok ,...
But you don't have the FEELING when you did the whole thing by yourself
beginning with the prototype.
That's what a electronic enthusiast, like me, would say.
However I used a cheap timer switch for my sunset/dawn project for my geckos,
it's quite the path mr_byte31 suggested Smiley
kanishka13
« Reply #6 on: August 24, 2011, 11:30:41 11:30 »
Atmega8 alone will not help you. You've got to use a codec I.C or use a controller and implement one.
Check this out
http://www.opencircuits.com/Music_Player
« Last Edit: August 24, 2011, 11:32:49 11:32 by kanishka13 » Logged
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #7 on: October 23, 2011, 10:15:55 22:15 »
well if you�re into AVR. Why not using some of the AVR-Studio compatible 32bit controllers? Or changing to ARM? There are a lot of MP3 software libraries out there.
