PIC16F877A to PIC16F887` - Sonsivri
May 13, 2026, 06:10:46 06:10
Author Topic: PIC16F877A to PIC16F887`  (Read 5747 times)
Unhappy
-Given: 1018
-Receive: 101
« on: March 26, 2011, 02:20:09 02:20 »
I know this is silly can anyone tell me how to use/convert *.hex file meant for PIC16F877A to program a PIC16F887. I do not have any source code files.
Thanking you all in anticipation
UnHappy
tAhm1D
-Given: 103
-Receive: 180
« Reply #1 on: March 26, 2011, 10:55:57 22:55 »
This is rather difficult as 16F877A and 16F887 have some differences, which you would need to change in the code to make it compatible for 887. You could disassemble it (software are available) and modify it, but it would become quite messy.
« Reply #2 on: March 27, 2011, 11:36:13 11:36 »
What i will do:
1. Find the difference between the two micros
2. Find where your new hardware meet 1
3. Disasembly the hex in mplab
4. Modify the disasemlby listing  related to 2
5. Rebuild the hex
It will not be easy.
gan_canny
-Given: 101
-Receive: 26
« Reply #3 on: March 27, 2011, 10:35:40 22:35 »
Attempting this without source code may become a fools errand. Even assuming it was coded to be as portable as possible the compiler is often charged with small micros to make the code compact and maximize the efficient use of the on chip firmware.This means the instruction level code becomes specific even if the higher level wasn't.
I'd try the dis-assembly route but then using the ASM code  I'd recode in c.
« Last Edit: March 27, 2011, 10:38:47 22:38 by gan_canny » Logged
