April 27, 2026, 02:20:52 14:20
Author Topic: having problem with keypad4x4 and LCD16x2  (Read 9596 times)
mrauf57
« on: March 02, 2011, 04:09:22 04:09 »
hi every one,
i m new in proton compiler. i connect LCD16x2 and keypad (4x4) with 16f877A. my problem is that , in LCD, it can show from 0-15 on pressing from first till last key, while i want to print what is exactly written in keypad. like 1-9, 0, A to D.?
my second problem is that i can see the number only while pressing, i want that pressed no. to show untill i press new no.?
and third problem is that,i want to save the pressed digits from key pad , to send them wirelessly too, but thats a later task, first i need to save the digits in any variables.
many thinks and regards to all, plz waiting for the reply
my code is here,
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : [select VIEW...EDITOR OPTIONS]                    *
'*  Notice  : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
'*          : All Rights Reserved                               *
'*  Date    : 27.01.2011                                        *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
Device = 16f877a
XTAL 4
ALL_DIGITAL=true
Declare LCD_TYPE 0
Declare LCD_DTPIN PORTD.4
Declare LCD_ENPIN PORTD.3
Declare LCD_RSPIN PORTD.2
Declare LCD_INTERFACE 4
Declare LCD_LINES 2
Dim var1 As Byte
dim KEY as byte
High PORTd.1
DECLARE KEYPAD_PORT PORTb
Cls
main:
var1 = INKEY
Key = LOOKUP VAR1,[255,1,2,3,"A",4,5,6,"B",7,8,9,"C","*",0,"#","D"]
delayms 100
Print At 2,1, @var1,"Rauf"
goto main
TomJackson69
-Receive: 63
« Reply #1 on: March 02, 2011, 06:48:44 06:48 »
In your main loop, after read a key (var1 = INKEY), you should compare to an old key. If NEW key <> OLD key then you have new key pressed. Otherwise, either same key pressed or no new key pressed.
Let have a variable called OldVar1.
Then your main loop looks something like this:
main:
var1 = INKEY      // IS function INKEY returns 0-15 Huh
if (var1 != OldVar1)   // CHECK THE SYNTAX FOR BASIC
                                        // Print on LCD only have a new key pressed
      OldVar1 = var1   // Save the key value for later
delayms 100
goto main
I write program in C, but the logic is same as basic
Tom
« Last Edit: March 02, 2011, 06:53:15 06:53 by TomJackson69 » Logged
Con Rong Chau Tien
-Receive: 4460
« Reply #2 on: March 02, 2011, 11:22:47 11:22 »
If you choose 16F887 as your device and add your keypad and lcd as per PIC16_ALCD_VHB.DSN in proton.
then you can try it out in proton.
Device = 16F877
Xtal 4
All_Digital=true
Declare LCD_Type 0
Declare LCD_DTPin PORTD.4
Declare LCD_ENPin PORTE.1
Declare LCD_RSPin PORTE.0
Declare LCD_Interface 4
Declare LCD_Lines 2
Dim var1 As Byte
Dim KEY As Byte
High PORTD.1
Declare Keypad_Port PORTB
Cls
main:
var1 = InKey
KEY = LookUp var1,[255,1,2,3,"A",4,5,6,"B",7,8,9,"C","*",0,"#","D"]
DelayMS 100
GoTo main
works for me Smiley as far as to see what your code is doing.
« Last Edit: March 02, 2011, 11:30:15 11:30 by pickit2 » Logged
mrauf57
« Reply #3 on: March 09, 2011, 04:05:55 04:05 »
@TomJackson69, hi, i used ur way but still no progress, means still my problem to save pressed button in any variable, could not done. Still untill i pressed any botton, it appear, when i release, it shows 16 on LCD. second problem also remain unsolved, seems lookup table is not working, showing 0-15 while pressing from first till last button, not show what is written on the keypad.
here is my revised code on ur logic.
main:
var1 = INKEY
if var1 <> oldkey then
Key = LOOKUPl VAR1,[1,2,3,"A",4,5,6,"B",7,8,9,"C","*",0,"#","D"]
delayms 100
Print At 2,1, @var1, "Rauf"
var1 = oldkey
delayms 100
else goto main
endif
@pickit2, hi, what is meant by "PIC16_ALCD_VHB.DSN", i dont have this file, can u send me or guid me how can i get this file or example?
many thanks and waiting for reply
o2
-Given: 41
-Receive: 405
« Reply #4 on: March 09, 2011, 03:31:39 15:31 »
@mrauf57
Your print(var1) not result from lookup,result lookup is "key",variable from keypad 0-15,when press 1 var1=0,change var1 1-16 with +1
sorry if wrong,i'm not use proton.
main:
var1 = InKey
var1=var1+1
KEY = LookUpL var1,[255,"1","2","3","A","4","5","6","B","7","8","9","C","*","0","#","D"]
DelayMS 100
Print At 2,1, KEY,"Rauf"
GoTo main
-Receive: 4460
« Reply #5 on: March 09, 2011, 04:10:54 16:10 »
PIC16_ALCD_VHB.DSN is in sample folder, It is part of the Demo boards made by crownhill, and installed when proton is.
maybe you need to read proton help file. your code works if you change the ports to match above board.
TomJackson69
-Receive: 63
« Reply #6 on: March 09, 2011, 04:58:59 16:58 »
mrauf57,
Why don't you draw a circuit in Proteus to simulate to see if your program works. I will help you to get this project done.
One of my mistake in the program that I had suggested you is:
 It should be:
      Print At 2,1, @Key,"Rauf"
Try that to see if it works. Sorry for the mistake.
Anyways, draw your circuit in Proteus. Post your circuit and program, I will work on.
Tom
« Last Edit: March 09, 2011, 05:07:32 17:07 by TomJackson69 » Logged
Con Rong Chau Tien
-Receive: 4460
« Reply #7 on: March 09, 2011, 07:28:09 19:28 »
Its all in my 3rd post above, I even the rewrote mrauf57's code so it works with crownhill development board.
Your missing my point crownhill have Development and Prototype boards. the also have all the above ciruit on one of them.
They have sample code, and most Importantly a copy of Proteus (copy is even loaded if you have full proteus). so no need to leave PDS to test your code.
so easy way to try your code is
1. write it.
2. compile it.
3. run it via proton.
EDIT:
run proton load the code from my post above
complie code
cilck on ISIS in tool bar of proton
select PIC16_ALCD_VHB.DSN
protues opens job done.
« Last Edit: March 09, 2011, 07:33:43 19:33 by pickit2 » Logged
mrauf57
« Reply #8 on: March 10, 2011, 02:07:59 02:07 »
@TomJackson69 and o2,
thaaaaaaaaaaaaank u guys.... u r absolutely right, my approach was wrong, now my lookup table is working, now i can print as written on my key pad.. i changed my program using ur approach and ok...
@PICKIT2, m new in proton,dont know how to use proteus even, untill now i could not find the Development and Prototype boards and the circuits your talking about. also i want to use 18f4550 but the my proton is not supporting. Only supporting until 16f series.
now m downloading it (proteus lite free) and will learn , then surly i would need ur help to resolve some of problem... Many Many thanks
-Receive: 4460
« Reply #9 on: March 10, 2011, 12:17:27 12:17 »
You must be using a very old version if it don't support 18Fxxx chips.
You need bunions Proton, it supports most if not all the 18Fxxx chips.
and as for Proteus try P7.8i both in this forum.
fernandodiaz
« Reply #10 on: May 22, 2011, 05:18:42 17:18 »
Hi comunity  Some have sample code of    22 BIT A/D  converter   MCP3550  PROTON PLUS
-Receive: 4460
« Reply #11 on: May 22, 2011, 07:16:22 19:16 »
And has this to do with Topic?
 EDIT:Don't Hi-Jack Topics, If you have something to post, post it, if something to ask, Ask it.
Start your Topic with [Req] works for most people here.
