May 16, 2025, 10:34:58 22:34
Pages: 1 [2] 3  All
Author Topic: Sinewave Inverter With Pic  (Read 64611 times)
Taner
-Given: 299
-Receive: 59
« Reply #25 on: November 25, 2008, 09:58:53 21:58 »
Hi Friends,
I was redesign the circuit of the Sine-wave Inverter with PIC16F876A MCU
in Altium Designer Summer 08, and You can make your own PCB.
Circuit and C code, here:
http://www.4shared.com/file/216893275/9a3044e6/PIC16_Inverter.html
Best regards
 Smiley
« Last Edit: February 07, 2010, 02:09:38 14:09 by Taner » Logged
dbcv
« Reply #26 on: November 28, 2008, 05:58:35 05:58 »
Circuits for Inverter can be found at
http://www.explorecircuits.com/cir_power_inverter.htm
Taner
-Given: 299
-Receive: 59
« Reply #27 on: November 29, 2008, 02:13:37 14:13 »
Hi Friends,
here are the 3 libraries related with electrical circuits of the above design
"Sine-wave Inverter with PIC16F876A MCU" for Altium Designer 08:
http://www.4shared.com/file/90029512/b8a31732/Altium_Library.html
Best regards: Taner
 Smiley
« Last Edit: February 07, 2010, 02:11:18 14:11 by Taner » Logged
hogar
« Reply #28 on: December 03, 2008, 06:03:51 18:03 »
perhaps this can help
http://www.technology.niagarac.on.ca/people/mcsele/i2k.htm
thetrueman
-Given: 24
« Reply #29 on: December 04, 2008, 11:28:45 11:28 »
Hi any body have covertered this program file in hex format? Pls upload it. Thanks.
jojora
« Reply #30 on: December 07, 2008, 05:00:27 05:00 »
Hi, In hex format
http://www.4shared.com/file/74830518/15882c5a/sine_pwm_voltage-regulator_32_int.html
junaid_766
-Given: 10
« Reply #31 on: December 07, 2008, 09:59:55 09:59 »
thanks for sharing the .HEX file but you should also share the circuit diagram for which u had written the code
or share the code
only the hex file is of no use
arash_tah
-Given: 18
« Reply #32 on: December 08, 2008, 04:22:39 04:22 »
Hi every body
Is there any methode to syncronize inverter output with main?
If so please explain.
Taner
-Given: 299
-Receive: 59
« Reply #33 on: December 08, 2008, 06:12:18 18:12 »
Hi arash_tah,
yes, there is a two methods for synchronization of the inverter outputs to the main,
first is an simple analog method with analog regulators like TL494, SG3524
and second method is a true digital with digital PLL synchronization. This can be done with
PIC16 or PIC18 MCUs with buil-in PWM modules.
Best regards: Taner
 Smiley
tAhm1D
-Given: 103
-Receive: 180
« Reply #34 on: December 12, 2008, 08:17:53 20:17 »
there are many wayes to build sinewave inverter without microcontroller. some cmos or ttl and eprom, dac
u need to get topology thats it.
   Without microcontroller you can make a sinewave inverter with operational amplifiers using bubba oscillator. I have attached the circuit.
tAhm1D
-Given: 103
-Receive: 180
« Reply #35 on: December 13, 2008, 06:57:00 18:57 »
for who want to see circuit with pic16f72.
http://rapidshare.com/files/163986365/scamitic.rar
I have downloaded your schematic which shows sine wave inverter with pic 16f72. I have some questions regarding your schematic.
I assume that it is linear type and R-C low pass filter is placed before the transformer to demodulate the carrier frequency of 6.4kHz. Please correct me if I am wrong. If I am correct, please let me know the modalities of low pass R-C filter for demodulation. Hope you will throw some light on the above matter and hope that it will not create any problem regarding the commercial interest of your sine wave inverter.
sohel
-Given: 169
-Receive: 149
« Reply #36 on: December 14, 2008, 08:33:50 08:33 »
go here
http://www.sonsivri.com/forum/index.php?topic=3950.0
« Last Edit: February 02, 2009, 11:42:41 23:42 by sohel » Logged
rajudp
« Reply #37 on: July 25, 2009, 09:42:34 09:42 »
there is  a new reference design available at microchip site http://www.microchip.com/offlineups
Unhappy
-Given: 1006
-Receive: 101
« Reply #38 on: July 26, 2009, 11:47:21 11:47 »
Dear Rajeshkk D\L requires password
tAhm1D
-Given: 103
-Receive: 180
« Reply #39 on: July 27, 2009, 05:13:34 17:13 »
Hi Rajeshkk,
 I am having some quarries from you regarding the Inverter.
What is the Modulating Frequency ?
What is the value of the RC Filter for Demodulating Carrier Frequency? Hope to hear from you.
« Last Edit: September 04, 2009, 11:55:30 11:55 by tAhm1D » Logged
arash_tah
-Given: 18
« Reply #40 on: July 27, 2009, 05:58:35 17:58 »
Hi every body
I have a question
How can I generate synchronized spwm with main power?
By the way I use PIC to generate spwm
Unhappy
-Given: 1006
-Receive: 101
« Reply #41 on: August 04, 2009, 03:32:44 03:32 »
   pass:rkk16219700
D/l Website still saying- Password Protected File -
Please enter the password below to download this file
The password you entered was invalid, please try again!
Unhappy
fernandodiaz
« Reply #42 on: August 05, 2009, 02:27:30 14:27 »
Build DDS_ TO 2.5 to 20khz  sine wave 4 bit generator
this need low pas filter additional
modify value  fase = fase + xxxx
                                  1 TO  4095  this afect output frecuency
use scope to see output
orange
-Given: 702
-Receive: 204
« Reply #43 on: September 17, 2009, 06:00:11 06:00 »
Check the attached file from
http://www.letbasic.com/forum/showthread.php?s=40ea7bac0314261a85ac1f63eebed5b7&t=1846&page=4
sudipm
« Reply #44 on: November 25, 2009, 12:48:51 12:48 »
I was trying to develop a sinewave inverter with 16f73. The waveshape with normal domestic load is just perfect.But it was meant to be used with used with a machine which uses a technology like a dimmer . And whenever this machine is turned on , the wave shape is getting disturbed.
I have included the oscilloscope display of the output . Can anyone please give me some advise about how to correct this problem.
arash_tah
-Given: 18
« Reply #45 on: November 25, 2009, 01:26:56 13:26 »
hi sudipm
It depends on the type of inverter I have to see your scematic before guiding
zuisti
-Given: 242
-Receive: 780
« Reply #46 on: November 25, 2009, 02:29:42 14:29 »
Hi;
At my mind it's a mains noise only, caused by the triac-controlled motor at every moment when it's switched on.
Don't worry the system should be work perfectly so ignore it.
However, use a better filtered power supply for the PIC circuit, proper groundings,
 ... and/or use better shielded scope measuring wires :-) :-).
But  ...this is my mind only ...!!
Have a nice day
zuisti
sudipm
« Reply #47 on: November 25, 2009, 04:11:53 16:11 »
Hi;
Hi Zuisti
I know it is being caused by the triac switching. But i have to find a way to stop this deformation of the wave.
Hi arash_tah
I am using a full bridge inverter followed by a stepup transformer with split bobbin. The input to the inverter is 12VDc. I will draw a block diagram of the inverter and post here. I think the feedback system i am using is not fast enough to correct the wave shape.
« Last Edit: November 25, 2009, 04:18:44 16:18 by sudipm » Logged
shams_iqbal
-Receive: 12
« Reply #48 on: April 01, 2011, 08:24:18 08:24 »
hi to all users
          in my opinion there may be two issue regarding to wave disturbance
1) dimmer load may be higher then then unit amp rating and other is control method of pure sine wave invertor wich requierd double calculation all of pic16fx7x desgines based on single calculation which only corrects voltage errors on feedback but not the current error calculation and wave calculation points are less mean small no of wave segments per cycle in lookup table
so for solution  if firmware is enhanced and sine lookup table is doubled in segments  then its current segment count for example if present lookup table is devided in 20 portion to farm a complete wave so double this wave segment to 40 this will reduces the hormonic distortion but for best result add current feedback and calculation for ref of my point regarding to control of pure sine plz see freescale online ups ref disgine and also ti online ups desgine and latest ref desgine on dspic based ups desgine
Rony
« Reply #49 on: March 12, 2012, 06:44:27 18:44 »
HI shams Iqbal ,
Can you write little more detail about current feedback system. Cz i also made same kind of Inverter where a common problem is wave shape distortion. Normally i am using 18f452 and CCP1 for PWM and 64 Numbers of  Pwm lookup table For Feedback control.
Now i need the idea for Current lookup table, And the method of applying it with main sine lookup table Please help.
Pages: 1 [2] 3  All
