spurs21
-Given: 35
-Receive: 50
« on: May 19, 2007, 02:33:14 02:33 » |
well i let u here a file wich has some basic samples in pbp, it contains the .hex, .pbp files and the other files genered for the pbp, also it contains the simulation in proteus. i hope it was useful for some of u. regards download: http://www.4shared.com/file/16227317/d16667b8/samplespbp.html
eliorap
« Reply #1 on: May 22, 2007, 04:10:15 16:10 » |
Ok That's good! but I'm looking for a counter from 0 to 99 without interruption in pbp with a code very easy I haven't been able to find it, I found one but with interruption, so I want a code very easy
spurs21
-Given: 35
-Receive: 50
« Reply #2 on: May 28, 2007, 03:05:42 03:05 » |
hi eliorap i have that counter i`ll post it tomorrow 4 u ok. i hope that in this post you post all the the excercises that u have done in pbp. and we can learn together. regards
spurs21
-Given: 35
-Receive: 50
« Reply #3 on: June 01, 2007, 11:36:21 23:36 » |
well eliorap sorry i cant`n post the code that day, but here is now:
code:
i var byte j var byte unidad var byte decena var byte
TRISB=0
main: for i=0 to 99 for j=0 to 99 unidad = i dig 0 portb = unidad + 16 pause 5 decena = i dig 1 portb= decena + 32 pause 5 next j next i goto main end
any cuestion tell me. regards... by the way the circuit diagram is the same that the other counter posted in the samples.
« Last Edit: June 01, 2007, 11:41:31 23:41 by spurs21 »
spurs21
-Given: 35
-Receive: 50
« Reply #4 on: June 01, 2007, 11:40:02 23:40 » |
come on friends post your samples o pbp here, i`m looking samples about 5x7 matrix, i have some of that, but i need more information about that, please if someone have done one help me. regards
spurs21
-Given: 35
-Receive: 50
« Reply #6 on: October 25, 2007, 04:40:22 04:40 » |
ok man i´ll upload tomorrow ok regards....
spurs21
-Given: 35
-Receive: 50
« Reply #7 on: October 27, 2007, 05:36:45 17:36 » |
-Given: 562
-Receive: 409
« Reply #8 on: November 11, 2007, 03:14:36 15:14 » |
thanks
you should use the thankyou button read the forum rules you might get banned  naughty naughty
bbarney
-Given: 405
-Receive: 545
« Reply #9 on: November 11, 2007, 09:43:42 21:43 » |
SONSiVRi
Administrator
-Given: 75
-Receive: 405
« Reply #10 on: November 11, 2007, 10:01:03 22:01 » |
you should use the thankyou button read the forum rules you might get banned  naughty naughty I was deleted him, he registered again and he started to post "thanks" again again. Its great to having warn option, I have added new modification on this forum. You done your job by pressing "report to moderator" There are "reports place" we checking everyday.
- Houston, we have a problem.
