Lumos
-Given: 74
« on: October 24, 2010, 08:27:33 08:27 » |
With commands "Print at 3,1 ..." and "Print at 4,1..." the text is written from the first position 3,4 and 4,4. Print at 1,1 and 2,1 is ok. (I use LCD_Lines 4, LCD_Interface 4)
Who can help me?
-Given: 582
« Reply #1 on: October 24, 2010, 09:29:26 09:29 » |
That's not much to go on You need to give us a bit more info, like show some sample code, your set up for the lcd then we may be able to help you
wizpic
-Given: 405
-Receive: 545
« Reply #2 on: October 24, 2010, 12:14:27 12:14 » |
Try inserting this line near the top of your code as it seem's to cure a lot of wierd lcd problems with certain chips Declare FLASH_CAPABLE = FALSE
piappo
« Reply #3 on: October 24, 2010, 12:49:37 12:49 » |
try this:
Cls Print At 1, 1 , "" Print At 2, 1, "" Print At 3, 1 , "try" Print At 4, 1, "this"
Lumos
-Given: 74
« Reply #4 on: October 24, 2010, 06:58:00 18:58 » |
hello, thanks for your help.
Declare FLASH_CAPABLE = FALSE -> did not work Print At 1, 1...4,1 -> did not work
-Receive: 4459
« Reply #5 on: October 24, 2010, 08:06:08 20:06 » |
Lumos is your code a secret? or the pic chip you used? and of couse the chipset the LCD is using. That's not much to go on You need to give us a bit more info, like show some sample code, your set up for the lcd then we may be able to help you wizpic
-Given: 582
« Reply #6 on: October 24, 2010, 08:53:52 20:53 » |
Lumos is your code a secret? or the pic chip you used? and of couse the chipset the LCD is using. The code is there it's hiding just above the picture  It's called RHandT.txt It must be hwo they have been uploaded wizpic
piappo
« Reply #7 on: October 24, 2010, 09:05:53 21:05 » |
change your code con this: start:
Print At 1,17,"Ta(",Dec2 Ta,") > Ti(",Dec2 Ti,")" Print At 2,17,"rHa(",Dec2 rHa,")< rHi(",Dec2 rHi,")" Line 3 is an extension of Line 1 and Line 4 is an extension of Line 2
if the display is 20x4:
Print At 1,21,"Ta(",Dec2 Ta,") > Ti(",Dec2 Ti,")" Print At 2,21,"rHa(",Dec2 rHa,")< rHi(",Dec2 rHi,")"
« Last Edit: October 24, 2010, 09:18:25 21:18 by piappo »
-Receive: 4459
« Reply #8 on: October 24, 2010, 10:26:07 22:26 » |
The problem is in your config 18Fxxx devices need Config start /and/end and inculed the Declare Flash_Capable = FALSE plus there maybe another gotyou about the 16x4 line display, but I don't have my notes here at home. look at the post above, its something about the code. Config_Start PLLDIV = 5 ' Divide by 5 (20 MHz oscillator input) CPUDIV = OSC1_PLL2 ' [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2] USBDIV = 2 ' USB clock source comes from the 96 MHz PLL divided by 2 FOSC = HS ' Internal oscillator, HS used by USB FCMEN = OFF ' Fail-Safe Clock Monitor disabled IESO = OFF ' Oscillator Switchover mode disabled PWRT = OFF ' PWRT disabled BOR = On ' Brown-out Reset enabled in hardware only (SBOREN is disabled) BORV = 3 ' Minimum setting VREGEN = Off ' USB voltage regulator not enabled WDT = OFF ' HW Disabled - SW Controlled WDTPS = 128 ' 1:128 MCLRE = OFF ' RE3 input pin enabled; MCLR disabled LPT1OSC = OFF ' Timer1 configured for higher power operation PBADEN = Off ' PORTB<4:0> pins are configured as analog input channels on Reset CCP2MX = On ' CCP2 input/output is multiplexed with RC1 STVREN = On ' Stack full/underflow will cause Reset LVP = OFF ' Single-Supply ICSP disabled XINST = OFF ' Instruction set extension and Indexed Addressing mode disabled (Legacy mode) Debug = OFF ' Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins Config_End
« Last Edit: October 24, 2010, 10:28:24 22:28 by pickit2 »
-Given: 405
-Receive: 545
« Reply #9 on: October 24, 2010, 10:30:07 22:30 » |
you thinking Declare LCD_Interface 8
or to slow the display down
LCD_CommandUs = 2000 LCD_DataUs = 50
Or you thinking
LCDOUT $FE,
I know the LCDOUT $FE, worked one time in proton even though it's PBasicPro , but I think it was the problem Declare Flash_Capable = FALSE takes care of
« Last Edit: October 24, 2010, 10:32:45 22:32 by bbarney »
TomJackson69
-Receive: 63
« Reply #10 on: October 24, 2010, 10:56:10 22:56 » |
Here is some of my though.
Since your program is displayed then I would assumed your initialize OK. How about the address of the LCD defined in Proton? It could be the DELAY not long enough between display each char. Try to slow down a bit between display each char will help.
I think there is a delay problem like bbarney has said, please FOCUS on that.
However here is LCD addresses:
Some 4x20 and 4x16 LCD have line address as:
Line1 0x00 Line2 0x20 Line3 0x00 Line4 0x40
For Hitachi HD66712 controller the address:
Line1 0x00 Line2 0x20 Line3 0x40 Line4 0x80
16 chars/line display address: Line 1 0x80 Line 2 0xC0 Line 3 0x90 Line 4 0xD0
20 chars/line display address: Line 1 0x80 Line 2 0xC0 Line 3 0x94 Line 4 0xD4
Tom
Con Rong Chau Tien
-Given: 499
« Reply #11 on: October 24, 2010, 11:07:48 23:07 » |
I agree with TomJackson69, check your LCD display data sheet to make sure the display address are done correctly.
-Given: 405
-Receive: 545
« Reply #12 on: October 25, 2010, 02:15:27 02:15 » |
Lumos try what piappo say's but just try putting 40 characters on line one and see if the other char show up on line 3 you really need to setup up the config to like pickit says as portb.3 doubles as a ccp pin if not set right and you have it as your enable pin and you should use TRISB %xxxxxxxxxx along with PORTB % xxxxxxxxx so you know every pin is set the way you hope It would really help if you posted a link to the displays datasheet one question does the display have 2 chips on it so 2 enable pins ? another thing is you have Print Cls start: Print At 3,1,"Ta(",Dec2 Ta,") > Ti(",Dec2 Ti,")" Print At 4,1,"rHa(",Dec2 rHa,") < rHi(",Dec2 rHi,")" try putting the cls further down with a delay and you just need cls no need for the print start:
Cls DelayMS 500 Print At 3,1,"Ta(",Dec2 Ta,") > Ti(",Dec2 Ti,")" Print At 4,1,"rHa(",Dec2 rHa,") < rHi(",Dec2 rHi,")"
« Last Edit: October 25, 2010, 02:56:23 02:56 by bbarney »
Lumos
-Given: 74
« Reply #13 on: October 25, 2010, 08:46:07 08:46 » |
many, many thanks, piappo, it work  Thanks also to the others for the quick help
« Last Edit: October 25, 2010, 08:52:49 08:52 by Lumos »
Ahmad_k
SCG Moderator
-Given: 179
-Receive: 1299
« Reply #14 on: October 25, 2010, 05:39:44 17:39 » |
Guys this is an old problem with proton using 16x4 LCD.
There was an error with "Print at 4,1" and "at 3,1" According to the help : $FE, $C0 Move cursor to beginning of second line $FE, $94 Move cursor to beginning of third line $FE, $D4 Move cursor to beginning of fourth line
there was an error. this should be : $FE, $C0 Move cursor to beginning of second line $FE, $90 Move cursor to beginning of third line $FE, $D0 Move cursor to beginning of fourth line
and this error is embedded in the compiler. so if you want to print at 4,1 just use the above command.
ex : Print $FE,$D0,"Test String"
