July 24, 2025, 01:01:53 01:01
pushycat
An effort to put up Construction projects published in Electronics For you Magazine will be done here in this thread regularly. If any other member too has any access to any construction articles from the magazine, is most welcome to post it here. All articles will include schematics, full articles with PCB layouts and codes. Thus material whatever available from the magazine will be posted here, and these are not my projects. Any claims about its non working or discussions about the same may be continued on the regular discussion forums. This thread will be exclusively for posting projects only.
Requests for any EFY published projects such as Code or other info may be continued on this thread:
EFY Magazine projects Requests Code or More
http://www.sonsivri.com/forum/index.php?topic=37591.0
EDIT: Ask for code or hijack this topic and your post will be deleted, and a warning given. Help keep topic clean
« Last Edit: June 15, 2019, 08:07:05 08:07 by pushycat »
Pages: [1] 2 3 4 5 6 7 8 ... 10
Author Topic: EFY Magazine projects  (Read 235549 times)
pushycat
-Given: 231
-Receive: 1448
« on: August 25, 2010, 02:00:38 14:00 »
« Last Edit: June 15, 2019, 08:07:05 08:07 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #1 on: August 25, 2010, 03:30:53 15:30 »
1. Microcontroller based water level controller with LCD
Many a times we forget to switch off the motor pushing water into the overhead tank (OHT) in our households. As a result, water keeps overflowing until we notice the overflow and switch the pump off. As the OHT is usually kept on the top most floor, it is cumbersome to go up frequently to check the water level in the OHT.
Here’s a microcontroller-based water- level controller-cum-motor protector to solve this problem. It controls ‘on’ and ‘off’ conditions of the motor depending upon the level of water in the tank. The status is displayed on an LCD module. The circuit also protects the motor from high voltages, low voltages, fluctuations of mains power and dry running.
Enjoy
« Last Edit: March 23, 2024, 01:30:29 13:30 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #2 on: August 26, 2010, 05:24:14 05:24 »
2. Laptop power converter (12 to 19 volts converter for Laptops)
This mighty gadget helps use and charge laptops on the move by converting 12 volt to 19 volts up to 3 amps which is suitable with 90% of the laptops. Construction project with full article, description and PCB layout.
« Last Edit: March 25, 2024, 01:50:11 13:50 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #3 on: August 26, 2010, 10:47:27 10:47 »
3. Collection of construction projects and circuit ideas published from Jan to December 2000. Link attached
« Last Edit: March 23, 2024, 08:18:07 08:18 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #4 on: August 27, 2010, 12:15:43 12:15 »
4. PIC16F877A-based Temperature Monitoring System (May 2010)
Here we describe a simple temperature measurement and display system based on LM35 sensor and PIC16F877A microcontroller.
« Last Edit: March 23, 2024, 08:18:44 08:18 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #5 on: September 01, 2010, 03:57:03 15:57 »
4. Collection of construction projects and circuit ideas published from Jan to December 2001.
Links updated
Enjoy
« Last Edit: March 23, 2024, 08:19:25 08:19 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #6 on: September 24, 2010, 02:00:32 14:00 »
PIC Microcontroller-based Electronic Lock
An electronic lock allows activation of an electric appliance only on entering the correct password. Here we present such an electronic locking system in which a PIC16F877A microcontroller plays the role of the processing unit.
« Last Edit: March 23, 2024, 08:26:23 08:26 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #7 on: October 05, 2010, 01:46:56 13:46 »
Remote-controlled 6-Camera CCTV Switcher
Here is a Microcontroller based remote-controlled CCTV switcher circuit to monitor six cameras on a single or dual monitor/TV. The original project is designed so that the audio is routed to a separate audio amplifier, and two RCA jacks are given for 2 video outputs. But as a fact that every TV or monitor will have an A/V input, one of the output may be connected to audio whereas other to the video output. All source codes are included in the file.
« Last Edit: March 23, 2024, 08:27:15 08:27 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #8 on: October 07, 2010, 01:12:36 13:12 »
Cellphone-Based device Control with Voice Acknowledgement
Here is a circuit that lets you operate your home appliances like lights and water pump from your office or any other remote place. So if you forgot to switch off the lights or other appliances while going out, it helps you to turn off the appliance with your cellphone.
« Last Edit: March 23, 2024, 08:28:02 08:28 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #9 on: October 08, 2010, 08:44:09 08:44 »
Wireless Equipment Control Using AT89C51
Here is a microcontroller-based wireless equipment controller that can switch on or switch off up to four devices at a desired time
interval set by the user in the transmitter.
« Last Edit: March 23, 2024, 08:28:30 08:28 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #10 on: October 19, 2010, 01:07:34 13:07 »
PIC based automatic Voltage Stabiliser Using PIC16F877A
Here is the circuit of an automatic voltage stabiliser that can be adapted to any power rating. Its intelligence lies in the program
on PIC16F877A—a low-cost microcontroller that is readily available.
« Last Edit: March 23, 2024, 08:28:59 08:28 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #11 on: October 26, 2010, 06:13:20 06:13 »
Motion Sensor for Security Light (Circuit idea)
Here is a system based on PIR motion detector module BS1600 (or BS1700) that can be used for security or corridor lighting in power-saving mode. This was published in the magazine under "Circuit ideas" section and thus no PCB layout was published.
« Last Edit: March 23, 2024, 08:29:29 08:29 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #12 on: November 03, 2010, 11:50:18 11:50 »
Make Your Own Digital Alarm Clock
Here we have described a microcontroller-based digital alarm clock. The time and alarm can be customised by the user, and are shown on the liquid crystal display (LCD) of the system.
« Last Edit: March 23, 2024, 08:29:55 08:29 by pushycat » Logged
tokyo_emb
-Given: 144
-Receive: 44
« Reply #13 on: November 12, 2010, 03:02:19 15:02 »
HELLO,
         its really hard to find a free copy of EFY MAGAZINE except 2000 and 2001 collection.though i have found a copy of EFY MARCH 2009.the link is bellow....
http://www.easy-share.com/1904110060/e4u0309_sacrFX.rar
pushycat
-Given: 231
-Receive: 1448
« Reply #14 on: November 13, 2010, 07:36:24 07:36 »
Pulse Counter Using AT89C4051
Pulse counters are widely used in our day-to-day life. Almost all museums and theatres have a visitor counter installed at entry/exit to measure the visitor traffic. In industries, counting is done for production control. Market tests too are performed by counting the sold goods.
« Last Edit: March 23, 2024, 08:32:05 08:32 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #15 on: November 22, 2010, 03:20:57 15:20 »
PC-based Wireless Control for Toy Car
Here we show how you can control a toy car through your PC’s serial port using a pair of ASK transmitter and receiver modules.
http://rapidshare.com/files/423802875/PC_based_wireless_control_for_Toy_car.rar
http://www.4shared.com/file/C1oj0f0w/PC_based_wireless_control_for_.html
http://ifile.it/wp25o7r
« Last Edit: November 24, 2010, 03:55:15 15:55 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #16 on: December 04, 2010, 07:03:41 07:03 »
Water-Tank-Filling Guard System
This water-tank-filling guard system for your overhead and ground tanks automatically switches off the pumping system when the overhead tank starts overflowing or the ground tank is empty.
http://rapidshare.com/files/434791473/Water_tank_filling_guard_system.rar
http://www.4shared.com/file/-BNtyRTV/Water_tank_filling_guard_syste.html
http://ifile.it/fyugrz0
« Last Edit: December 11, 2010, 06:01:24 06:01 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #17 on: December 11, 2010, 06:01:42 06:01 »
Secure Digital Access System using iButton
Access control forms a vital link in a security chain. Here we describe a secure digital access
system using iButton that allows only authorised persons to access a restricted area.
http://rapidshare.com/files/434791878/Secured_digital_acess_system_with_iButton.rar
http://www.4shared.com/file/nOt9vg4E/Secured_digital_acess_system_w.html
http://ifile.it/c0gwmof
« Last Edit: January 11, 2011, 07:26:44 07:26 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #18 on: January 11, 2011, 07:26:18 07:26 »
RFID based security system
A radio-frequency identification (RFID) based access-control system allows only
authorised persons to enter a particular area of an establishment. The authorised
persons are provided with unique tags, using which they can access that area.
http://rapidshare.com/files/441417832/RFID_Based_secirity_system.rar
http://www.4shared.com/file/NBmhEyTa/RFID_Based_secirity_system.html
http://ifile.it/v912ulq
« Last Edit: January 22, 2011, 06:03:58 06:03 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #19 on: January 22, 2011, 06:05:52 06:05 »
Beginners guide for AVR development
Here is a guide to Atmel AVR development which would be very helpful to beginners for learning AVR microcontrollers.
http://rapidshare.com/files/441417860/Beginners_guide_to_AVR_development.rar
http://www.4shared.com/file/xAhqsRVT/Beginners_guide_to_AVR_develop.html
http://ifile.it/pgzf57e
« Last Edit: February 01, 2011, 07:18:01 07:18 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #20 on: February 01, 2011, 07:19:38 07:19 »
Speed control for AC / dc motorsHere is a circuit utilising the simple NE555 timers to produce PWM and pahse control signals
that can control the speed of both AC as well as DC motors.
http://rapidshare.com/files/441417927/Speed_control_for_AC_and_DC_Motors.rar
http://www.4shared.com/file/h_sVjExB/Speed_control_for_AC_and_DC_Mo.html
http://ifile.it/tc8perk
« Last Edit: February 07, 2011, 08:30:50 08:30 by pushycat » Logged
pushycat
-Given: 231
-Receive: 1448
« Reply #21 on: February 07, 2011, 08:31:55 08:31 »
Photo Voltaic charge controllerA charge controller is one of the main components of a solar battery charging system. Its main function
is to fully charge a battery without permitting overcharge or reverse current flow (generally during night).
http://rapidshare.com/files/441417977/Photovoltaic_battery_charge_controller.rar
http://www.4shared.com/file/b2DpYCVf/Photovoltaic_battery_charge_co.html
http://ifile.it/iut7vp0
pushycat
-Given: 231
-Receive: 1448
« Reply #22 on: March 15, 2011, 03:06:25 15:06 »
Tutorial on ATmega32 Development Board (Part 1 of 2) Here we describe a development board that is based on the popular AVR ATmega32 microcontroller and meets the needs of both the beginners as well as professionals. The first part is published and the second part of the article is expected next month.
http://rapidshare.com/files/452611293/Atmega32_development_Board_Pt1.rar
http://ifile.it/bcq1kn4
http://www.4shared.com/file/e2xFQFLY/Atmega32_development_Board_Pt1.html
pushycat
-Given: 231
-Receive: 1448
« Reply #23 on: March 18, 2011, 08:13:11 08:13 »
Interfacing Nokia Colour LCD With AVR Microcontroller
Here we describe how to use the colour LCD of a Nokia handset (model 6100, 7210, 6610, 7250 or 6220) with Philips PCF8833
chipset through ATmega2560 ATMEL AVR microcontroller.
http://rapidshare.com/files/453120503/Interfacing_Nokia_LCD_with_AVR.rar
http://www.4shared.com/file/qaf4_H4x/Interfacing_Nokia_LCD_with_AVR.html
http://ifile.it/zv93mbh
pushycat
-Given: 231
-Receive: 1448
« Reply #24 on: March 24, 2011, 04:59:59 16:59 »
Automatic Room Power Controller
The circuit presented here senses the absence of occupants in a room and automatically shuts off the power to a particular
appliance, say, a tubelight or fan. It turns on the appliance again when someone enters the room.
http://rapidshare.com/files/453119841/Automatic_room_power_controller.rar
http://www.4shared.com/file/b5q4mLil/Automatic_room_power_controlle.html
http://ifile.it/irajpu8
