April 11, 2026, 05:30:31 17:30
Author Topic: [Req] One-dimension Edge detection using optical array sensor  (Read 4733 times)
elcielo
-Given: 115
« on: August 19, 2010, 05:31:04 05:31 »
I want One-dimension Edge detection using optical array sensor.
Optical array sensor
         TSL3301
                    http://www.taosinc.com/productdetail.aspx?product=18
         MLX90255BC
                    http://www.melexis.com/Sensor_ICs_Infrared_and_Optical/Optical_sensing/Linear_Optical_Array__385.aspx
         or handmade optical array sensor
plz help me.
« Last Edit: August 20, 2010, 02:29:09 02:29 by elcielo » Logged
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #1 on: August 19, 2010, 03:54:31 15:54 »
Standard method for machine shops:
These
Usable for X and Y axis.
SuperDrive
-Given: 36
« Reply #2 on: August 19, 2010, 09:49:09 21:49 »
"Edge Detection" also can be an image processing thing.
oldvan
-Receive: 107
« Reply #3 on: August 20, 2010, 02:52:59 02:52 »
WOW.  Now that description was updated, my post was WAY off,
but sure seemed correct with the earlier description.
Hopefully someone else has help for what you really need.
« Reply #4 on: August 20, 2010, 04:05:48 04:05 »
We need a LOT more information on what you're doing -> application or constraints, lighting, motion, speed. accuracy, edge length, proximity, artifacts, ambient noise, etc etc etc etc
Listing an optical detector p/n is about the same as saying you are using a 5k resistor.
1st rule of design: frame the problem with proper and adequate constraints.
