April 21, 2026, 07:22:42 19:22
Author Topic: Need password for AT89STK-10 starter kit firmware  (Read 6420 times)
jestanoff
« on: July 16, 2010, 11:27:02 23:27 »
Someone have a password for firmware AT89STK-10 evaluation kit from Atmel. Official firmware is code protected and only demo version is available.
http://www.efo.ru/ftp/pub/atmel/_C51_and_AVR_with_USB/html/dev_kit_at89stk10.htm
I need pass for these zip:
http://www.efo.ru/ftp/pub/atmel/_C51_and_AVR_with_USB/libraries/c51_library/at89c5131/c5131-mass-storage-NF-2K-1_0_0P.zip
I would be very grateful if anyone has the software.
blauwhaar
-Given: 11
« Reply #1 on: August 16, 2010, 09:10:31 09:10 »
Look here:
http://www.atmel.com/dyn/products/product_card.asp?part_id=3479
if you can program you have a good skeleton with this code:
http://www.atmel.com/dyn/resources/prod_documents/c5131-mass-storage-virtual-1_0_6.zip
Most of the missing code (in the protected zip) is available in this zipfile.
I hope you can program and change the code for your needs.
If you have knowledge of reverse engineering:
http://ftp://ftp.efo.ru/pub/atmel/_AVR_MCUs_8bit/_WITH_USB/STK525_CD/libraries/c51_library/at89c5131/c5131_mass-storage-NF-2K-1_0_0.hex
Happy coding!
(I shall try to get the password, but the atmel site does not respond on the link in de zipfile, i have an at89c5131 kit. If you have further questions do not hesistate to ask me.)
« Last Edit: August 16, 2010, 09:23:41 09:23 by blauwhaar » Logged
jestanoff
« Reply #2 on: August 16, 2010, 11:50:47 11:50 »
Hi blauwhaar,
In my project i already use compiled hex file c5131_mass-storage-NF-2K-1_0_0.hex with shematics from http://www.atmel.com/dyn/resources/prod_documents/doc7516.pdf. Project works fine with only change a on-board crystal to 16MHz (originally 24MHz).  But for my other project I need to now how Atmel firmware do Nand Flash Translation Layer, therefore I needed the C-source of mass storage. After a week experiments I find a right NFTL and all other necessary data, project work without problems.
