April 11, 2026, 01:41:15 13:41
Author Topic: [Help]When in debug the I2C'SCL or SDA that be in low???  (Read 4120 times)
jlian168
« on: July 13, 2010, 08:57:22 08:57 »
Dear all:
Pardon me,My english not well.
1.Use PIC16F877A & DS1307.
2.BCLIF is set.
3.Like topic:When power is on or the soft is run then How can i let the SCL or SDA set to high?
Thank you very much.
-Receive: 4459
« Reply #1 on: July 13, 2010, 01:04:52 13:04 »
see this project
http://picnote.blogspot.com/2009/01/simple-clock-using-ds1307-pic16f877a.html
jlian168
« Reply #2 on: July 14, 2010, 01:32:25 01:32 »
Thank you sir:
But i mean is:
1.If SCL is low,Maybe i can TRI_SCL=1 to release SCL to high.
2.But if SDA is low by slave,So how can i to release it?
3.The situation is in to repeat reset the CPU(No power off).
4.Maybe use Soft I/O to simulate the I2C is easy to release it,
   But i use MSSP hradware.
5.Such a state that anyone has been met?Can you tell me the answer
