May 23, 2025, 07:07:08 07:07
Pages: 1 [2] 3  All
Author Topic: Proteus Models/Designs/Layouts & Stuff  (Read 30814 times)
zuisti
-Given: 242
-Receive: 780
« Reply #25 on: April 21, 2007, 05:00:38 17:00 »
Sorry, There were some errors in some files so I have deleted it. Will upload on correction.
Please upload it!
This is worthly to look:
http://rapidshare.com/files/27172374/SkyEye___ProVer_DSN.zip.html
Tested with Proteus 6.9 sp5.
Thanks for the files from you!
zuisti
sureshsharma2032
« Reply #26 on: April 22, 2007, 07:54:39 07:54 »
Great zuisti. Thanks.
Please upload some more.
Thankyou.
sohel
-Given: 169
-Receive: 149
« Reply #27 on: April 22, 2007, 02:00:07 14:00 »
nice topics.
can anybody share model for AT89S8252 .
thanks
zuisti
-Given: 242
-Receive: 780
« Reply #28 on: April 25, 2007, 01:49:34 13:49 »
Hi Suresh!
Please look at this post from me on thema SDK:
http://www.sonsivri.com/forum/index.php?topic=3342.msg16705;topicseen#msg16705
I think it is useful for you too...
Or do you have a newer? Please upload it!
Again: please upload the models2.rar repaired if you are ready!
zuisti
« Last Edit: April 25, 2007, 01:56:24 13:56 by zuisti » Logged
spasbyspas
-Given: 739
-Receive: 366
« Reply #29 on: May 07, 2007, 07:25:21 07:25 »
http://rapidshare.com/files/29927447/ProteusBiblioteki.rar
sureshsharma2032
« Reply #30 on: May 07, 2007, 03:50:35 15:50 »
A Battery model with 1 to 30 Volts & Ampere Indicator. There's a HIERARCHICAL DESIGN in it.
http://rapidshare.com/files/29993093/BATSUPIMETER.rar
Thanks.
zuisti
-Given: 242
-Receive: 780
« Reply #31 on: May 07, 2007, 04:23:32 16:23 »
Hi Suresh!
Please look at this post (last from me, today):
http://www.sonsivri.com/forum/index.php?PHPSESSID=7afb39b27e774e06a19cc26f0e999c0e&topic=3342.0
If you don't have it yet...
zuisti
sureshsharma2032
« Reply #32 on: May 07, 2007, 08:10:50 20:10 »
Hi zuisti
I have already looked at your post & downloaded the file. Thanks for it. Keep Going.
sureshsharma2032
« Reply #33 on: May 08, 2007, 08:21:33 08:21 »
595 Proteus Models in *.Mdf format.
http://rapidshare.com/files/30118314/Proteus_Models.rar
                              OR
Just a single file (All.LML) with all the 595 Models in it. Place it in Models directory of your Proteus Installation.
http://rapidshare.com/files/30120668/ALL.rar
« Last Edit: May 08, 2007, 08:41:41 08:41 by sureshsharma2032 » Logged
sureshsharma2032
« Reply #34 on: May 08, 2007, 12:22:35 12:22 »
There is no difference I have seperated all the models from proteus & also added new models which doesn't come with proteus. Means old + new models in a single package. As per your requirement you can select a single model(*.Mdf) or a group of models(*.Mdf) & place in your Models directory as per requirement for your schematic. If someone needs only a single model he/she can select it & place in the Models directory OR if you want all the models then just place All.LML in the Models directory.
« Last Edit: May 08, 2007, 12:31:36 12:31 by sureshsharma2032 » Logged
sureshsharma2032
« Reply #35 on: May 08, 2007, 12:37:13 12:37 »
A Hobby Servo Motor Design
http://rapidshare.com/files/30150398/Hobby_Servo_Motor.rar
sureshsharma2032
« Reply #36 on: June 05, 2007, 01:02:28 13:02 »
A Count-Down Timer Design
File: Count_Down_Timer.rar
DownloadLink: http://rapidshare.com/files/35357843/Count_Down_Timer.rar
File-Size: 0.02 Mb
micropar
-Given: 44
« Reply #37 on: June 10, 2007, 12:48:31 12:48 »
Hi Sureshsharma2032 or any Gentleman,
                              OR
Can any one upload the same once again? Links above are all dead.
Website says "Files removed by uploader".
Thanks in advance,
Regards,
--micropar--
ppa88
-Given: 49
-Receive: 131
« Reply #38 on: June 13, 2007, 08:22:35 08:22 »
Here is an example which shows the PWM capability of PIC16F877. I have included the full MPLAB project along with the CCS C source code. The RS232 terminal allows you to select among 3 frequencies. The value of the A to D conversion depending on setting of the pot is also displayed and the change in PWM duty cycle can be clearly seen on the scope. I have also supplied a file defs16F877.h which will help you all to write programs in CCS C for 16F877.
The source code file has comments which explain how the PWM section of 16F877 is configured.
http://rapidshare.com/files/36890829/pwm.rar.html
Good wishes to all
zuisti
-Given: 242
-Receive: 780
« Reply #39 on: June 18, 2007, 08:27:42 08:27 »
I just uploaded both RARs above (zipped to one file):
http://rapidshare.com/files/37874711/ProteusModels595.ZIP.html
An other gentleman  Smiley
abbas
« Reply #40 on: September 12, 2007, 09:31:33 21:31 »
anyone have model for AT89s51/52?Huh Cool
sohel
-Given: 169
-Receive: 149
« Reply #41 on: September 13, 2007, 07:13:09 07:13 »
i am looking model for at89s8252. Shocked
Kova
-Given: 172
-Receive: 24
« Reply #42 on: September 13, 2007, 08:12:28 08:12 »
HI all,
I'm looking for a LM567/NE567 model....please help me  Cry
Thanks a lot
Bye
« Last Edit: September 13, 2007, 10:11:25 10:11 by Kova » Logged
user112
-Given: 6
-Receive: 139
Salut tuturor(hello to all)
« Reply #43 on: September 13, 2007, 10:05:04 10:05 »
hallo you can use models for AT89C51/52  from Proteus it is not big difference read this
http://www.atmel.com/dyn/resources/prod_documents/doc3487.pdf
user112
-Given: 6
-Receive: 139
« Reply #44 on: September 13, 2007, 10:18:45 10:18 »
LM567 if you still need model http://www.sistemelektronik.com/yukle/dosya/egealtay/9D9_LM567.zip
ppa88
-Given: 49
-Receive: 131
« Reply #45 on: September 13, 2007, 07:02:07 19:02 »
Can anybody post a successful simulation example for this model of LM567? I have not been able to make it work as per the datasheet.
« Last Edit: September 13, 2007, 07:04:34 19:04 by ppa88 » Logged
Kova
-Given: 172
-Receive: 24
« Reply #46 on: September 14, 2007, 06:08:03 06:08 »
Quote!!!!
I have tried all configuration and all examples found on the net, for example:
http://www.reconnsworld.com/audio_tonedecode.html
(With C1= 0.022uF and R1= 100K to capture a tone of 413Hz)
OR
http://members.cox.net/rbirac3/Snuffy/tone_detect.htm
Output at pin 8 is always at 5V!  Cry Cry
I have posted also in the forum where the file is situated....here:
http://tinyurl.com/ywx6pu
(See page 5 and 6)
Bye
« Last Edit: September 14, 2007, 06:13:12 06:13 by Kova » Logged
user112
-Given: 6
-Receive: 139
« Reply #47 on: September 14, 2007, 07:26:21 07:26 »
I tried to simulate and d' ont work sorry I will search more informations for LM567
ppa88
-Given: 49
-Receive: 131
« Reply #48 on: September 14, 2007, 08:05:49 08:05 »
I have almost given up on this model. I think the dll is buggy as it takes a lot of processor resource with no appreciable results.
Kova
-Given: 172
-Receive: 24
« Reply #49 on: September 14, 2007, 10:01:08 10:01 »
Damn  Undecided Undecided
The LM567/NE567 is necessary for my project  Embarrassed Embarrassed
Pages: 1 [2] 3  All
