April 11, 2026, 08:56:45 20:56
Pages: 1 2 3 4 [5]
Author Topic: SPOT WELDER WITH PIC16F88 tested - YOUTUBE video  (Read 33230 times)
« Reply #100 on: April 21, 2010, 10:44:03 10:44 »
I have no answer, i didn't calculate anything too.
Just my feeling that it should not turn off too fast, as the very high welding current effected by stray inductance could kicking back to the mosfet destroying the body drain diode if the turn off is too fast.
How slow? Can it be too slow? Frankly, i do not know.
kalpakchiev
-Given: 34
-Receive: 68
« Reply #101 on: April 21, 2010, 10:59:42 10:59 »
I agree but we have to talk with dimensions - too slow or too fast sounds like the saying for comparing BIG ANT and SMALL ELEPHANT Grin.
I have no idea which way is better to turn it off fast or slow.
borberk
-Given: 309
-Receive: 598
« Reply #102 on: April 21, 2010, 12:16:34 12:16 »
100m capacitor charged on 30V and discharged through 0.07+rds/5 is practically empty in 30ms.
Troubles with voltage spikes vhich occur on weld start and end because of electrode inductance can be eliminated by diode in series with charge FET.
Rise and fall times on weld FET gates are not important.
kalpakchiev
-Given: 34
-Receive: 68
« Reply #103 on: April 21, 2010, 02:18:30 14:18 »
Yes I think that's right. In our case capacitor is 1F and voltage is 20V so we are talking for max. weld time about 200ms
titi
-Given: 4121
-Receive: 834
« Reply #104 on: April 21, 2010, 05:20:21 17:20 »
In the web site : http://www.ultrakeet.com/index.php?id=article&name=cdWelder_p2
The you-tube video show examples of weld, at 1:58 min they give time of weld of 0.1ms, 0.5ms, 1.5ms, 4.5ms, 9.5ms to weld (Nickel to Stainless).
If these times are really good, if you have not a very fast turn-off, it will be impossible to have these short times.
But it is possible that for your applications, that turn-off time become not important.
Best Regards.
waicon
-Given: 59
-Receive: 79
I'm learning to Dream...not Relaxing...zzZ
« Reply #105 on: April 22, 2010, 02:53:32 02:53 »
a) yes, R9 increase will couse turnoff timing increase.
b) Q6 will it replace with P-ch FET (small signal to92) type? as long as its -VGS is higer than VIN. or added 12v ziner.
c) ring effect on gate ? i'm not sure, it related to capacitive load effect. refer to link http://rapidshare.com/files/378642574/capacitive_loading.rar , but i think R1~R5 slightly increase turnoff timing.
d) a good weld spot, are determine by a good "intermatalic formation" in its spot by 2 metals, if less will couse loose or "dry-join", too much will properly couse a melted hole in it. a PWM pulse train might help on weld input.
sadman
-Given: 1985
-Receive: 3216
Sow The Seeds of Love
« Reply #106 on: April 23, 2010, 07:23:09 07:23 »
Hi Friend kalpakchiev
can i used uln2003 in place of tc4422 also what is total current of transformer you used for supply and charging purpose
sadman
kalpakchiev
-Given: 34
-Receive: 68
« Reply #107 on: April 23, 2010, 07:26:35 07:26 »
sadman
I am not sure You can replace tc4422 whit ULN2003, transformer is 16VAC 240W with 35A bridge rectifier
Best regards
-Receive: 4459
« Reply #108 on: April 23, 2010, 11:48:42 23:48 »
waicon said a PWM pulse train might help on weld input.
I think back to a DC welder I fixed a few years back its control was with two power Fets.
one had PWM on its gate and other was on/off
kalpakchiev
-Given: 34
-Receive: 68
« Reply #109 on: April 24, 2010, 07:06:10 07:06 »
Hi Pickit2, why there is an ON/OFF fet when turning PWM off, also turns the weld off?
How many ONs and OFFs in one post  Grin Grin Grin
Best regards
kalpakchiev
-Given: 34
-Receive: 68
« Reply #110 on: April 28, 2010, 07:17:10 07:17 »
LCD prepared for test  Cool
« Reply #111 on: April 28, 2010, 03:16:21 15:16 »
I am still waiting...  Wink
Can not find my old tab welder, searching for the caps i found a bag of 10000uF/35V, is that a crazy idea to parallel 100 of them making a capacitor farm?
sadman
-Given: 1985
-Receive: 3216
« Reply #112 on: April 29, 2010, 05:24:34 05:24 »
i found 47000uf used 24 in parallel to get the required value
kalpakchiev
-Given: 34
-Receive: 68
« Reply #113 on: April 29, 2010, 05:54:16 05:54 »
It is possible to parallel a few capacitors to reach desired value (make a cap. farm), but you must have in mind that this will increase internal resistance of the whole capacitor.
Best regards
« Reply #114 on: April 29, 2010, 06:24:57 06:24 »
Isn't paralleling capacitors will decrease the total ESR value?
kalpakchiev
-Given: 34
-Receive: 68
« Reply #115 on: April 29, 2010, 08:49:41 08:49 »
I think that all the connection between capacitors have to be added to internal resistance, so it will be increased. Am I wrong?
sadman
-Given: 1985
-Receive: 3216
« Reply #116 on: April 29, 2010, 12:03:35 12:03 »
if you have ESR meter just do a test for us that will help us as in my country 1F audio capacitor hard find, just check ESR of two 2200uf,cap then join both capacitor in parallel and measure ESR again that will clear every thing so we used alternative method, once again thanks for your corporation.
sadman
kalpakchiev
-Given: 34
-Receive: 68
« Reply #117 on: April 29, 2010, 02:24:09 14:24 »
Yes this test can be very useful, but unfortunately I have no ESR meter.
If some one in the forum have, please help Sadman.
Best regards and many thanks in advance for your kind cooperation.
Ivan Kalpakchiev
Fab66
-Given: 129
« Reply #118 on: May 01, 2010, 06:44:59 06:44 »
Hello kalpakchiev, all's
i am new here, i discovered this site and this project.
I follow it since a few day's, and i think that can be my
next electronic build.
Thank's for sharing, i search now the condensator on internet.
Do you think that best result will be with 2 condo in serie,
or one (with 1F) is enough to sold accus ?
Best regard's to all
Fabrice
kalpakchiev
-Given: 34
-Receive: 68
« Reply #119 on: June 07, 2010, 07:48:01 07:48 »
Hi Fab66,
Sorry for my late post but I was on a place where it is difficult to get connected to internet.
For me using one 1F capacitor gives good results. But it depends on what You are going to weld - type and thickness of the material.
Now I am back and will finish the project with all the final modifications that we discussed with other peoples in this forum.
I wish you success in your project.
Best regards,
Ivan Kalpakchiev.
Pages: 1 2 3 4 [5]
