Easypic add on board project - Sonsivri
May 13, 2026, 04:22:49 04:22
Author Topic: Easypic add on board project  (Read 4868 times)
-Given: 582
« on: March 26, 2010, 10:06:25 22:06 »
Recently I wanted to measure the voltage of one of my PSU�S, Normally I knock it up on Vero-board or try and throw it together only to give up half through due to the fact that I�m not 100% happy with the reading I obtain, Like not been accurate enough compared to my multi-meter or stable enough, I know it might be asking too much from a 10bit old pic,
I did think about adding a 12-24bit A/D converter chip but they add more cost�s to the project plus it�s writing the code (which is not a problem), I also thought about just adding a resistor divider but I thought by using an op-amp it act�s has a buffer which is better I think.
So I decided to design a add on board for the Easypic board to get it right, Looked through my junk box and found the LMC660 op-amp which is a single supply/ rail to tail so I thought that will do I simulated it in ISIS then moved to Altium for designing the PCB.  Because the op-amp is a quad type may as well make it do up to 4 channels.
I added a LM341 adjustable precision reference voltage to improve the reading but rather than have it fixed I made it variable either 2.50V or 4.096V. But after building the board up and played around with it I found that it made the reading worse, well this could be the way I coded it but I tried several methods and picked the best method and never use the LM341
This is all tested and working so I thought I will share it, It�s simple and straight forward to set up and calibrate, Feel free to pass any comments error�s or even post your code if you can get better reading using it or an easier way than mine
Here are some pictures of it working  and the project file that I threw together with sample code for one channel only
« Last Edit: March 27, 2010, 01:01:04 01:01 by Wizpic » Logged
-Given: 582
« Reply #1 on: March 27, 2010, 01:02:12 01:02 »
Here is the book with all the stuff required to build
« Reply #2 on: March 27, 2010, 05:05:47 17:05 »
Nice one wizpic. I was talking to bbarney about the ADC and voltage measurement. He pointed me out to a nice topic you might want to try out:
http://digital-diy.com/handy-tips/148-adc-calibration.html
This might help you get better results from the existing circuit.
-Given: 582
« Reply #3 on: March 27, 2010, 06:20:33 18:20 »
I shall have a look at that, I only used the sample code just to show, The readings I get are very stable and accurate. Has it is without using V-Ref. But more ways the better
Glad you like it. It's nice to get some feed back
