April 11, 2026, 08:56:03 20:56
Author Topic: Microcode Serial Communicator Problem!  (Read 10019 times)
engr.humair
« on: March 09, 2010, 05:14:59 17:14 »
Dear:
I am trying to interface NokiaGSM 6100 cell with PIC16F877A @ 9600bps.
Problem: Nokia6100 responds OK on AT in Hyperterminal but is not giving any response in Microcode Serial Communicator. Serial Communicator COM, Baudrate,Parity, Bytesize & Stop bits settings are same of that to Hyperterminal Program.
Is there any other settings i need to do? Need ur expert advise?
Thanks in advance.
« Last Edit: March 09, 2010, 07:23:01 19:23 by engr.humair » Logged
king
-Receive: 21
Jack of All But Master of One
« Reply #1 on: March 10, 2010, 11:58:35 11:58 »
If you have done the same settings on serial comunicator then it should work, but i think the difference is that in serial comunicator you have to place Enter Key to transmit data while in hyperterminal data transmits without placing enter key so check your serial communicator again by unchecking "Transmit  on Carriage return" option.Also give us your feedback
falcon _bd
-Given: 66
-Receive: 117
falconbd.com
« Reply #2 on: March 10, 2010, 09:51:37 21:51 »
Check the flow control settings
engr.humair
« Reply #3 on: March 11, 2010, 04:18:41 04:18 »
Thanks falcon_bd for your response.
Can you please guide me how i can change flow control settings in Microcode Serial Communicator. I am unable to locate it Sad
Waiting for your reply.
Thanks in advance
falcon _bd
-Given: 66
-Receive: 117
falconbd.com
« Reply #4 on: March 13, 2010, 07:20:42 07:20 »
I think there is no option to settings the flow control. You can used the DOCKLIGHT as serial communicator.
Search in sonsivri for  docklight.
SpaleKG
-Given: 19
« Reply #5 on: April 04, 2010, 03:00:01 15:00 »
I think that you need to use nokia F-bus in your PIC device too. So you can find how to make it with rs232 too.
F-bus uses 2 wires for communication. Otherwise if you are use same HW for communication with your nokia (PC to nokia and PIC to nokia)
then you need to be sure that you sending CL/RF to nokia after AT commands. CL/RF is $20 ascii code.
« Last Edit: April 04, 2010, 03:06:38 15:06 by SpaleKG » Logged
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #6 on: April 04, 2010, 03:43:50 15:43 »
... you need to be sure that you sending CL/RF to nokia after AT commands. CL/RF is $20 ascii code.
ASCII $20 is a space.
Is this "CL/RF" you refer to perhaps correctly known as CR/LF?
Carriage Return plus Line Feed.  ASCII characters $0D and $0A  ?
Here's an ASCII table in case you need one.
http://www.cs.utk.edu/~pham/ascii_table.jpg
SpaleKG
-Given: 19
« Reply #7 on: April 05, 2010, 01:15:32 13:15 »
Yes it is, I mean CR/LF (sorry for typo because I was sleepy). Also about codes, you are right it is $0D $0A
BTW I will find PHP solution which I made few years ago for using to communicate with Benq GSM/GPRS module via RS232.
I discovered similar problems about end lines, so I will find code today.
Posted on: April 05, 2010, 01:36:39 13:36 - Automerged
Posted on: April 05, 2010, 02:13:29 14:13 - Automerged
]Ok, I find it. In my situation I communicate with device via telnet.
<?php
require_once "PHPBenq.php";
//ob_implicit_flush();
$comm = new PHPBenq();
$result $comm->Connect();
 if (
$result == 0) {
$comm->DoCommand('module1\n',$result);
// NOTE: $result may contain newlines
echo $result;
//sleep(5);
$comm->DoCommand('ATE0'.chr(0x13),$result); // NOTE 1
echo $result;
//$test = array();
$comm->DoCommand1('AT+CMGL=4'.chr(0x13),$result);   // NOTE 1
$ress explode("\n",$result);
print_r($ress);
echo
$result;
sleep(3);
$comm->DoCommand('07917373499910F101000B917373096000F800100B7378985D0699D9E1391A'.chr(0x1A).chr(0x1B),$result); // NOTE 2
sleep(10);
echo
$result;
$comm->DoCommand('^X'$result);
echo
$result;
sleep(3);
$comm->DoCommand('logout'$result);
echo
$result;
// say Disconnect(0); to break the connection without explicitly logging out
$comm->Disconnect();
Explain notes from code:
NOTE 1 - for ENTER I am sending $13 to device
NOTE 2 - in some cases when device expecting DATA it need to receive SUBSTITUTE ESCAPE  ($1A $1B) as end of data. In my case after AT commands which says to device that next data will be SMS message, then device need to know when you are finished with SMS message.
So you can try to send $13 (ENTER) at the end of line, or CR/LF (mentioned before) or escape sequence ($1A $1B).
Let me know in what case it works Smiley
Regards.
« Last Edit: January 09, 2012, 02:11:42 14:11 by SpaleKG » Logged
king
-Receive: 21
« Reply #8 on: July 13, 2010, 07:06:22 19:06 »
Dear Humair
From where you buy 6100 cable also tell me either it is Serial cable or USB cable and if you have any kind of schematic to interface it with Computer or with PIC-Micro-controller then please provide us
