PilotPTK
-Receive: 23
« on: November 30, 2009, 10:37:18 10:37 » |
I have a need to transmit data between micro controllers via a wireless solution. Normally, I would pick one of the off the shelf products and go on my way with it, but in this case, my needs are more unique. I need EXTREMELY long-range (appx. 50 MILES), but I can live with VERY slow speeds.. 10bps would be just fine. The antenna can't be all that large either  The devices have to communicate with a base-station which CAN have a very large/tall antenna - but LOS is out of the question. Any recommendations? even possible? or am I stuck with using CDMA/GSM modems in these devices.
ALLPIC
-Receive: 72
« Reply #1 on: November 30, 2009, 10:47:14 10:47 » |
CDMA/GSM is much reliable for long distance. Or else you have to form network of zigbee or WiFi (repeater like) so that there will be less possibility of missing data
LabVIEWguru
-Given: 276
-Receive: 593
« Reply #2 on: November 30, 2009, 12:17:58 12:17 » |
How about storing your data, then once or twice a day have a cellular phone call the base and upload the data at high speed? (Long range = high power+good antenna)
I used to live in a city where remote water flowmeters would sample once or twice a minute, then at night call a computer via cellular and upload all the data. Everything was located underground, accessible by a manhole except for the antenna.
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #3 on: November 30, 2009, 01:28:11 13:28 » |
IFF line of sight is possible, WIFI + a couple of sattellite dishes could possibly move the data. Ideas available here: http://www.engadget.com/2005/11/15/how-to-build-a-wifi-biquad-dish-antenna/If it is not a commercial project, amateur radio packet radio could be applied. Possibly even a few nodes already in place you could move your traffic through. TAPR has tons of resources: http://www.tapr.org/Phone line and a pair of modems might be most reliable way to go.
TomJackson69
-Receive: 63
« Reply #4 on: December 13, 2009, 11:21:15 11:21 » |
Use phone line and a pair of PIC use DTMF to send and receive data. It is possible and low cost. I designed and used in 2000. I don't know if I can find the project because I have been move several times. If I can find it, I will post.
Tom
« Last Edit: December 13, 2009, 11:23:23 11:23 by TomJackson69 »
Con Rong Chau Tien
Jeckson
-Given: 54
« Reply #5 on: December 13, 2009, 06:58:23 18:58 » |
Hai
Use hf,Vhf,uhf transmission. Cause the frecuencies mean cost. With frs/gmrs radio that works in free frecuencies allocation.
Cb also an option in USA(hf).
regards Jeckson
PilotPTK
-Receive: 23
« Reply #6 on: December 14, 2009, 09:01:50 09:01 » |
Thank you all for the replies. I appreciate your help.
Although the cost is substantial, I have decided to go the GSM/CDMA Modem route. I've found a provider that gives 1MB per Month for $8 per month per card. I have to monitor about 50 different locations - meaning roughly $400 per month in access costs.
If anyone is aware of a provider (GSM or CDMA) who gives >250kB per month for less than $8, that info would be helpful.
Thanks! PPtk
ALLPIC
-Receive: 72
« Reply #7 on: December 14, 2009, 09:06:38 09:06 » |
if you are going to continually monitoring the data on CDMA or GSM then you have to communicate with provider to get fix IP so that your work will be more easy otherwise your GPRS connection is going to be very very bad. I face this problem then I had words with provider he given me fix ip range of 10 then my unite start working. Yap this is very personal experience.
PilotPTK
-Receive: 23
« Reply #8 on: December 14, 2009, 11:02:47 11:02 » |
Why would each gprs device need a static IP? I see no reason why they could not be dynamic and communicate to a fixed IP at my office. I don't need to poll them - they simply need to be able to send data to me.
PPtk
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #9 on: December 14, 2009, 11:55:10 23:55 » |
I need EXTREMELY long-range (appx. 50 MILES)  50 miles is nothing to HF ham radio. This would be using 'ground wave' mode. Home brew transmitters are cheap to build or you can buy a kit. As for data modulation and format, take your pick: RTTY, Morse code, DominoEx, PSK31, DTMF, etc. It's all been done before hundreds of times over.Why is it the younger generation is so ignorant of the experience of the older generations? $400/month
« Reply #10 on: December 15, 2009, 12:46:36 00:46 » |
I had a quiet similar needs, i am thinking about web based monitoring via ftp, http, or even email where the remote station send data to web service maintained from the base station - static ip is not required. All is still in concept now, i already bought Simcom SIM548 GSM/GPRS + GPS modem for this purpose. How will the weight and urgency of the data will be? If it is light then i think RF is still a good choice, $400 is not small amount of money - for me at least. Mine is quiet heavy on data and the price of the GPRS service here is far below yours, 125MB for about $5 per month. I am still doing research for this thing, that is why i asked for a book: http://www.sonsivri.com/forum/index.php?topic=26345.0-ichan
-Given: 499
« Reply #11 on: December 15, 2009, 04:20:32 04:20 » |
+1 with the ferret's suggestion on using HAM type radio. You only got to pay for the setup and there would be no monthly fees afterwards.
Jeckson
-Given: 54
« Reply #12 on: December 15, 2009, 06:32:20 18:32 » |
Hai PILOTPTK
First only 10 bps....that's the advantages..
Consider your frecuencies rules at your location....
There's numberous free frecuencies and lot of kits that offered that range..with 300 m or more. Added more gain antennas for that. Like 43X-44X Mhz.
If lived at USA.I think that CB=Citizen band(11 meter band) is free.Just register and no Exam(+cost)
Must be aware for frecuencies rules...
Regards Jeckson
PilotPTK
-Receive: 23
« Reply #14 on: December 23, 2009, 01:05:23 13:05 » |
I'm very well aware of the distances that HAM type radio has achieved, and personally, I've used PSK31 to communicate for a darn long way. My reason for not really considering this is that it is a commercial application, which tends to be frowned upon by the HAM community - and the person technically 'operating' the remote units will A) Not have a AR license and B) be using it for commercial purposes. Are their HF bands that are both free and available to commercial applications?  50 miles is nothing to HF ham radio. This would be using 'ground wave' mode. Home brew transmitters are cheap to build or you can buy a kit. As for data modulation and format, take your pick: RTTY, Morse code, DominoEx, PSK31, DTMF, etc. It's all been done before hundreds of times over.Why is it the younger generation is so ignorant of the experience of the older generations? $400/month
FriskyFerret
-Given: 513
-Receive: 360
« Reply #15 on: December 23, 2009, 02:08:18 14:08 » |
What country would the system operate in, PilotPTK?
PilotPTK
-Receive: 23
« Reply #16 on: December 23, 2009, 06:28:06 18:28 » |
USA
Jeckson
-Given: 54
« Reply #17 on: December 28, 2009, 08:52:40 20:52 » |
huh link very slow...
Use CB.There's numberous kits and circuits It's just registered.
there's also free like 4XX Mhz but need amplify for 50 miles.
CB is the best..
Regards Jeckson
manish12
-Given: 44
-Receive: 39
« Reply #18 on: January 16, 2010, 08:19:57 20:19 » |
a good quality+long range waki-tokies ,along with dtmf + good height antenna is the best idea to go for , and it will be cheapest also.
if you cascade the w-t unit you can create repeater for desired range .
the idea is practical to implement
« Last Edit: January 16, 2010, 08:22:18 20:22 by manish12 »
PilotPTK
-Receive: 23
« Reply #19 on: January 24, 2010, 04:33:27 04:33 » |
CB is the best..
Regards Jeckson
Jeckson, Can you point me to any of these circuits or kits? I'm quite interested in your CB idea, but I'm not having much luck finding anything on sonsivri or google. Thanks! PPtk
oldvan
-Receive: 107
« Reply #20 on: January 24, 2010, 12:35:47 12:35 » |
CB: Amplitude modulation, loaded with interference, legal only for voice communication, typically good to about 3 or 4 miles. For 27 MHz, antennas are not small. http://wireless.fcc.gov/services/index.htm?job=service_home&id=cbCitizens Band (CB) Radio Service is a private two-way voice communication service for use in personal and business activities of the general public. Its communications range is from one to five miles.
Jeckson
-Given: 54
« Reply #21 on: February 04, 2010, 06:55:28 06:55 » |
Hai
>Jeckson,
>Can you point me to any of these circuits or kits? I'm quite interested in your CB idea, but I'm >not having much luck finding anything on sonsivri or google.
>Thanks! >PPtk
Just search at CB frecuencies 27-28-29 MHz kit.If I'm not wrong even old handy talky(used at WW II).
Or also could used R/C frecuencies(50 Mhz) but in USA are illegal for more power?
oldvan
-Receive: 107
« Reply #22 on: February 04, 2010, 05:56:35 17:56 » |
50-54 MHz is a HAM band, license required.
Jeckson
-Given: 54
« Reply #23 on: February 10, 2010, 07:41:55 07:41 » |
OK 50-54 MHz is licence...
CB band is the way
Regards Jeckson
oldvan
-Receive: 107
« Reply #24 on: February 10, 2010, 10:47:49 10:47 » |
CB band is the way  It seems like you missed a critical detail: CB is legal only for voice communication. I suppose one COULD use a synthetic or recorded voice to transmit the data and voice recognition to receive the data, but that would be silly.
