April 12, 2026, 12:44:41 00:44
Author Topic: watchdog issue on AVR  (Read 5139 times)
sphinx
Online Online
-Given: 683
-Receive: 385
« on: October 26, 2009, 07:58:18 19:58 »
hey all
i made a program in assembler trying to figure out what i am doing wrong since watchdog wont work
i just made a very simple program to set a led on portb1 and then when watchdog cuts in it should
clear the same port and go to sleep.
i tried it with both oshonsoft and proteus and its not working
is there anyone that can help out on this
best regards
p.s. i dont have any hardware to test sadly
jestanoff
« Reply #1 on: October 27, 2009, 08:56:19 20:56 »
Try with code which I edited. I have not tested it, but I guess it will work. Atmel Watchdog is setting very strange, but once setup works flawlessly. In my projects I used it only to reset MCU, not for interrupt. If you replace the bit WDTIE with WDE will get my working code. Good approach for work is to have hardware to test.
