You think I am funny guy huh?
March 07, 2026, 05:35:15 05:35
Author Topic: Modified Explorer 16 Development Board  (Read 9164 times)
sohel
-Given: 169
-Receive: 149
« on: October 15, 2009, 11:52:29 11:52 »
any one try this ? its true for pickit2/3 ICSP header  marked pin 1 is actually pin 6
http://www.paintyourdragon.com/uc/explorer16/index.html
here result
Initializing PICkit 2 version 0.0.3.63
Found PICkit 2 - Operating System Version 2.100.7
PICkit 2 Unit ID = Explorer 16
Target power detected ( 3.24V)
PIC24FJ64GA004 found (Rev 0x3003)
PICkit 2 Ready
Resetting
Programming Target (10/15/2009  5:17:16 PM)
Erasing Target
Programming Program Memory (0x0 - 0x1A7F)
   (Using Programming Executive)
Verifying Program Memory (0x0 - 0x1A7F)
Programming Debug Executive (0x-800100 - 0x800400)
Verifying Debug Executive (0x800100 - 0x800400)
Programming Debug Vector
Verifying Debug Vector
Programming Configuration Memory
Verifying Configuration Memory
PK2Error0028:  Unable to enter debug mode
NOTE: Check that the ICS (Comm Channel Select) Config bits are set to the PGxn/EMUxn port PICkit 2 is connected to.
PICkit 2 Ready
Running Target
PICkit 2 Ready
« Last Edit: October 15, 2009, 12:24:54 12:24 by sohel » Logged
MisterX
-Given: 168
-Receive: 24
« Reply #1 on: October 15, 2009, 06:08:31 18:08 »
Hello sohel
I actually use this firmware and everything is working fine for me.
Here are my results:
PIC24FJ128GA010 found (Rev 0x3002)
PICkit 2 Ready
Resetting
Programming Target (2009-10-15  12:52:11)
Erasing Target
Programming Program Memory (0x0 - 0x19FF)
Verifying Program Memory (0x0 - 0x19FF)
Debug mode entered, DE Version = 1.0.8
PICkit 2 Ready
Resetting
PICkit 2 Ready
Running Target
PICkit 2 Ready
Stepping Target
PICkit 2 Ready
Target Halted
Running Target
PICkit 2 Ready
And Yes the silkscreen on the Explorer16 says pin1 is on the top side of the board but it's not true.
I use a 90 degres 6 pins headers and there no way to put the programmer in the wrong side.
But with this firmware you only need to use a "real PICkit2" for programming the bootloader the first time.
The onboard PIC18LF4550 is after seen like a PICkit2 and you can use it like a normal PICkit2.
Hope this can be helpfull.
Edit : I did not try with a PIC24FJ64GA004, I have a Explorer16 100-pins. Maybe there are differences between the 2 development boards.
« Last Edit: October 15, 2009, 06:12:04 18:12 by MisterX » Logged
-Given: 858
-Receive: 4451
« Reply #2 on: November 21, 2010, 09:31:25 21:31 »
This needs a boost, I just found a Explorer-16 in works stores along with a few PIMs
Hard part is migrating to Mikro-Basic for dsPic. don't you just hate not having a full Hello World sample program.
I can only drive leds D3 to D6, can't get to D7 to D10 yet. Sad
added a list of what ports are doing, this is on going.
krish2487
-Receive: 25
« Reply #3 on: November 28, 2010, 11:55:37 11:55 »
i can vouch for that...
it works properly.
I just followed the instruction step-by-step and it works fine for me.
i remember that Pickit2 has a couple of quirks like this which were smoothened out in the later release.
something to do with unable to program and the pickit 2 not being recognised.
There are two versions of pickit 2
one that comes with a black button for reset and the later one with red button.
the red one works fine .
PS: I faced this problem and contacted microchip.
they sent me a replacement and the red one works fine with my explorer 16 board.
Dint try it with the black version
-Given: 858
-Receive: 4451
« Reply #4 on: November 28, 2010, 01:46:30 13:46 »
You still using a pickit2 to program the Explorer-16?
I use the onboard 4550 and moded pickit2.exe
MisterX
-Given: 168
-Receive: 24
« Reply #5 on: November 28, 2010, 03:15:05 15:15 »
Hi pickit2 if you cannot control leds 7 to 10 it's only because the JTAG port is enable in your config fuses.
Have a look at Lucio Di Jasio's website FAQ #1
http://www.flyingpic24.com/4.html
-Given: 858
-Receive: 4451
« Reply #6 on: November 28, 2010, 03:22:48 15:22 »
Thanks for the link but Jtag was not the problem..  (When enabled, the JTAG port takes control of 4 pins of PORTA (RA5, RA4, RA1, RA0)
I could not control leds on RA5 to RA10, It was A config error, problem was, I had no Hello World, to get me started.
krish2487
-Receive: 25
« Reply #7 on: November 28, 2010, 04:19:08 16:19 »
@pickit2
that was before i modded it
now it works fine in the way you suggested....
for that matter
explorer 16 is only a proof-of-concept tool
most of the projects happen outside it/without it..
:-D
