kang2008
« on: September 19, 2009, 12:30:58 00:30 » |
hi?
i need pulse multiplier schematic (2048pulse * 64 = 131072pulse) ?
who? help me?
thank you
jestanoff
-Given: 25
« Reply #1 on: September 22, 2009, 04:25:40 16:25 » |
What do you mean pulse multiplier. Perhaps each input pulse to generate a number of output pulses or anything else. Could you add more explanation and what it will be used. With the numbers that you wrote it seems to me it was a memory.
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #2 on: September 22, 2009, 05:25:15 17:25 » |
Phase Locked Loop perhaps? Routinely done for RF circuits.
What frequency are these pulses arriving at?
Give a man a fish and you feed him for a day. Teach a man to fish and he will sit around in a boat drinking beer all day.
kang2008
« Reply #3 on: September 23, 2009, 09:39:39 09:39 » |
use ac motor driver(pluse)
jestanoff
-Given: 25
« Reply #4 on: September 23, 2009, 04:47:26 16:47 » |
Nobody guess. This project is like one equation with five unknown.
« Reply #5 on: September 26, 2009, 04:25:49 16:25 » |
If the input frequency is not too high, not in MHz range, then you can use a microcontroller to do that.
1. Measure the periode T between two input pulse. 2. Output n number of pulses with T/n periode. (n = 64 for your case). 3. Back to 1
This approach will lag 1 pulse stream, but with PLL there will be more pulse lag before the system locked.
wedo
-Given: 10
-Receive: 51
« Reply #6 on: September 26, 2009, 06:37:52 18:37 » |
There are two methods to achieve multiplier circuit:
1- Get the pulses using MCU counter pin and multiply the count number by 64. 2- Use multiplier IC like: AD534, AD632, etc…
By the way, are you looking for analog or digital multiplier?
Give us more details so that we can help you.
You are welcome.
samir
-Given: 27
-Receive: 21
« Reply #7 on: September 27, 2009, 03:54:05 15:54 » |
hi?
who? help me?
thank you
as oldvan said,it is called as phase locked loop http://www.national.com/ds/LM/LM565.pdfas far as i know it is the only thing that can have output freq in multiple of input.only thing you may be concern about pll response time and have to tune it according.
samud
« Reply #8 on: October 01, 2009, 04:44:00 04:44 » |
do u have any other circuit for this
SONSiVRi
Administrator
-Given: 75
-Receive: 405
« Reply #9 on: October 01, 2009, 07:51:08 07:51 » |
User is gone, he can't answer your questions. Because we told him to follow the rules, he doesn't followed on purpose again and again.
- Houston, we have a problem.
« Reply #10 on: October 02, 2009, 10:23:24 10:23 » |
Topic will be locked
