April 29, 2026, 02:10:19 14:10
Author Topic: HOW TO GET PROGRAM FROM LOCK ATTINY2313  (Read 11562 times)
tango
-Given: 28
« on: September 06, 2009, 09:00:33 09:00 »
Can someone post som example or link HOW TO ?
I need to read locked ATTINY2313.
Best regards to all.
gem1144aaa
-Given: 134
-Receive: 27
« Reply #1 on: September 06, 2009, 02:31:57 14:31 »
Hi tango
forget it .
find this link first then decide
http://www.sonsivri.com/forum/index.php?topic=2815.0
jestanoff
« Reply #2 on: September 22, 2009, 06:21:21 18:21 »
In older Atmel microcontrollers had a chance to read the contents by reducing the voltage of the microcontroller, but the release of avr series I think this bug is resolved.
chinninitin
-Given: 155
-Receive: 38
« Reply #3 on: November 03, 2009, 05:54:46 17:54 »
Friends,
Instead of posting for help here and trying and wasting time,,  one can write code in 50% of this time :-)
Try atleast ;-)
Chinni
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #4 on: November 03, 2009, 07:55:13 19:55 »
There is a way but it's very very very complicated.
First you have to buy some chemicals (strong acids and methyl alcohol). Then you need precision mechanics tools, a Oscilloscope,a good Logicanalyser and a very good microscope.
After you got everything view this YouTube video: http://www.youtube.com/watch?v=tnY7UVyaFiQ
Nearly the same way you'll get the data out of the ATtiny2313.
If I get some other method's I'll post it here.
« Last Edit: November 04, 2009, 05:27:24 17:27 by DarkClover » Logged
DarkClover
-Given: 37
-Receive: 60
Still alive...
« Reply #5 on: November 04, 2009, 05:28:23 17:28 »
Another method:
Use the Logic analyser from method 1 to monitor and log the pins from
the ATtiny2313. Maybe with that you can reverse engineer the code.
cncbasher
-Given: 107
-Receive: 51
« Reply #6 on: November 04, 2009, 06:24:25 18:24 »
unless you have $$$$$$$$$ , or a university's budget  don't even try . there again if you did you would not need to reverse engineer the code
many chips have protection and code encryption built in , and poking the chip will infact deliberately destroy it , microchip did in the early days have a poor fab plant which allowed a few tricks to be used to open the fuse bank and allow the code to be read , but these day's they are an order of a few magnitude more secure , companys are demanding more security to their IP rights .
many companys now rather than code the chip themselves , have the fab plant build and program the chip before delivery , and is part of the master chip
and in this case cannot be read out .
