C++ Compiler for PIC - Sonsivri
May 13, 2026, 03:36:34 03:36
Author Topic: C++ Compiler for PIC  (Read 9408 times)
ALLPIC
-Receive: 72
« on: June 29, 2009, 07:41:18 19:41 »
Dear ALL
Is there any one have information regarding C++ Compiler for PIC microcontroller. I used all C compiler now I would like to see C++ compiler, like Boost C++ compiler. But Boost C has problem with floating point
I see IAR might haveing C++ Compiler but I am not able to find good crack for IAR PIC compiler.
regards and thanks in advance
dvbguy
-Given: 8
« Reply #1 on: July 01, 2009, 10:36:03 10:36 »
There is a reason why it is hard to find C++ for embedded systems.. The overhead cost is too high.. Even on compilers that support C++ its usually a scalled down version.. Most programmers that I know that use compilers that support C++, still only use them as C compilers..
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #2 on: July 01, 2009, 01:18:54 13:18 »
Hard to search on here for    C++    but there was a thread recently on the topic:
http://www.sonsivri.com/forum/index.php?topic=14112
