April 20, 2026, 10:18:54 22:18
Author Topic: Problem with ucos-ii OSTimeDlyHMSM() function.  (Read 7157 times)
30f4011
-Given: 778
-Receive: 96
« on: June 23, 2009, 03:27:12 15:27 »
Hi friends,
            I am developing small application with ucos-ii v2.86 and OLIMEX STRE-912 board with IAR EW-ARM v5.30 . In code when OSTimeDlyHMSM() function is encountered the task is halted permanently and execution freezes.
           It works with small delays e.g OSTimeDlyHMSM(0, 0, 0, 5 ) but not with normal ones e.g OSTimeDlyHMSM(0, 0, 1, 30 );
OS timer tick is set to 100 ticks per second.
          Program works properly if OSTimeDlyHMSM() is removed.
           Please help me to solve this problem Embarrassed Embarrassed
the application code is as under,
uC/OS-II
Filename      : app.c
Version       : V1.00
#include <includes.h>
*                                               LOCAL DEFINES
*                                             LOCAL DATA TYPES
typedef struct graphics
               unsigned char x1;
               unsigned char y1;
               unsigned char x2;
               unsigned char y2;
               unsigned char color;
              }lcdgraphics;
//struct graphics lcdgraphics;
*                                                VARIABLES
OS_STK   Task_Serial_TX_STK[Task_COM_STK];
OS_STK   TASK_LCDD_STK[Task_LCD_STK];
OS_EVENT *mb;
OS_EVENT *clr;
OS_EVENT *lcdq;
void *lcdptr[4];
*                                            FUNCTION PROTOTYPES
void Task_Serial_TX( void *pdata );
void Task_LCD( void *pdata );
*                                                main()
* Description : This is the standard entry point for C code.  It is assumed that your code will call
*               main() once you have performed all necessary initialization.
* Argument(s) : none.
* Return(s)   : none.
* Caller(s)   : This is the standard entry point for C code.
* Note(s)     : none.
void   main   ( void )
 BSP_IntDisAll();           /* Disable all interrupts until we are ready to accept them */
 BSP_Init();                /* Initialize system's BSP */
 OSInit();                  /* Initialize "uC/OS-II, The Real-Time Kernel" */
 mb   = OSMboxCreate( (void *)0 );
 clr  = OSMboxCreate( (void *)0 );
 lcdq = OSQCreate( &lcdptr[0], 4);
 OSTaskCreate( Task_Serial_TX, ( void * )0,  &Task_Serial_TX_STK[Task_COM_STK -1], Task_COM_PRIO ); // task prio = 2
 OSTaskCreate( Task_LCD, ( void *)0, &TASK_LCDD_STK[Task_LCD_STK-1], Task_LCD_PRIO ); // task prio = 1
 OSStart();                 /* Start multitasking (i.e. give control to uC/OS-II) */
*                                                Task_Serial_TX()
* Description :
* Return(s)   : none.
* Caller(s)   :
* Note(s)     : none
void Task_Serial_TX ( void *pdata )
  unsigned char err;
  lcdgraphics rectangle;
  rectangle.color = 0;
  rectangle.x2 = 0;
  rectangle.y2 = 0;
  rectangle.x1 = 0;
  rectangle.y1 = 0;
  pdata = pdata;
  while( 1 )
   rectangle.x1 += 2;
   rectangle.y1  = rectangle.x1;
   if( rectangle.x1 > 130 )
     rectangle.x1 = 0 ;
     LCDClearScreen();
    if( rectangle.color++ > 10 )
      { rectangle.color = 0; }
   if( rectangle.y2 > 130)
   { rectangle.y2 = 0;}
   UartSendStr( " PASSED " ); // sends data to uart
   OSQPost( lcdq, (void *)&rectangle);
*                                                Task_LCD()
* Description :
* Return(s)   : none.
* Caller(s)   :
* Note(s)     : none
void Task_LCD ( void *pdata )
  unsigned char err;
  int TempColor[11] =
                    { WHITE, BLACK, RED, GREEN, BLUE, CYAN, MAGENTA,
             YELLOW, BROWN, ORANGE, PINK };
  lcdgraphics *rectangle;
  pdata = pdata;
  while( 1 )
     rectangle = (lcdgraphics *)OSQPend( lcdq, 0, &err );
     OSTimeDlyHMSM(0, 0, 0, 50);
     LCDSetRect(rectangle->x1, rectangle->y1,
                      rectangle->x2, rectangle->y2,
                      FILL, TempColor[ rectangle->color] );
//   WARM REGARDS
// YOUR HELP WILL BE GREATLY APPRECIATED
« Last Edit: June 23, 2009, 03:39:03 15:39 by 30f4011 » Logged
