May 26, 2025, 12:16:51 00:16
Pages: [1] 2 3  All
Author Topic: Mastercam x7 & Mastercam x8 for SolidWorks - All posts, all Versions  (Read 208692 times)
jesse
-Receive: 101
« on: June 05, 2009, 07:59:37 19:59 »
This topic is
Mastercam x7
and
         Saludos
« Last Edit: August 25, 2014, 11:14:55 23:14 by pickit2 » Logged
pjve64
« Reply #1 on: July 07, 2009, 09:25:01 21:25 »
I went and tried some different combinations as the problem obviously had to do with the HASP drivers.
This was done on a Windows XP servicepack 2 system, I have no access to a Vista system
Below is the readme.txt file with the additions I made (at the bottom)
1) Install Mastercam X4, select Sim Type > NetHASP
2)  Run "mastercam_x4_nethasp_crk.exe", browse to <mastercam X4 progdir\mastercam.exe> click Start > OK
3) If you have got Mastercam X3 installed as Sim Type > HASP you need to delete old dump from Windows Registry!
Delete Registry Entry
 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\NEWHASP\Services\Emulator\HASP\Dump\584B4AE9]
4) Run "mastercam-dealer-unlim.reg" to use Mastercam with Delear type of license or "mastercam-industrial-unlim.reg" to use it with Industrial  type of license
   I selected:"mastercam-industrial-unlim.reg"
5) If you have "USB-Emulator" already installed just restart (or reboot a computer) it so it can read a new dump
6) If you have no USB-Emulator installed you need to install it. For more infor see "USB-Emul Win32 Setup" or "USB-Emul Win64 Setup" next
That's all.. Enjoy Smiley
__________________________________________________________________
1) Open folder "USB-Emul_Win32" and run "install.bat"
2) Wait until system will find and install new devices
You need a local Administrator rights to install this emulator for Win64!
1) Start ->       Control Panel -> Add Hardware (Yes, I have already connected the hardware) -> Add a new hardware device -> Install the hardware that I manually select from a list -> Show all Devices -> Have disk -> Browse -> (browse to folder "USB-Emul_Win64")
Confirm to install not certificated drivers if Windows ask for..
2) If setup is succesfull you have to see new system device
Device Manager -> System devices -> Virtual Usb Bus Enumerator
3) Reboot!!!
Now you still may end up with the NO SIM message
Below worked for me on a Windows XP servicepack 2 system
- From the created entry "MasterCam X4" in "Programs" run Hasp Setup
- Then select: NHasp X
   When the NHasp X screen appears select: NetHASP and Local
   Select Read (and you will see the entries filled).
- Now you can start mastercam (This worked for me)   Smiley
marty.markoh
-Given: 192
-Receive: 433
Everything must B explored!Remember what U see!
« Reply #2 on: July 30, 2009, 09:25:16 09:25 »
Someone have NoPE's crack for MasterCam x4 samplefiles?Please share...TIA
 Smiley
Btw. crack from  http://rapidshare.com/files/247620591/Fixed_Crack.rar
isn't NoPE's crac-where come from?
« Last Edit: July 30, 2009, 09:52:26 09:52 by marty.markoh » Logged
milenjs
« Reply #3 on: August 04, 2009, 07:42:16 07:42 »
I test and this procedure solve my "No SIM" problem Smiley Now I have working Mastercam x4.
jesse
-Receive: 101
« Reply #4 on: August 06, 2009, 06:05:52 18:05 »
   Download from:
   http://www.cimco-hsm.com/index.php?page=download
   Crack:
   http://www.filefactory.com/file/ah0a98h/n/hsm_v3_x_v4_x_for_mcx4_crack_rar
   Saludos
sgoum
-Given: 94
-Receive: 68
« Reply #5 on: May 03, 2010, 05:51:15 05:51 »
http://rapidshare.com/files/380594416/MSTRCMX5FSLDWRKSISO-LZ.part1.rar
http://rapidshare.com/files/380594335/MSTRCMX5FSLDWRKSISO-LZ.part2.rar
http://rapidshare.com/files/380594194/MSTRCMX5FSLDWRKSISO-LZ.part3.rar
This is
MASTERCAM X5 FOR SOLIDWORKS
Password: http://avaxhome.ws/blogs/avaxklan    not link but password
Posted on: May 02, 2010, 08:24:43 20:24 - Automerged
The link IS the Password
http://rapidshare.com/files/379968167/mcam_x5_for_sw_v14.0.10.21.part1.rar.html
http://rapidshare.com/files/379968268/mcam_x5_for_sw_v14.0.10.21.part2.rar.html
http://rapidshare.com/files/379969883/mcam_x5_for_sw_v14.0.10.21.part3.rar.html
Links without password
EDIT: we don't code links
« Last Edit: May 03, 2010, 02:16:52 14:16 by pickit2 » Logged
Redhouse
-Given: 90
-Receive: 8
« Reply #6 on: May 03, 2010, 02:08:20 14:08 »
Sorry I misunderstood, yes that unpacked the ISO...THX... I'll see if I can get ahold of SW.
If anyone could post the stand alone (non plug-in) version it would be much appreciated.
« Last Edit: May 03, 2010, 02:23:27 14:23 by pickit2 » Logged
jesse
-Receive: 101
« Reply #7 on: May 04, 2010, 04:20:15 04:20 »
        Here's the emulator for Mastercam X4 MU3, the SW can be DL from their website.
        http://www.filefactory.com/file/b1765gf/n/mc_x2-x4mu3_win32_win64_nethasp_crack.rar
        Saludos
Posted on: May 03, 2010, 11:06:31 23:06 - Automerged
Jesse, do I run the stuff from this RAR before or after running mastercamx4-mu3-web.exe?
(before or after installing MC)
  Hi Redhouse
The RAR contains just the emulator, follow this steps to install:
1  Install Mastercam X4, when asked select NetHasp
2  Install Mastercam X4 MU3 update
3  Unpack RAR to a folder ( no needed but easier to use )
4  Install Mastercam Key in Register ( included in Emulator folder )
5  Install Emulator ( run Install.bat from emulator folder )
    and that's it, Mastercam is ready to use.
    Saludos
Redhouse
-Given: 90
-Receive: 8
« Reply #8 on: May 04, 2010, 06:58:18 18:58 »
 Hi Redhouse
    Saludos
Just so I am clear on this, are you sure about step-2?
I was reading on their website (http://www.mastercam.com/Support/Downloads/MastercamX4/Default.aspx) that you have to have a valid mantainance lic to install MU3:
"If your maintenance contract has expired prior to the date of the release, then you will not be able to run that Maintenance release."
I just want to be clean in my own mind what steps to take in proper order, thanks.
« Reply #9 on: May 04, 2010, 07:19:04 19:19 »
Yes when you install software, you have NO maintenance contract.
That's why the patch/crack Smiley
Redhouse
-Given: 90
-Receive: 8
« Reply #10 on: May 05, 2010, 03:57:46 03:57 »
Well Duh, that's not what I mean't, I thought I was clear it was the sequence I was inquiring about, sorry I'll try to be more clear.
The above had a typo "...to be clean in my own mind" should have read "to be Clear in my own mind".
I was just uncertain because the MU3 said it wouldn't install w/o "something" in place prior to trying.
Posted on: May 05, 2010, 12:52:29 00:52 - Automerged
 Hi Redhouse
    Saludos
Did all that exactly, it didn't work.
Untill... I checked the other instructions readme_Win32.txt in the second half of step #5:
"run  "NHaspX.exe" select  SIM type > NetHASP, Mode > Local > OK"
after doing that it worked fine, app launched and runs.
Without that last step, when the app launched you'd just get a splash screen then a small dialog box that say's:
Exiting
"No SIM Found"
Thanks for the help all.
jesse
-Receive: 101
« Reply #11 on: April 27, 2011, 05:29:09 17:29 »
   Maintenance Update 1 for Mastercam X5
         Just the medicine, download update from their website.
                http://www.filefactory.com/file/cbf1d67/n/mc_x5_mu1.rar
                Saludos
hosmis
-Given: 349
-Receive: 243
« Reply #12 on: January 01, 2012, 10:14:47 10:14 »
Mastercam X6 (v15.0.3.28) 32/bit
http://hotfile.com/dl/135902776/3cea44b/mc.part1.rar.html
http://hotfile.com/dl/135904433/b9f0595/mc.part2.rar.html
http://hotfile.com/dl/135905930/9ae7b6c/mc.part3.rar.html
http://hotfile.com/dl/135907554/08384a6/mc.part4.rar.html
http://hotfile.com/dl/135909267/83f6fd5/mc.part5.rar.html
http://hotfile.com/dl/135909525/e2abaea/mc.part6.rar.html
http://hotfile.com/dl/135947041/4ecf949/MCX.rar.html
sgoum
-Given: 94
-Receive: 68
« Reply #13 on: June 07, 2012, 05:52:50 17:52 »
Here it is
http://depositfiles.com/files/ekn4tmwc1
SB7
-Given: 294
-Receive: 818
Cry Havoc and let slip the dogs of war
« Reply #14 on: January 09, 2013, 01:13:09 01:13 »
This is for Mastercam x64 X6 MU2 or MU3 ( as the exe didn't change between updates) .  Just replace the Mastercam.exe with one provided and enjoy.  No USB Dongle emulator is needed , although it should also work with an EMU installed as the emu/registry check is patched as well.
This is just a patched .exe, the full installation and MU's are available directly from Mastercam under "support/downloads"  in the X6 section
« Last Edit: January 12, 2013, 05:38:56 05:38 by SB7 » Logged
whatchitfoool
-Given: 25
« Reply #15 on: February 11, 2013, 02:56:31 02:56 »
Am i right in the assumption that the base, and then each update needs to be installed in order to get this going? (ie, the updates are individual, not all encompassing)
SB7
-Given: 294
-Receive: 818
« Reply #16 on: February 11, 2013, 03:59:58 03:59 »
Yes,
The updates need to be installed in order, they are not all encompassing.  ( I did mention that in the readme)
You could stop @ MU2 , as the .exe didn't change between MU2 and MU3, although MU2 was a total disaster. MU3 fixed most of the things they screwed up with MU2.
If you find that the fully patched version isn't working for you, then I can provide minimally patched versions ( 8 bytes as opposed to 320 or so) that require the USB EMU's ( As close to legit as we're going to get.)( driver signing needs to be disabled for WIN7 x64 etc)
I'll post both the fully patched and minimally patched MCFSW X6 x64 MU1 DLL's in the next couple of days.  I've been chasing a memory leak that I attributed to the patching, but I just discovered it behaves the same way with an EMU.  ( MCFSW X6 MU1 x64 with SW2013)
Cheers
SB
« Last Edit: February 11, 2013, 04:06:10 04:06 by SB7 » Logged
SB7
-Given: 294
-Receive: 818
« Reply #17 on: February 14, 2013, 11:39:40 23:39 »
Minimally patched MC.exe  X6 MU3 x64 with USB EMU files  see readme
Posted on: February 15, 2013, 12:38:37 00:38 - Automerged
Minimally patched MCFSW.dll X6 MU1 x64 with USB EMU files see readme
 NOte: These are just the patched files, you'll need to "acquire" the full install files/MU's where ever you like.
« Last Edit: February 14, 2013, 11:45:18 23:45 by SB7 » Logged
Fab66
-Given: 127
« Reply #18 on: February 15, 2013, 04:31:01 04:31 »
Hello All's
also i search a french language patch for X4 MU3 and/or X6 MU3.
Thank's if you can help.
Fab
malcodrakefoy
« Reply #19 on: February 23, 2013, 09:21:19 21:21 »
works fine for me on my home laptop even blade expert runs without a glitch
cncbasher
-Given: 107
-Receive: 51
« Reply #20 on: February 24, 2013, 01:06:24 13:06 »
MCFSW X6 MU1 x64 DLL  Fully patched ( hopefully :-0)  ie No EMU required  Just replace the DLL and enjoy
could this be placed at a site where you don't need to subscribe to for access
SB7
-Given: 294
-Receive: 818
« Reply #21 on: May 17, 2013, 12:13:30 00:13 »
Posted on: February 24, 2013, 08:36:20 20:36 - Automerged
Note: this is just the patched DLL, you need to "acquire" the full installers/MU's , wherever you like
UPDATE: bug fix
"maintenance expiry date" from 12/31/2015 to 01/01/2016 to indicate an updated/fixed DLL
New Link :
Posted on: February 24, 2013, 08:45:50 20:45 - Automerged
Mastercam X7 x64 Fully patched ( hopefully ;-0)  No EMU required.  ( Note: This is just the patched exe, you'll need to acquire the full install where ever you like)
Hope someone may find this useful.
Minimally tested , feedback ?
Cheers
New Link as last one was deleted
« Last Edit: May 25, 2013, 04:34:33 16:34 by SB7 » Logged
PaulC
-Given: 3935
information is free and should be shared for free
« Reply #22 on: May 17, 2013, 01:37:12 13:37 »
full version download...
http://www.mastercam.com/Support/Downloads/MastercamX7/Default.aspx
find it , read it , share it .
mitchjs
-Receive: 105
« Reply #23 on: June 09, 2013, 08:30:08 20:30 »
on a side note, Mastercam X7, seems to run a program called "ToolManager.exe" (extensions folder), which seems to be protected by a different system, WIBU codemeter
not sure what exactly its doing, do know if I uninstall the codemeter service, mastercam wont run, dll missing error
tool seems to run... so not sure whats the deal
I prefer to not have "codemeter" service running, but that would require some patching to "toolmanager"
sgoum
-Given: 94
-Receive: 68
« Reply #24 on: June 14, 2013, 01:01:39 13:01 »
Enjoy
Pages: [1] 2 3  All
