May 24, 2025, 09:23:15 09:23
Pages: [1] 2  All
Author Topic: mikroC PRO for PIC 2009 version 2.15 has been released  (Read 24296 times)
wnmaximino
-Given: 47
-Receive: 202
Homer
« on: June 03, 2009, 07:22:49 19:22 »
For more information:
http://www.mikroe.com/en/compilers/mikroc/pro/pic/
Walko
-Receive: 8
« Reply #1 on: June 20, 2009, 09:51:32 09:51 »
Hello !
Somebody have a cr*** for this new release ?
Thanks a lot and have a nice day Wink
jack12345
-Given: 58
-Receive: 134
Happy diy
« Reply #2 on: June 26, 2009, 06:24:52 18:24 »
Hi:
I used mikroC PRO for PIC 2009 v1.65 of Crack,compiler OK!!
giappolo
-Given: 1736
-Receive: 621
« Reply #3 on: June 28, 2009, 01:20:54 13:20 »
Hi:
Sorry, but this is not true, if you test with following example 'Mikroelektronika\mikroC PRO for PIC\Examples\Development Systems\BIGPIC5\Touch Panel', you have DEMO LIMIT
xp338
-Given: 249
-Receive: 47
« Reply #4 on: June 28, 2009, 02:29:15 14:29 »
I use "Manny" instruction and test build 'Mikroelektronika\mikroC PRO for PIC\Examples\Development Systems\BIGPIC5\Touch Panel'.. ok
Hello chaps and ladies... V2.15 is now as leosedf says... what i have found is a string if you search for this string  F0 FF E9 8B 03 00 00 43 83 FB 3F in mBPIC.exe using say Ultraedit and when you find it replace the Valve 8B with 86 and then save the file, and using the same mikroBasic_PRO_PIC.key file from version 1.45 it will work as full version. I have tested it with the MMC file from Mikro's site and it compiles ok...
   Also you can edit the Key file and the bottom and change the name to something you might like...  This might be a string that is in all future versions so could be helpful to us all... I'll make a patch and post it or if someone would like to make one this would be nice too....
hope this helps all of us....
Manny....
lyk
« Reply #5 on: June 28, 2009, 08:45:37 20:45 »
Hello !
See http://rl-team.net/warez/1146288367-mikroc-pro-for-pic-2009-v215.html
Thiru09
-Given: 401
-Receive: 1188
« Reply #6 on: June 29, 2009, 05:16:18 05:16 »
Rapidshare link (from rl-team)
http://rapidshare.com/files/249666416/MikroElektronika.mikroC.PRO.for.PIC.2009.v2.15-rG.rar.html
Password: rl-team.net
pc04
-Given: 254
« Reply #7 on: June 29, 2009, 10:45:01 10:45 »
Registration doesn't work properly, demo limit still exist, tried with ethernet example
thanks
pc04
lyk
« Reply #8 on: June 29, 2009, 10:47:25 10:47 »
Kraсk is not working.
Do not remove demolimit.
wnmaximino
-Given: 47
-Receive: 202
Homer
« Reply #9 on: July 13, 2009, 07:08:20 19:08 »
New version avaliable... 2.50
xp338
-Given: 249
-Receive: 47
« Reply #10 on: July 14, 2009, 11:33:11 23:33 »
Just find this Patch , Not test...
Credit to the uploader
http://uploading.com/files/98Q1KHZS/MikroElektronika
bajrang
-Given: 245
-Receive: 79
« Reply #11 on: July 15, 2009, 04:16:32 04:16 »
rapidshare please!
dilipvpn
 Warned
« Reply #12 on: July 16, 2009, 06:35:31 18:35 »
Please upload rapidshare
spasbyspas
-Given: 741
-Receive: 366
« Reply #13 on: July 16, 2009, 06:56:35 18:56 »
Rapid link(10 time limit - i'm sorry):
http://rapidshare.com/files/256540526/MikroElektronika_Compilers_88_04_19_patch.zip.html
... and ifile - no limit:
http://ifile.it/8qp1zu2
endjoy!
dilipvpn
 Warned
« Reply #14 on: July 18, 2009, 07:07:30 19:07 »
Crack is working.
It will  remove demo limit.
Thanks.
koky
-Given: 162
-Receive: 157
« Reply #15 on: July 19, 2009, 10:40:26 10:40 »
remove demo limit, ba the cracked hex is different from original mikroc compiler (the lengt is the same but compare file show many difference)
okk
-Given: 369
-Receive: 39
« Reply #16 on: July 19, 2009, 01:55:55 13:55 »
I tried compiling the flashing LED examples supplied with mikroc_pro_pic_2009_v250 and they seem to simulate correctly in Proteus.
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1298
« Reply #17 on: July 19, 2009, 05:13:49 17:13 »
Yes it will works for small hex output ( < 2k ). But the generated Hex is not working for bigger program. I did try it on 49K program compiled with MikroC 8.2 and it is not working when compiling with the new version. And several examples also not working.
okk
-Given: 369
-Receive: 39
« Reply #18 on: July 19, 2009, 07:22:37 19:22 »
OK Ahmad_k, I didn't try  compiling and simulating anything larger such as the GLCD example.
Guess I'll have to wait for the correct medicine.
Thanks....
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1298
« Reply #19 on: July 19, 2009, 07:44:52 19:44 »
Does the simulation works fine for GLCD sample ? When i try it i got a crapped image on LCD.
okk
-Given: 369
-Receive: 39
« Reply #20 on: July 20, 2009, 01:22:45 13:22 »
I'll try to simulate the GLCD example when I get home tonight from work and report back...
okk
-Given: 369
-Receive: 39
« Reply #21 on: July 20, 2009, 04:24:26 16:24 »
You are quite correct Ahmad_k!
Original hex files for 16F887 simulate OK and 18F8520 simulates with LCD corruption after first bitmap has loaded.
Compiled files from 'fixed' version display outer boarder with rectangle in corner and then random 'junk'.
koky
-Given: 162
-Receive: 157
« Reply #22 on: July 20, 2009, 08:30:17 20:30 »
i attach a copare snap shot of the touch pannel hex, in the right there is original hex in the left crack hex
dilipvpn
 Warned
« Reply #23 on: July 25, 2009, 07:32:53 19:32 »
Here is the working patch of mikroC PRO for PIC 2009 version 2.50
I had compared both demo and patched out put .hex,They are exactly same.
http://rapidshare.com/files/259425963/MikroC_-_MikroBasic_Pro_For_PIC_v2.5_Patch_By_SCG.rar
conquerertr
« Reply #24 on: July 29, 2009, 01:24:30 01:24 »
http://uploading.com/files/98Q1KHZS/MikroElektronika is givin error on rapidshare.com
Error
This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times.
This limit is reached.
To download this file, the uploader either needs to transfer this file into his/her Collector's Account, or upload the file again. The file can later be moved to a Collector's Account. The uploader just needs to click the delete link of the file to get further information.
Pages: [1] 2  All
