April 29, 2026, 06:03:31 18:03
Author Topic: Fuse Configurator Plugin 1.2.2.4 for Proton  (Read 13368 times)
Dom
-Given: 65
-Receive: 32
« on: June 02, 2009, 10:08:52 22:08 »
I think  I haven't seen this plugin in the forum :
It can work now for the 3.2.5.5 version of Proton PDS
Download and put this plugin in the plugin directory of Proton PDS:
http://rapidshare.com/files/240122453/JGBTools.zip
Download and put thoses PPI files at the same level of Inc files
http://rapidshare.com/files/240123412/Includes.zip
You can now configure fuse setting for different Pics more easely.
Dom
« Last Edit: June 04, 2009, 09:42:33 09:42 by Dom » Logged
Dom
-Receive: 4460
« Reply #1 on: June 25, 2009, 03:25:41 15:25 »
Reason you did not see it posted here, is most people here know about Proton Plugins Smiley
http://wiki.picbasic.org/index.php?n=Main.Plugins
Dom
-Given: 65
-Receive: 32
« Reply #2 on: June 26, 2009, 05:19:48 17:19 »
Yes, but mine, I've patched it... Wink
Regards.
Dom
-Receive: 4460
« Reply #3 on: June 26, 2009, 10:04:31 22:04 »
A few setting dont work, try 16F690 and BOR_ON / BOR_OFF is not the right setting.
With the new pic chips you need to set all the fuses, or you end up spending an age debuging your code.
you should see the Fuse Configurator for Proton Beta, works like magic.
-Given: 405
-Receive: 545
« Reply #4 on: June 26, 2009, 10:38:11 22:38 »
The 16f690 BOR_ON / BOR_OFF  problem is in that version and a few newer version's of the compiler,
The compiler think's it should be BOD_ON / BOD_OFF  because the 16f690.inf  & 16f690.lpb files are wrong and this was found out on one of the beta versions but never corrected for this one.
Just change the bor to bod and it will compile or fix the lines in those 2 files
Or change the lines in the PPI file to read BOD instead of BOR
I have no idea if the BOR setting work's on the chip by doing any of these fixes but it will compile at least
« Last Edit: June 26, 2009, 10:41:46 22:41 by bbarney » Logged
-Given: 405
-Receive: 545
« Reply #5 on: June 27, 2009, 04:50:47 16:50 »
heres some fixed files untested though but it compiles with the proper fuse settings,just put them in the Inc directory backing-up the 2 original files first
Dom
-Given: 65
-Receive: 32
« Reply #6 on: June 29, 2009, 10:48:03 10:48 »
Here is the version 1.2.2.6 of this software:
http://rapidshare.com/files/249887407/JGBTools1226.zip
For use with the "Includes" 's  files and the two files from Bbarney.
PS: to avoid repeating the "config_start"..."config_end" section at each change of the fuse, you must first select this section.
« Last Edit: June 29, 2009, 10:55:01 10:55 by Dom » Logged
Dom
sadman
-Given: 1987
-Receive: 3216
Sow The Seeds of Love
« Reply #7 on: August 03, 2009, 08:33:04 08:33 »
with out setup file not work properly under ide i just make setup to help out other as simple copy paste of crack files never work for me in ide setup work fine and plug start
http://rapidshare.com/files/263143273/Includes.rar.html
sadman
