tekniker_erhan
-Given: 48
-Receive: 102
« on: May 13, 2009, 04:59:34 16:59 » |
« Last Edit: May 13, 2009, 06:09:27 18:09 by tekniker_erhan »
jwildes
  Warned
-Given: 557
« Reply #1 on: May 13, 2009, 09:13:14 21:13 » |
Dear Friend,
First, thanks for you share this project with us. I would like to know what compiler you used with this .bas file. And what language is used too....turkish, russian, etc.
Best regards,
Jwildes
-Given: 566
-Receive: 409
« Reply #2 on: May 13, 2009, 10:07:44 22:07 » |
Looking at it I would say picbasic pro becuse it's a PBP file
jwildes
  Warned
-Given: 557
« Reply #3 on: May 14, 2009, 03:08:17 03:08 » |
I tested it with a DS1822....because DS1820 is no longer available and i dont have one here...but the temperature value is 212°C for 25.3°C. I try translate the comments for turkish to english but haven't sucess... If someone can translate to english will be helpful. I will try with PBP Pro to change some words and see if compiler ok...
Best regards.
Jwildes
ajak
-Given: 199
-Receive: 77
« Reply #4 on: May 14, 2009, 06:06:31 06:06 » |
Here i try to translate it.. Some comments were translated but some is not.. '************************************************* *************** '* Name: * DS1820'li room termometresi.BAS '* Author: Erhan YILMAZ * '* Notice: * '*: All Rights Reserved * '* Date: 13.05.2009 * '* Version: 1.0 * '* Notes: * '*: * '************************************************* *************** @ DEVICE PIC16F84A @ DEVICE PIC16F84A, XT_OSC @ DEVICE PIC16F84A, WDT_OFF @ DEVICE PIC16F84A, PWRT_ON @ DEVICE PIC16F84A, PROTECT_OFF define OSC 4 Define LCD_DREG PORTB Define LCD_DBIT 4 Define LCD_RSREG PORTB Define LCD_RSBIT 0 Define LCD_EREG PORTB Define LCD_EBIT 1 LCDOUT $ FE, $ 40,12,18,18,12,0,0,0,0 'rating iþareti LCDOUT $ FE, $ 48,4,14,4,4,4,4,14,0 'à characters
command byte 'Script Variables has a byte 'loop sayac Variables temp var word 'temperature measurement Variables There PORTB.2 DQ 'DS1820 pin connection DQ_DIR have TRISB.2 'DS1820 input / output pin routing Lcdout $ fe, 1, "ROOM TERMOMETRES", 1 ' by pressing: Gosub init1820 'DS1820 hazýrla command = $ cc 'command sent ROM Gosub DS1820_yaz
command = $ 44 'Start Dönüþümü Gosub DS1820_yaz
Gosub init1820 'DS1820 hazýrla again
command = $ be 'Read temperature results Gosub DS1820_yaz Gosub DS1820_oku Lcdout $ FE, $ C0, "TEMPERATURE =", dec (temp>> 1 ),".", dec (temp.0 * 5), 0, "" Goto basla 'And not connected DS1820'yi hazýrlar and sensor controls init1820: Low DQ Pauseus 500 DQ_DIR = 1 Pauseus 100 If DQ = 1 Then Lcdout $ FE, $ C0, "DS1820 NO" Pause 500 Goto basla Endif Pauseus 400 Return 'DS1820'ye command sends byte'ný DS1820_yaz: For i = 1 to 8 If komut.0 = 0 Then Gosub sifir_yaz Else Gosub bir_yaz Endif command = command>> 1 Next i Return 'DS1820'ye logic 0 sends information sifir_yaz: Low DQ Pauseus 60 DQ_DIR = 1 Return 'DS1820'ye logic 1 sends information bir_yaz: Low DQ @ Nop DQ_DIR = 1 Pauseus 60 Return 'DS1820'den 16-bit temperature reading information DS1820_oku: For i = 1 to 16 temp = temp>> 1 Gosub bit_oku Next i Return 'DS1820'den 1 bit reads bit_oku: temp.15 = 1 Low DQ @ Nop DQ_DIR = 1 If DQ = 0 Then temp.15 = 0 Endif Pauseus 60 Return End
tekniker_erhan
-Given: 48
-Receive: 102
« Reply #5 on: May 14, 2009, 01:00:55 13:00 » |
codes here with english descriptions '**************************************************************** '* Name : DS1820'li oda termometresi.BAS * '* Author : ERHAN YILMAZ * '* Notice : * '* : All Rights Reserved * '* Date : 13.05.2009 * '* Version : 1.0 * '* Notes : * '* : * '**************************************************************** ' Picbasic Pro program to read DS1820 1-wire temperature sensor ' and display temperature on LCD @ DEVICE PIC16F84A @ DEVICE PIC16F84A,XT_OSC @ DEVICE PIC16F84A, WDT_OFF @ DEVICE PIC16F84A, PWRT_ON @ DEVICE PIC16F84A, PROTECT_OFF define OSC 4 Define LCD_DREG PORTB Define LCD_DBIT 4 Define LCD_RSREG PORTB Define LCD_RSBIT 0 Define LCD_EREG PORTB Define LCD_EBIT 1 LCDOUT $FE,$40,12,18,18,12,0,0,0,0 'degree sign LCDOUT $FE,$48,4,14,4,4,4,4,14,0 'İ character
' Allocate variables komut var byte ' Storage for command i var byte ' Storage for loop counter temp var word '' Storage for temperature DQ var PORTB.2' Alias DS1820 data pin DQ_DIR var TRISB.2' Alias DS1820 data direction pin ;Lcdout $fe, 1, "ROOM THERMOMETER"' english Lcdout $fe, 1, "ODA TERMOMETRES",1' Turkish 'Mainloop to read the temperature and display on LCD basla: Gosub init1820 ' init the DS1820 komut = $cc ' Issue Skip ROM command Gosub DS1820_yaz
komut = $44 ' Start temperature conversion Gosub DS1820_yaz
Gosub init1820 ' Do another init
komut = $be ' Read the temperature Gosub DS1820_yaz Gosub DS1820_oku ' Display the decimal temperature Lcdout $FE,$C0,"SICAKLIK=",dec(temp >> 1),".",dec(temp.0 * 5),0," " Goto basla ' Initialize DS1820 and check for presence init1820: Low DQ ' Set the data pin low to init Pauseus 500 ' Wait > 480us DQ_DIR = 1 ' Release data pin (set to input for high) Pauseus 100 ' Wait > 60us If DQ = 1 Then 'Lcdout $FE,$C0, "DS1820 not present"'english Lcdout $FE,$C0, " DS1820 YOK "'Turkish Pause 500 Goto basla ' Try again Endif Pauseus 400 ' Wait for end of presence pulse Return
' Write "command" byte to the DS1820 DS1820_yaz: For i = 1 to 8 ' 8 bits to a byte If komut.0 = 0 Then Gosub sifir_yaz ' Write a 0 bit Else Gosub bir_yaz ' Write a 1 bit Endif komut = komut >> 1 ' Shift to next bit Next i Return
'Write a 0 bit to the DS1820 sifir_yaz: Low DQ Pauseus 60 ' Low for > 60us for 0 DQ_DIR = 1 ' Release data pin (set to input for high) Return
'Write a 1 bit to the DS1820 bir_yaz: Low DQ ' Low for < 15us for 1 @ nop ' Delay 1us at 4MHz DQ_DIR = 1 ' Release data pin (set to input for high) Pauseus 60 ' Use up rest of time slot Return
'Read a bit from the DS1820 DS1820_oku: For i = 1 to 16 ' 16 bits to a word temp = temp >> 1 ' Shift down bits Gosub bit_oku ' Get the bit to the top of temp Next i Return
'DS1820'den 1 bit okur bit_oku: temp.15 = 1 ' Preset read bit to 1 Low DQ ' Start the time slot @ nop ' Delay 1us at 4MHz DQ_DIR = 1 ' Release data pin (set to input for high) If DQ = 0 Then temp.15 = 0 ' Set bit to 0 Endif Pauseus 60 ' Wait out rest of time slot Return End
jwildes
  Warned
-Given: 557
« Reply #6 on: May 25, 2009, 06:49:49 18:49 » |
Hi Guys,
I compile the last code sent by Erhan with PBP Pro 250....it's work fine.... I translate to portuguese too....good jog Erhan... Now i'd like to change the sensor...1820 to 1822....any tip?
Jwildes
tekniker_erhan
-Given: 48
-Receive: 102
« Reply #7 on: May 26, 2009, 11:31:58 11:31 » |
These codes are sample for one wire interface and comunication, You can use what you want with codes ds1820,ds1822,ds18b20,ds1990a etc. The difference between ds1820 and ds1822 temperature calculations and resolution For use ds1822 change this line Lcdout $FE,$C0,"SICAKLIK=",dec(temp >> 1),".",dec(temp.0 * 5),0," with this line Lcdout $FE,$C0,"SICAKLIK=",dec(temp >> 4),".",dec(temp.3 * 5),0," " I have not tried codes, but as theoretical
