Hierarchical Block - Sonsivri
May 13, 2026, 03:16:33 03:16
Author Topic: Hierarchical Block  (Read 4303 times)
badvezir
« on: May 03, 2009, 05:30:27 05:30 »
Hi!
I created an hierarchical Block of an OTA in orcad capture and i want to use it in many projects so as to create filters!
Is there any way to make this block part of a library so to use it easily every time i want?
Because so far to use this block to another project, i had to copy the block, then copy what's inside the block and connect the pins!!!
Thanks in advance for your time!!!
