Source Code can't run in proteus - Sonsivri
May 13, 2026, 03:16:36 03:16
Author Topic: Source Code can't run in proteus  (Read 5232 times)
jamen
-Given: 31
« on: April 19, 2009, 08:46:38 08:46 »
the day before yesterday ; i am download a refereng design at WWW.IRF.COM.
Source Code can't run in proteus?
WHY??? Can anyone help?
Sory bad in english.
-Receive: 4459
« Reply #1 on: April 21, 2009, 01:51:14 01:51 »
code posted is microchip assembley code, did you run MPLAB to make the hex file.?
and your link to WWW.IRF.COM should read www.irf.com
http://www.irf.com/technical-info/appnotes.htm  < and here point to file you want help with.
« Last Edit: April 27, 2009, 05:03:00 17:03 by pickit2 » Logged
jamen
-Given: 31
« Reply #2 on: April 21, 2009, 06:53:52 18:53 »
Tank you ! In IR web site,The source code was wrong. At MPLAB_IDE. use MPLAB_SIM debug was OK. But use proteus debug ,Can't run. I can't found the problem.
-Receive: 4459
« Reply #3 on: April 27, 2009, 05:07:16 17:07 »
I think without a model for IRS2530D, you will never get it sim in Proteus.
