May 25, 2025, 05:29:04 05:29
Author Topic: AVR mcu based thermostat with 7 segment LED and PTC (or NTC)?  (Read 8265 times)
firewalker
-Given: 19
-Receive: 88
« on: April 18, 2009, 03:23:45 15:23 »
Is there any AVR mcu based thermostat (3 digit accuracy) with 7 segment LED and PTC (or NTC)?
I have found several thermostat projects using an AVR mcu. The most of them uses a smart display an a sensor DSxxx.
I would also find handy if you know anything for other (not avr mcu based, or without an mcu) thermostats with 7 segment display and an PTC or NTC?
« Last Edit: April 18, 2009, 05:01:42 17:01 by firewalker » Logged
bbarney
-Given: 405
-Receive: 545
« Reply #1 on: April 18, 2009, 04:48:33 16:48 »
Why don't you make up your mind on what your requesting,the topic states
Re: AVR mcu based thermostat with 7 segment LED and PTC (or NTC)?
then at the bottom your asking for something else ?
Is there any other (not mcu based) thermostat with 7 segment display?
So what is it you want ?
firewalker
-Given: 19
-Receive: 88
« Reply #2 on: April 18, 2009, 04:55:37 16:55 »
My primary goal was an avr based, seven segment display thermostat using a NTC or a PTC. I have searched for hours over the net. I didn't found anything. So I suspected that I won't find someone how knows something for such a thermostat. But, I had to ask.
My second goal was avr mcu-less thermostat.
Maybe I should have posted a new thread to "general-electronics".
« Last Edit: April 18, 2009, 05:01:59 17:01 by firewalker » Logged
avrPassion
« Reply #3 on: April 18, 2009, 06:12:15 18:12 »
It is so simple to design a thermostat yourself.
All members of ATmega family have 10 bit ADC which is enough for 3 digit.
to do signal conditioning on a sensor such as pt100 you should pass 100uA from it and then measure the voltage on it. You can use an OP07 op-amp to amplify the output voltage.
If you want, i can draw the circuit and post it here.
firewalker
-Given: 19
-Receive: 88
« Reply #4 on: April 18, 2009, 07:14:39 19:14 »
Thanks you avrPassion. I will give a try.
Manuel
-Given: 713
-Receive: 194
« Reply #5 on: April 18, 2009, 07:23:13 19:23 »
Well, related 2 3 DIGIT 7 segment LED display unit U can use a 0..100mV voltmeter from RS or FARNEL i'd say....then you can use a silicon based sensor such as MCP9700 from m..chip and a little OP circuitry just 2 enter in the range of the voltmeter....and the job is done.
maybe something like 522-339 from RS...expencive but functional...
A processor based can be realized and U will spend no more than 7$....but some rework will be involved in....
Tell us what would you like 2 to @ the end?
Let me tell you that U can also consider a sampling request from LASCAR.  http://www.lascar.co.uk/press/pdf/PR-10-02-UK.pdf at a cost of £15.50
CU
X.
« Last Edit: April 18, 2009, 07:31:44 19:31 by Manuel » Logged
