May 25, 2025, 05:50:43 05:50
Author Topic: Willem EPROM Programmer 2009  (Read 13112 times)
acat_lm
-Given: 73
-Receive: 128
« on: March 04, 2009, 10:46:47 10:46 »
 Support CHIPS   (EPROM,EEPROM,FLASH,I2C,PIC,MCS-51,AVR, 93Cxx, ISP)
EPROM   27C64 , 27C128 , 27C256 , 27C512 , 27C010 , 27C020 , 27C
040 , 27C1001
M27C1001 , M27C2001 , M27C4001
27C080 (A19) , M27C801 , M87C257
2716(Vpp25V) , 2732 , (adapter DIP24)
2764 , 27128 , 27256 , 27512 , 27010,
Vpp12.5V (21Vpp Modify Circuit)
EEPROM   28C65 , 28C64 , 28C128 , 28C256 , 28C512 , 28C010 , 28C020 , 28C040
M28C16A/17A (DIP28)
(Adapter or Jumper) 28C16,XLS2816 (DIP24)
FLASH Memory   28F64 , 28F128 , 28F256 , 28F512 , 28F010 , 28F020
MX26C1000 , MX26C2000 , MX28F1000 , MX28F2000
Am28F256A , Am28F512A , Am28F010A , Am28F020A (New command erase/prog.)
-- intel ---
i28F001BX , 28F004 , 28F008 , 28F016
FLASH Memory   29F64 , 29F128 , 29F256 , 29F512 , 29F010 , 29F020 , 29F040 , 29F080
29F001 , 29F002 , 29F004 , 29F008 , 29F016 , 29F032 , V29C51002T
Serial (I2C) EEPROM
24Cxx    24C02 , 24C04 , 24C08 , 24C16 , 85C72 , 85C82 , 85C92
--- page write ----
24C32 , 24C64 , 24C128 , 24C256 , 24C512
Microwire EEPROM
    <------ Data 8bit -----> (pin 6 ->ORG. [Schematic connect to GND])
93C06 , 93C46 , 93LC46 , 93C56 , 93C57, 93C66 , 93C76 , 93C86 (8bit) , AT59C11 , AT59C22 , AT59C13
CAT35C102 , CAT35C104 , CAT35C108 (pullup pin7)
<------Data 16bit------> (pin 6 ->NC [No Connect])
93C06A , 93C46X , 93C56 , 93C66 , 93C76 , 93C86 (NS)
Microchip PIC   16C84 , 16F84 ,16F84A , 16F627/16F628
12C508/A , 12C509/A , 12CE518 , 12CE519 , 16C505
16C620 , 16C621 , 16C622 , 16CE623 , 16CE624 , 16CE625 , 16C710/711
---ICSP connector----
16F870 , 16F871 , 16F872 , 16F873 , 16F874 , 16F876 , 16F877 PIC16F873A , PIC16F874A , PIC16F876A , PIC16F877A
-Add PIC microchip 14bit
PIC12F629 , PIC12F675 ,  PIC16F630 , PIC16F676 , PIC12F635 , PIC12F683 , PIC16F636 , PIC16F684 , PIC16F688
PIC16F72/73/74/76/77 , PIC16F737/747/767/777 , PIC16F87/88 , rfPIC12F675x , PIC16F785/PS200 , PIC16F716
-Add microchip 14bit,12bit OTP
PIC12C671 , PIC12C672 ,  PIC12CE673 ,  PIC12CE674
PIC16C61/71 , PIC16C62/64/65/73 , PIC16C62A/62B/62C/63/63A/64A/65A/65B/66/67
PIC16C72/72A/73A/74A/74B/76/77 , PIC16C620/620A/621/621A/622/622A
PIC16CE/623/624/625 , PIC16C710/711/712/716 , PIC16C773/774 , PIC16C745/765/923/924 , PIC16C925/926
PIC16C554/556/557/558 , PIC16C432/433 , PIC16C717/770/771/781/782
-Add PIC microchip 12bit (FLASH memory)
PIC12F508/509 , PIC10F200/202/204/206 , PIC16F505 , PIC16F54/57
-Add PIC18Fxxx
PIC18F242 , 18F248 , 18F252 , 18F258 , 18F442 , 18F448 , 16F452 , 16F458
PIC18F1220 , 18F2220 , 18F4220 , 18F1320 , 18F2320 , 18F4320
PIC18F6520 , 18F6620 , 18F6720 , 18F8520 , 18F8620 , 18F8720
PIC18F2331 , 18F2431 , 18F4331 , 18F4431
PIC18F6525 , 18F6621 , 18F8525 , 18F8621
PIC18F6585 , 18F6680 , 18F8585 , 18F8680
PIC18F2439 , 18F2539 , 18F4439 , 18F4539
PIC18F6410 , 18F8410 , 18F6490 , 18F8490
Add PIC18Fxxx
PIC18F2410 , PIC18F2420 , PIC18F2455
PIC18F2510 , PIC18F2515 , PIC18F2520 , PIC18F2525 , PIC18F2550 , PIC18F2585
PIC18F2610 , PIC18F2620 , PIC18F2680
PIC18F4410, PIC18F4420 , PIC18F4455
PIC18F4510 , PIC18F4515 , PIC18F4520 , PIC18F4525 , PIC18F4550 , PIC18F4585
PIC18F4610 , PIC18F4620 , PIC18F4680
Add Find and edit value OSCCAL (PIC12F629/675 , PIC16F630/676)
Add Edit config at address 0x2008,0x2009 (PIC12F635/683 , PIC16F636/684/688 , PIC16F785)
Fixed Programming PIC all
Test on chip
PIC12F675 , PIC16F676 , PIC16F684 ,PIC16F767, PIC16F74
PIC16F872 , PIC16F876 , PIC16F877, PIC16F876A, PIC16F873A, PIC16F819
PIC16F84 , PIC16F84A , PIC16F628, PIC16F628A,
eprom PIC12C509JW , PIC16C505JW , PIC16C711JW , PIC16CE625JW
PIC18F458 , PIC18F4320 , PIC18LF258 , PIC18F4539 , PIC18F4431
Atmel Flash Memory
(Sector Programming)
(Software Data Protection)   AT29C256 , AT29C512 , AT29C010A , AT29C020 , AT29C040 , AT29C040A
W29EE512 , W29EE011 , W29EE012 , W29C020(128) , W29C040
PH29EE010(W29EE011)
ASD AE29F1008 (AT29C010), AE29F2008 (AT29C020)
Ver 0.992 up(DOS). Can run under win9x
(disable prog. CPUIdle or CPUCool)
Atmel Flash Memory
AT49Fxxx (Subset 29Fxxx)
(Byte-by-Byte Programming)
(Software Data Protection)    Command seq. 5555/AA, 2AAA/55, 5555/A0
AT49F512 , AT49F010 , AT49F020 , AT49F040
SST39SF010 , SST3S9F020 ,SST39SF040
AT49F001 , AT49F002 , AT49F008A
Command seq. 555/AA, 2AA/55, 555/A0
Am29F512 , Am29F010 , Am29F020 , Am29F040 , HY29F080
29F002 , 29F002T , Pm29F002T
Serial Peripheral Interface (SPI)
EEPROM Mode0 (0,0)
AT25xxx, W95xxx   [Atmel] AT25010 , 020 , 040 (A8-A0)
AT25080 , 160 , 320 , 640 , 128 , 256 (A15-A0)
[ST] W95010....256, Microchip 25x010 - 25x640
--- Byte programming
25010 , 25020 , 25040
--- Page programming
25C080 , 25C160 , 25C320 , 25C640 , 25C128 , 25C256 , 25C512
AT25HP256 , AT25HP512
AT25HP1024 (24bit address)
-- CAT64LCxxx (16bit DATA IN/OUT) use Socket 93Cxxx
CAT64LC010, CAT64LC020, CAT64LC040
Atmel EEPROM (page prog.)
(Software Data Protection)   AT28C256 , AT28C010 , AT28C040
Nonvaltile SRAM (DS12xx)   DS1220 , DS1225Y , DS1230Y/AB , DS1245Y/AB , DS1249Y/AB
static RAM (Test RAM)   6116 , 6264 , 62256 , 62512 , 628128
EPROM winbond,SST
Electrical Erase Chip   W27E512 , W27E010 , W27C010 , W27C020 , W27C040
SST27SF256 , SST27SF512 , SST27SF010 , SST27SF020
MX26C4000
Vcc = 3.3-3.6V SST37VF512 , SST37VF010 , SST37VF020 , SST37VF040
Flash Memory SST,Sanyo    SST28SF040A , LE28F4001
 Link: http://rapidshare.com/users/9RL0MM
localcrack
-Given: 64
-Receive: 21
« Reply #1 on: March 05, 2009, 06:10:10 06:10 »
Original website
http://www.sivava.com/
mayli
-Given: 12
-Receive: 30
« Reply #2 on: March 05, 2009, 09:42:48 09:42 »
Do you have the PCB schematic or CAD file?
Since all the programs you posted are need the programming board. If haven't the board, all the programs are no used.
acat_lm
-Given: 73
-Receive: 128
« Reply #3 on: March 05, 2009, 10:38:02 10:38 »
 There is documentation On reference. In documentation there is all.
fikus
-Given: 57
-Receive: 15
« Reply #4 on: October 14, 2009, 06:17:33 18:17 »
Does anyone have schematic for 40/42 adapter?
fikus
-Given: 57
-Receive: 15
« Reply #5 on: October 16, 2009, 09:01:53 21:01 »
I answer myself  Smiley
http://www.ezoflash.com/
