March 16, 2026, 10:12:50 10:12
Pages: [1] 2 3 4 5
Author Topic: Proton Development (USB Key version) Needed for Cracking  (Read 73157 times)
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« on: October 31, 2006, 08:30:42 20:30 »
Hello.
Anyone have a full copy of Proton Development suite (Dongle Protected)?? because i can crack all type of dongle without having the original dongle key. Beleive me when i get this program it takes only a few days and it will be cracked.
-Given: 582
« Reply #1 on: October 31, 2006, 08:37:37 20:37 »
You could always buy a copy if you wanted to  Wink and save time in cracking it then
Plus the down side side is that you will not be able to get updates for it
Support the makers and it keeps them going  Lips sealed
wizpic
thoroide
-Receive: 72
« Reply #2 on: October 31, 2006, 09:22:05 21:22 »
The program is almost one year that is out.
Many many people has try to crack it but no luky.
The program is hardly protected, is packed with custom modified armadillo, then you can't try to crack it since you have not unpacked.
Also, the protection is deeply implemented.
There are other issues in adding's.
To setup program you need the dongle.
To run program you need dongle.
When you perform a online update you need the dongle, and for each update you need to re-crack the program....
In effect is more easy to buy it that crack it. Also if you use it for work, at the first work you do, the compiler is repayed itself.
Also the cracked version can give you false results. You feel that is correctly compiled, but due a some little cracking failure, you may obtain a miscompiled software, and it can cause a very loose of time.
\thor
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #3 on: November 01, 2006, 04:19:34 04:19 »
Yes i know that but i want to try cracking it, plz if anyboyd have a copy upload it.
jibun24
« Reply #4 on: November 02, 2006, 03:31:49 15:31 »
Try with this one, this is a recent lite version but the compiler seems complete like PDS (the size of the compiler is close to 1Mb).
I have cracked the proton IDE (work with proton plus 2.20) but not with this lite version.
http://rapidshare.com/files/1688142/Proton_Ds_Lite_Pic_Compiler_W_Floating_Point_new_version.zip
 Smiley
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #5 on: November 02, 2006, 07:08:34 19:08 »
i only want to crack the original version to use the 18xxx series. The version cracked by METAL is very good, but i want to try the compiler ver 3.0
jibun24
« Reply #6 on: November 02, 2006, 07:34:46 19:34 »
It's version 3.0 !!!, install it and test it !
The Proton IDE that i have cracked work with proton plus 2.20 because this one is not protected with dongle. But with the PDS lite (lines and somes pics limitations) it doesn't work because it's protected with a dongle.
mizk_electro
« Reply #7 on: November 03, 2006, 12:47:55 00:47 »
Ahmad_K
If you can make it .... hope u can share it over here ?
Its should be interesting.
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #8 on: November 03, 2006, 11:58:35 11:58 »
is this version support 18F2550 or 18F4550 Huh
miba
-Given: 313
« Reply #9 on: November 03, 2006, 02:37:21 14:37 »
Yes it supports both (18F2550, 18F4550).
The offical list of all supported devices: http://www.picbasic.org/proton_compiler.php
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #10 on: November 04, 2006, 04:14:06 04:14 »
I mean the version posted by JIBUN24
is this version support the 18F2550 ??
demon
-Given: 47
« Reply #11 on: November 04, 2006, 11:49:07 11:49 »
I too have been after a full version, but still no luck
The software dongle can be emulated and read, if it is one of the standerd  ones.
The hard part if you can't get a key to clone is going to be getting the encryption key tables, as these are needed to to get jumps to work correctly, assuming the crooks at Crownhill arn't better than avarage programmers, they may have just used the dongle wrapper.
if anybody can share a copy of full version then please
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #12 on: November 04, 2006, 05:30:15 05:30 »
that's what i need. A full copy to crack it
sadman
-Given: 1977
-Receive: 3210
Sow The Seeds of Love
« Reply #13 on: November 04, 2006, 12:39:21 12:39 »
send me your email address and i will send you orignal iso for new relase 3.10.8
Fragrance
okk
-Given: 369
-Receive: 39
« Reply #14 on: November 04, 2006, 01:03:14 13:03 »
Here it is....
DownloadLink: http://rapidshare.com/files/1942526/Prot.rar.html
Password: sonsivri
mizk_electro
« Reply #15 on: November 04, 2006, 04:03:59 16:03 »
Here it is....
Password: sonsivri
okk ...
Is it the one that been talked by Ahmad_k ?
and it's still NOT being cracked or already BEEN  cracked ?
Sorry for my bad english ...
 Sad
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #16 on: November 04, 2006, 04:49:42 16:49 »
Can you please split this file into several pack. 10MB per pack please. because i have a slow internet connection
bajrang
-Given: 245
-Receive: 79
« Reply #17 on: November 04, 2006, 05:17:58 17:17 »
Dear Ahmad_K,
Good that you are interested in cracking the PDS!
As a word of caution , i would lile to mention that the USB dongle seems to have some part of compiler on it! This was brought to notice by some of our friends here.
But anyways please attempt to crack PDS somehow! It would be one of the greatest achievement on this forum . My all best wishes to you!
warm regards,
bajrang
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #18 on: November 04, 2006, 05:29:46 17:29 »
I will do my best. but please split the file into several pack
okk
-Given: 369
-Receive: 39
« Reply #19 on: November 04, 2006, 07:51:37 19:51 »
Yes it's the full version that uses the 'Spark' USB dongle.
It is NOT cracked.
Here are the new links: -
http://rapidshare.com/files/1991979/Prot.part01.rar.html
http://rapidshare.com/files/1992583/Prot.part02.rar.html
http://rapidshare.com/files/1993512/Prot.part03.rar.html
http://rapidshare.com/files/1994295/Prot.part04.rar.html
http://rapidshare.com/files/1995179/Prot.part05.rar.html
http://rapidshare.com/files/1995939/Prot.part06.rar.html
http://rapidshare.com/files/1996558/Prot.part07.rar.html
http://rapidshare.com/files/1997176/Prot.part08.rar.html
http://rapidshare.com/files/1997806/Prot.part09.rar.html
Passworg: sonsivri
« Last Edit: November 04, 2006, 07:53:45 19:53 by okk » Logged
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #20 on: November 05, 2006, 09:14:49 09:14 »
Ok i will start the cracking
okk
-Given: 369
-Receive: 39
« Reply #21 on: November 05, 2006, 10:26:12 10:26 »
Good luck!!!!!
cesarman
« Reply #22 on: November 06, 2006, 03:27:17 03:27 »
yep realy Good Luck. let us know what we can help..
sadman
-Given: 1977
-Receive: 3210
« Reply #23 on: November 06, 2006, 12:40:30 12:40 »
hi
here is pds3.10 orignal dongle version  Wink
http://rapidshare.com/files/2209365/PDEV310.part1.rar.html
http://rapidshare.com/files/2211261/PDEV310.part2.rar.html
http://rapidshare.com/files/2212280/PDEV310.part3.rar.html
last and final part
http://rapidshare.com/files/2213476/PDEV310.part4.rar.html Wink
« Last Edit: November 06, 2006, 12:59:27 12:59 by Fragrance » Logged
johnbharath
« Reply #24 on: December 11, 2006, 07:33:19 07:33 »
good luck ahmad, How is going on Smiley
Pages: [1] 2 3 4 5
