Part Project LM35 & 16F676 - Sonsivri
May 13, 2026, 03:16:10 03:16
Author Topic: Part Project LM35 & 16F676  (Read 8502 times)
-Receive: 4459
« on: January 19, 2009, 01:23:55 01:23 »
As you may know the 16F676 is a pain to setup, so I will share the start of a project.
The rar file has Proton Basic files & Proteus DNS, so you can test setup before the build.
This is to monitor the output of a LM35 and Display the Temerature readings on a Lcd.
« Last Edit: January 19, 2009, 01:31:10 01:31 by pickit2 » Logged
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #1 on: January 19, 2009, 06:00:56 06:00 »
Looks ok to me , and I would suggest you use another Voltage reference for using LM35
1.- LM35 out signal is only milivolts , for example 1000 mv or 1 v for 0-100 Degree Celsius diference.
2.- Connect Vref in PIC to an lower voltage so you can expand the scale
3.- This is easy to do with a voltage ladder of , let say 2 x 10 kohm resistors from 5V to ground and connecting Vref of Pic in the middle so Vref is 2.5V.  You must adjust your " PAYBACK " variable accordingly. And also configure ADCON0 register accordingly.
This will give you much more precisión in reading the temperature.
Greetings
Francisco
jeanninemtv
-Given: 57
-Receive: 25
« Reply #2 on: January 19, 2009, 07:26:53 07:26 »
so you need a stable Vref...  better with a buffer opamp
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #3 on: March 21, 2009, 05:42:47 05:42 »
Older topic, but seemed incomplete so I'll add to it:
I'd suggest using a zener diode to create the reference voltage, so it will be stable even if power supply voltage isn't.
Something like this:
Zener diodes are readily available at most 0.1V steps from 2 to 5.1 Volts.
insane4evr
-Receive: 50
« Reply #4 on: March 22, 2009, 03:08:33 03:08 »
Try an LM336x-2.5. It has tighter reference voltage tolerance and lower temperature drift. Just my 2 cents.
-Given: 405
-Receive: 545
« Reply #5 on: March 22, 2009, 04:52:50 04:52 »
Hey pickit, don't suppose you did a version of this with a 3 or 4 digit led display ?
-Receive: 4459
« Reply #6 on: March 22, 2009, 04:58:05 04:58 »
I did do, a (freq-counter or voltage) monitor for 6 digit 7seg display.
I will dig it out if you want.
-Given: 405
-Receive: 545
« Reply #7 on: March 22, 2009, 06:22:56 06:22 »
if you wouldn't mind,I had one made with a 16f690 but after getting bit by a bug I lost a lot of stuff and a bunch never worked after upgrading to the beta just 16f690 stuff and I did try the "Declare FLASH_CAPABLE = FALSE" trick that got the lcd to work but the code never ran right so I thought try leds again  Grin
babatundeawe
-Given: 60
« Reply #8 on: April 24, 2009, 08:56:42 20:56 »
try this from one of spency's tut
www.digital-diy.net
