March 15, 2026, 08:36:32 08:36
Author Topic: picbasic pro and stp16c596  (Read 6429 times)
-Given: 405
-Receive: 545
« on: August 28, 2006, 06:56:23 18:56 »
has anybody used this shift register with picbasic pro.Iwant to us it with this dual-color 8x8 dot matrix display and don't know where to start.Iwas thinking of using a pic18f2550 or 18f4550 any help you be greatly appreciated anything to get me started would be great
stp16c596 http://www.st.com/stonline/products/literature/ds/10154.pdf#search=%22stp16c596%22
display http://www.sparkfun.com/commerce/product_info.php?products_id=681
mississippi
« Reply #1 on: August 29, 2006, 12:59:33 12:59 »
To get the data in the chip you can use the shiftout  instruction with the  \16 parameter. And with a normal output you can control the LE pin.
So you only use 3 pins to controle this chip. And in principle it is not nessesary to use a 18 F part, a 16F part can do it also.
-Given: 405
-Receive: 545
« Reply #2 on: August 29, 2006, 03:29:46 15:29 »
Thanx
