pasanlaksiri
-Given: 144
-Receive: 59
« on: December 14, 2008, 05:35:27 17:35 » |
What do u guys think? This is how exactly i do it http://www.youtube.com/watch?v=Ee_8IMx0uMoLarge files removed : way out of order posting such files..
« Last Edit: August 11, 2013, 03:29:20 15:29 by pickit2 »
notes5
-Given: 173
-Receive: 971
« Reply #1 on: December 14, 2008, 05:44:15 17:44 » |
Very good...nice PCB print!
Congratulations.
Bye, notes5.
Notes5 isn't the original uploader, only a seeker...like a spider.
Wannabe
-Given: 228
-Receive: 285
« Reply #2 on: December 14, 2008, 06:04:44 18:04 » |
Great prints! Which PCB layout software do you use?
pasanlaksiri
-Given: 144
-Receive: 59
« Reply #3 on: December 14, 2008, 06:08:54 18:08 » |
Sprint-Layout 5
cyber_drifter
-Given: 167
-Receive: 32
« Reply #4 on: December 14, 2008, 06:55:34 18:55 » |
That's excellent work pasanlaksiri. How did you achieve the component layout artwork, using silkscreen?
niktesla
-Given: 166
-Receive: 280
« Reply #5 on: December 14, 2008, 07:19:02 19:19 » |
Boy what is the magic? Tell us! niktesla
Ensinar é aprender, compartilhar é se tornar mais forte!!!<br />Teaching is learning, sharing is becoming stronger!<br />NikTesla
MAXPAYNE
-Given: 493
-Receive: 362
It's a little funny......
« Reply #6 on: December 15, 2008, 03:31:56 03:31 » |
nice job u have done!!!! How did u make the silkscreen work they r really impressive..........!!!!!!!!!
Whats the Craziest Project u have done lately...?
lillbear
-Given: 223
-Receive: 182
« Reply #7 on: December 15, 2008, 06:45:11 06:45 » |
well i dunno how pasanlaksiri does it. But one way is that u print silk screen/component layout on self adhesive label and voila. or other way is use hot iron technique (read toner transfer) also works but not so neat and clean but it's safe for the circuit. Moist (air) -> paper label or plastique is not nice combination with electronics.
it have been almost 10 yrs. when i first time try it.
yours
« Last Edit: December 15, 2008, 06:49:29 06:49 by lillbear »
microkid
-Given: 45
-Receive: 23
« Reply #8 on: December 15, 2008, 01:22:32 13:22 » |
Silk screen is very nice and impressive
Can you tell us how did you did it?
MicroKid
Never Never Never giveup
usrrsr
-Given: 11
« Reply #9 on: December 15, 2008, 03:14:56 15:14 » |
What do u guys think? OK pasanlaksiri, now you know that you did a nice home pcb works and also in what others are interested now. so will you please now...us... ?
« Last Edit: December 15, 2008, 04:59:31 16:59 by SONSiVRi »
Malcolm
-Given: 632
-Receive: 295
« Reply #10 on: December 15, 2008, 03:37:20 15:37 » |
Marvellous! Please describe your HOW-TOs?
Regards.
pasanlaksiri
-Given: 144
-Receive: 59
« Reply #11 on: December 15, 2008, 03:46:47 15:46 » |
Regards.
Hi Thanks. Im using Screen Printing
wyatt
-Given: 36
« Reply #12 on: December 15, 2008, 04:04:34 16:04 » |
>Hi Thanks. >Im using Screen Printing Very nice work!! Can you please be a little more specific about your Screen Printing technique?? //
newboy
-Given: 42
-Receive: 20
« Reply #13 on: December 15, 2008, 04:35:32 16:35 » |
how about solder mask ( the white writing) for the component'name ? How you do that ? Can you share the technic in details ... so that I can make it on my work . Thanks
pasanlaksiri
-Given: 144
-Receive: 59
« Reply #14 on: December 15, 2008, 05:36:54 17:36 » |
>Hi Thanks. >Im using Screen Printing Very nice work!! Can you please be a little more specific about your Screen Printing technique?? // This is how exactly i do ithttp://www.youtube.com/watch?v=Ee_8IMx0uMo
Biggles
-Given: 15
-Receive: 23
« Reply #15 on: December 15, 2008, 09:47:14 21:47 » |
Very nice work!
Man who act in haste, repent at leisure.
usrrsr
-Given: 11
« Reply #16 on: December 31, 2008, 03:33:21 15:33 » |
Hi Will you please tell us which ink you used? And have you added any thinner in ink before actual printing on copper clad?
Is it film type or film less screen?
thnks
pasanlaksiri
-Given: 144
-Receive: 59
« Reply #17 on: December 31, 2008, 04:05:06 16:05 » |
thnks
Will you please tell us which ink you used? Hmm no links actually. I learn it from some local dude But did u see this video http://www.youtube.com/watch?v=Ee_8IMx0uMoAnd have you added any thinner in ink before actual printing on copper clad? Nope no thinners. There is special inks for screen printing. And im using this UV sensitive chemical to make screens ( Autotype PLUS 1 SR ) http://www.macdermidautotype.com/autotype.nsf/webfamiliesEurope/PLUS%20Direct%20Emulsions
glitch_inc
-Receive: 8
« Reply #18 on: January 07, 2009, 01:45:18 01:45 » |
So let me see if I get this right...
Your using the technique in the video to create the screen itself of your PCB and Silk The question I think most of us have is what kind of ink are you using to do the resist on the copper side? What technique are you using to do actual etching?
My questions to you would be
1) Are you silk screening both sides and then etching? 2) Once your done with a screen can you remove the burnt emulsion and make a new screen on it? 3) For someone new who wanted to do screening what kind of cost are you looking at for the screen, emulsion, tools (Squeegee and Emulsion spreader) and ink? (Am I missing any supplies?
icecubetray
« Reply #19 on: January 07, 2009, 02:04:12 02:04 » |
I'm impressed with the quality of your copper etching. Looks top notch to me.
I've never been able to produce quality like that at home. What kind of trace widths do you think you can get and what kind of spacing between pads?
Nice work!
Cheers
usrrsr
-Given: 11
« Reply #20 on: January 07, 2009, 02:43:30 14:43 » |
i did the screen printing earlier with cheaper PVC glossy ink (Rs. 45 per 200 gms) without thinner. this scheme also worked fine if you have all fixtures like table etc.
After seeing your post i enquired about special ink available for pcb works, cost are as follows and also i am mentioning cost for all other tems required for geting started in screen printing ( Cost in Indian Currency)
1. PCB ink for making tracks etc - Rs. 375 / Kg 2. Thinner for above ink (Thiner is always required) - Rs 260 / litre 3. Silk creen print ink - Rs. 610 / Kg 4. Thinner for above is same as a mentioned in sr 2 5. 12 inch x 14 inch screen cost - Rs. 150 (Screen can be reused) 6. Screen coating sollutin - Rs. 90 / litre 7. Film - Rs. 45 / meter (210 mm wide) 8. Decoating sollution - Rs. 5 (powder to be mixed with 1 litre water) 9. Squeezee - Approx Rs 20 per ince length 10. PVC glossy ink only - Rs. 45 per 200 gms 11. 500 Watts halgen bulb - Rs. 20 12. Frame holder for hlding halogen lamp - Rs. 70 13. glass and table - Approx Rs. 200 14. Good quality water sprinkler (ne we can see in hair cutting shop) - Rs. 45
reards
pasanlaksiri
-Given: 144
-Receive: 59
« Reply #21 on: January 07, 2009, 03:51:44 15:51 » |
reards
Dont use PVC inks. It will dry quickly but its paint layer is very thin, easily it can be peel off.
usrrsr
-Given: 11
« Reply #22 on: January 08, 2009, 04:13:49 16:13 » |
ya but if u do it little bit trick or get it done from proffessional then it works fine
abcsantosh
-Given: 33
« Reply #23 on: January 13, 2009, 11:29:30 11:29 » |
Very nice expose. You have mastered the screen printing. Especially that small clearance area PCB.
pasanlaksiri
-Given: 144
-Receive: 59
« Reply #24 on: January 13, 2009, 02:43:02 14:43 » |
Thanks for the comment. He he heeee but u know im just a newbie for making PCBs using screen printing
chandra2sekhar2000
-Given: 24
« Reply #25 on: January 15, 2009, 05:27:13 17:27 » |
HELLO usrrsr, R u from india.if yes where can i get the PCB inks and SilkScreen ink. And one more thing . What about the Solder mask layer.What ink has to be used for Solder masking? And Can u tell me the process of Tinning ? Do u have idea of making Double side Pcbs?if yes where can i get via's for this boards? THANK u.
usrrsr
-Given: 11
« Reply #26 on: January 16, 2009, 05:02:40 17:02 » |
Yes u r right. I am from India and in that from Mumbai Inks are as follows 1. Ink used for tracking and etching (PCB inks ) Code - CS1882 / CS1881 Type - "Alkali solluble Acid resist" Blue color (Any color can do) Reudcing agent code :- CS2207 2. Ink used for silk screen (SilkScreen ink) Code - CS1861 Type - "Alkali solluble Acid resist" (Any color can do) Reducing agent code :- 1860 3. Ink used for Masking or Solder mask layer Code - CS1476 Type - "Alkali solluble Acid resist" Blue colr Reducing agent code :- CS2207 Available at M/s Vrajesh & Bro Dumping road Mulund Mumbai Ph. - 022 - 56065742 - 25147886 For all ink Make is "COATS LTD." Tinning process is some wat complicated and needs proper investment and is not possible to manufacture it at home. My suggestion is to purchase it directly. Double sided PCBs using screen printing is highly imposible and not recommended. Just today i did my screen printing of pcbs and i got 100% OK result with PVC glossy black ink so before purchasin abve mentioned costly ink, do practice with pvc ink.
« Last Edit: January 16, 2009, 05:18:50 17:18 by usrrsr »
newboy
-Given: 42
-Receive: 20
« Reply #27 on: January 17, 2009, 03:32:45 15:32 » |
usrrsr,
Just to ask your opinion ...
Is it worth to make silkscreen for prototype or customize pcb ? I mean is it worth of time to make a PCB using silkscreen method instead of toner transfer or UV exposure or you use it (silksreen) for mass production at home.
How many time you use the silkscreen (with diffrent PCB artwork) before it cannot use anymore. How long it's take to produce one PCB ... start from making silkscreen upto the PCB is ready for drilling and soldering ?
usrrsr
-Given: 11
« Reply #28 on: January 17, 2009, 06:51:32 18:51 » |
usrrsr,
Screen print is a part of making pcbs and not the whole method. hence you can't directly compare screen print with other method of transferring artwork on copper clad. Normally to prepre a screen exposing and dring takes arround 2 hour. but here a normal print on tracing paper will do the work you don't need positive like what is need for photoresist pcbs. You can imagine if i need 100 pcbs then i must have 100 pcb prints for toner transfer method (assuming no fault while transferring) In screen printing you just need to change copperclad to satisfy qty needs and hence not only for Mass production but also for prototype you can use it. because if you order it outside then because of minimum order quantity you won't get it at cheaper rate. Consumable parts for screen printing are much more cheaper than any other methode. i have used it 6-7 times. "How long it's take to produce one PCB ... start from making silkscreen upto the PCB is ready for drilling and soldering ?" -> Best answer to this would be "depends on when you start and when you finish" mathematically Time to complete pcb = Finish time - Start time this is because this totally depends upon size and nature of pcb
pasanlaksiri
-Given: 144
-Receive: 59
« Reply #29 on: January 18, 2009, 03:24:51 03:24 » |
usrrsr,
Screen printing is not worth if you are need just one or two PCBs. U better stick with photoresist pcbs.
