May 15, 2025, 08:06:54 08:06
Pages: 1 [2] 3 4  All
Author Topic: warp13a  (Read 27432 times)
sarco
« Reply #25 on: November 15, 2005, 11:55:16 11:55 »
hi
the version i have posted is the latest due to this link  http://www.newfoundelectronics.com/downloads.htm
but if you want you can use the 16f876a with another firmware i will post it here next time
sarco
sarco
« Reply #26 on: November 15, 2005, 07:03:09 19:03 »
hi
this is the 16f876a firmware for warp13a comptable with my post tittled  the correct brd for warp13a
sarco
« Last Edit: November 15, 2005, 07:17:34 19:17 by sarco » Logged
-Given: 562
-Receive: 409
« Reply #27 on: November 19, 2005, 11:43:52 11:43 »
theres new warp13 exe file warp13.exer(o) can some one upload pleease
wizpic
pvinbox@yahoo.com
« Reply #28 on: December 14, 2005, 03:40:19 03:40 »
hai
i am from coimbatore, tamilnadu
i got pdf for this pcb
if u want pls send me a pm
by
pvinbox@yahoo.com
« Reply #29 on: December 14, 2005, 03:41:53 03:41 »
hai beserk
or u do onething u just send your address to me
i will send you the pcb
picstart
« Reply #30 on: December 24, 2005, 02:16:54 14:16 »
i am trying to build this programmer. Can someone tell me what are the components indicated by the arrows in the figure?
Can the resonator be replaced with a crystal?
-Given: 562
-Receive: 409
« Reply #31 on: December 24, 2005, 03:35:23 15:35 »
One at the to is a push to make button (restets the programmer)
the one at the bottom is the round black thing) is a 1.5amp bridge rectifier
hope this helps
wizpic
Faros
-Given: 141
-Receive: 178
« Reply #32 on: December 24, 2005, 05:42:15 17:42 »
I confirm what Wizpic said.... the reset is indicated on the PCB and the I/P voltage is 12 v AC , so the rectifier is needed …
A lot of info about WARP13A can be found in this page ..
http://www.newfoundelectronics.com/warp-13a.htm
pl4tonas
-Given: 318
-Receive: 195
« Reply #33 on: January 05, 2006, 01:57:02 13:57 »
Hello people, The new version of Warp13.exe (o) is here:
  [url=http://rapidshare.de/files/10442687/w13o.rar][color=#0000ff][url=http://rapidshare.de/files/10442687/w13o.rar]http://rapidshare.de/files/10442687/w13o.rar[/color][/url][/url]
have a nice day.
picstart
« Reply #34 on: January 05, 2006, 02:21:43 14:21 »
Thank you so much pl4tonas.Do you have the lates hex file also ..i.e 1.7 ?
ps: the passwd of above file is pl4tonas
« Last Edit: January 05, 2006, 03:09:53 15:09 by picstart » Logged
pl4tonas
-Given: 318
-Receive: 195
« Reply #35 on: January 05, 2006, 06:06:18 18:06 »
First, my appologies for forgetting the password and my thanks to picstart who posted it.
The password is "pl4tonas"
About the hex file, sorry but I dont have anything newer than 1.6j.  I think there is no 1.7 available yet.
When something comes to my hands I will try to post it.  In case I forget again the password, this sould be tha same as before.
For those that I caused inconvinience, please forgive me.
P.
picstart
« Reply #36 on: January 06, 2006, 07:11:05 19:11 »
Check out http://newfoundelectronics.com/gold%20members.htm
They do have firmware v1.7 for gold members.
picstart
« Reply #37 on: January 09, 2006, 01:00:06 13:00 »
I built this programmer using the pcb/schematic  posted in this thread. But I'm getting lot of program errors after I burn a hex file. Also the red LED isn't glowing- btw when is it supposed to glow?
picstart
« Reply #38 on: January 13, 2006, 03:38:01 15:38 »
When i try to program PIC 18f452 using my self-made warp 13 programmer ( latest firmware and software) I get program word errors on verifying.
Someone please help :confused:
Thank you!
kevin0204
« Reply #39 on: January 13, 2006, 05:59:01 17:59 »
Try this,
http://rapidshare.de/files/10976448/warp13a_pcb-ok.pdf
kevin0204
« Reply #40 on: January 14, 2006, 07:45:12 07:45 »
http://rapidshare.de/files/11009712/lastest.rar
pw is filename
-Given: 562
-Receive: 409
« Reply #41 on: January 14, 2006, 09:26:09 09:26 »
Dam good work Kevein thanks for sharing  Cheesy
we are all grateful to you does this work with the standard software which is o i think
cheers
wizpic
picstart
« Reply #42 on: January 14, 2006, 02:10:58 14:10 »
Thanks kevin for latest hex file.
What about my problem...if anyone has any idea:confused:
Please!!!
I used the same pcb but without the extra ground copper ! does it make any difference.
Btw the input is 16v in some circuits and 12v in others...??!!
tdsnet
« Reply #43 on: January 14, 2006, 03:12:14 15:12 »
hi, picstart
If you use the same pcb , check components.
Some pcb uses 12v AC with bridge rectifier (12*1.414=17v)  other pcb uses 16-18 VDC.
At 7805(pin3) you must have +5V. (for pin20 of f252)
At 7815(Pin3) you must have +15V
-Given: 562
-Receive: 409
« Reply #44 on: January 15, 2006, 10:19:59 10:19 »
Kevin
what it you design your pcb in have you got the gerber files
and the working schematic you made it from theres that many flying around not sure which one is which
can you opload what you have got
cheers
wizpic
kevin0204
« Reply #45 on: January 15, 2006, 03:34:56 15:34 »
Quote from: Wizpic
Kevin
cheers
wizpic
http://rapidshare.de/files/11097547/warp13_A.rar
several eagle schematic and pcb file from internet (here and other site)
but this one is 100% work.
i don't know who designed this file. i am only modify wire size.
selim
« Reply #46 on: January 19, 2006, 03:43:29 15:43 »
HI kevin
Please i try pass: filname or lastest   for the file lastest.rar  but no success
please i want the pass for this file
Thank you in advance
mmengi
« Reply #47 on: January 19, 2006, 07:14:44 19:14 »
hi selim,
Password is "lastest.rar"
stroma
« Reply #48 on: January 20, 2006, 08:13:40 20:13 »
Hi guys,
I’m experimenting with usb powered icsp warp13. schematic is on the links below …
http://icd2.narod.ru/w13usb1.jpg
http://icd2.narod.ru/w13usb2.jpg
What you think about this idea?
Any suggestions and/or error correction are welcome!
best regards,
stroma
nimdonia
« Reply #49 on: May 05, 2006, 06:06:51 18:06 »
hi guys, can soemone repost the lastest.rar... need latest firmware... link to rapidshare says tht it had been deleted... thnx
