Entire Forum
This board
This topic
Members
Entire Site
Home
Contact Us
Help
Search
GoogleTagged
Donations
Login
Register
Welcome,
. Please
login
or
register
Did you miss your
activation email?
April 18, 2026, 01:40:26 13:40
1 Hour
1 Day
1 Week
1 Month
Forever
Electronics
Artificial Intelligence (AI) & Robotics
(Moderator:
5V,2A H bridge help
Pages:
1
2
All
« previous
next »
Author
Topic: 5V,2A H bridge help (Read 27360 times)
tAhm1D
-Given: 103
-Receive: 180
Re: 5V,2A H bridge help
Reply #25 on:
January 21, 2009, 10:16:14 10:16 »
For most of the Mosfets it is normally 8v not 12v. But exceptions are there, please find out some Mosfets known as Logic Level Mosfets which can operate at 5v.
free
-Given: 71
Reply #26 on:
January 22, 2009, 01:23:20 01:23 »
hi tAhm1D,
I built the circuit from you, but it's not working fine on me.
When I use 24v supply no output voltage, but it's working if the supply about 14 - 16v, stranger..
I replace the mosfet with lower ampere, same result.
I want to build it again.
- Soichiro Honda -
tAhm1D
-Given: 103
-Receive: 180
Reply #27 on:
January 22, 2009, 10:20:04 10:20 »
The circuit is supposed to be Ok. Probably you could not select appropriate parts.
Try the same circuit without R9, R10, R11, Q5, Q6 and observe the output. Then, if the circuit is alright, put these parts again and select the proper sense resistor R9. Change its value to observe the output.
caveman508
-Given: 12
READ, REAd, REad, Read
Reply #28 on:
January 22, 2009, 02:47:59 14:47 »
R9 MUST remain in circuit for it to work.
To disable the current limit function, simply disconnect the collector of Q5 & Q6.
Caveman
ajmain
Reply #29 on:
January 22, 2009, 03:55:48 15:55 »
You can connect the sources of the low side MOSFETs directly to ground to disable current limit.
tAhm1D
-Given: 103
-Receive: 180
Reply #30 on:
January 22, 2009, 04:26:35 16:26 »
Hi caveman508,
ajmain got the idea clearly. R9 is not required and the sources of the low side Mosfets can be connected directly to ground to disable current limit.
Pages:
1
2
All
« previous
next »
Please select a destination:
Electronics
=> Projects
=> Pic Basic Languages
=> Pic C Languages
=> AVR, 8051 Family and ARM Area
=> RTOS
=> Artificial Intelligence (AI) & Robotics
=> Hardware and Tools
=> General Electronics
Computers
=> Internet Scripting Languages
=> Graphics and CAD
Announcements and Rules
=> Help & Rules
===> English
===> Arabic
===> French
===> Italian
===> Persian
===> Portuguese (Brazilian)
===> Spanish
===> Swedish
===> Turkish
=> Announcements
Others
=> General
=> Entertainment
=> Suggest Forum Content
=> Holiday and Greetings
=> Testing Forum
=> Invitation Request
Loading...
