November 06, 2025, 03:55:56 15:55
Pages: 1 [2]  All
Author Topic: REQ:Using DVD Writter's laser diode for making PCB....  (Read 38910 times)
HX1
« Reply #25 on: September 11, 2008, 03:37:29 15:37 »
You have luck, because here in the Brazil the price of a CNC machine is more high than that $700, unfortunately.
Keyboard not found. Press F1 to continue.
Opast
-Given: 31
-Receive: 19
« Reply #26 on: September 11, 2008, 03:44:49 15:44 »
Do a Google search for Diy CNC machine.  You'll find a lot of info and you can make your own for a few hundred $$$.
titi
-Given: 4003
-Receive: 834
« Reply #27 on: May 10, 2009, 09:47:19 09:47 »
Here a original method to Etching PCB with Laser
This is a video running at 4X speed, illustrating the etching process I'm using. The paint is removed from the copper-clad PCB in an Epilog laser cutter. After a wipedown with alcohol to remove any paint dust, the PCB is etched in ferric chloride solution.
http://www.flickr.com/photos/macetech/2735223162/
http://www.electronics-lab.com/blog/?p=2367
Best Regards.
« Last Edit: May 10, 2009, 09:51:54 09:51 by titi » Logged
Pages: 1 [2]  All
