April 29, 2026, 07:29:37 07:29
Author Topic: Need some help!  (Read 4576 times)
ncsportsman
« on: August 25, 2008, 07:07:44 07:07 »
i have a kit to modify a xbox 360 controller for rapid fire capability, can i just read and save a image in picbasic and rewrite it to another chip and it work?
cluoiset
« Reply #1 on: August 25, 2008, 10:44:36 10:44 »
I think if you can read it out and check the correct fuse bits, then you can program it back. Just watch the fuses.
Cluoiset
TomJackson69
-Receive: 63
« Reply #2 on: August 26, 2008, 07:51:08 19:51 »
You will need alot more informations than you have to be able reproduce the firmware. You need to know what the uC part number and than you need a programmer to read the code. I don't have a X-Box so I don't know what the chip is.
The code is in binary form so it does not matter what compiler you use to import the file. If you have a programmer cappable of read the code out of the chip than you can program that code to a same uC. I am very sure the code is protected so don't be supprise if you read out all ZEROs.
Tom
Con Rong Chau Tien
