April 29, 2026, 03:56:43 03:56
Author Topic: Request: Laptop battery charger  (Read 4912 times)
nileshhande
-Given: 23
« on: July 27, 2008, 10:03:40 10:03 »
Hi all. Looking for laptop battery charger for RC-project(long backup)
Thanks&Regards.
Walkura
-Given: 56
-Receive: 82
« Reply #1 on: July 27, 2008, 08:48:02 20:48 »
In the elektor of january 2006 they published a laptop charger .
Unfortunatly the file i have of that turns out to be corrupted .
I hope this will get you a bit closer .
Have a nice eve Walkura
-Receive: 4460
« Reply #2 on: July 27, 2008, 09:14:28 21:14 »
for information only The power supply you get with a laptop is only a power supply. @19V common type.
the battery charging and monitoring is controlled via the laptop.
micropar
-Given: 44
« Reply #3 on: July 28, 2008, 01:39:08 01:39 »
Hi all,
Visit any SMPS chips mfg such as Power Integration, ST micro, NXP, On-Semi , Fairchild and you find lot of Laptop charger circuits with SMPS.
--micropar--
nileshhande
-Given: 23
« Reply #4 on: July 28, 2008, 08:15:07 08:15 »
Hi, Exactly thats what i looking for.. how to monitor and charge through a 19volt adapter.Also I'm searching for elektor of january 2006(Walkur's reply).is this a individual charger?
Thanks and Regards.
Walkura
-Given: 56
-Receive: 82
« Reply #5 on: July 28, 2008, 09:56:48 09:56 »
The elektor schematic concerns a 19 Volt powersupply (switchmode)
When it comes to charging and monitoring the charge process i need some more information .
A : how much cells
B : what chemistry of cells .
C : size of the cell's in Ah .
nileshhande
-Given: 23
« Reply #6 on: July 28, 2008, 12:19:29 12:19 »
@Walkura
A : how much cells
Hi, A:Planning to use 2-3 battery's. B: LI-iON. C: 14.4V, 4400mAh. Thanks
Walkura
-Given: 56
-Receive: 82
« Reply #7 on: July 28, 2008, 08:21:36 20:21 »
Good evening nileshhande.
I think you would come to something like this then .
http://focus.ti.com.cn/cn/lit/an/slua097/slua097.pdf
There are dozens of chips to build smps's and lithium ion chargers .
But let me add a few points .
Building a switchmode powersupply is in itself very well possible when you have the acces to an ossciloscope etc.
The power doesnt have to be high for this half a Ampere would do so topswitch ,Fairchild fps anything will do .
(although i would prefer to build forward instead if flyback cause it saves the trouble of gapped cores)
About the charging part there it really doesnt matter which chipset you choose .
For me the criterium would be if its dil sockets .
It can be the TI from the datasheet or some other chip like it.
http://focus.ti.com/lit/ds/symlink/bq2954.pdf
I know Microchip has them too like the 16HV785.
Good luck Smiley
( and be carefull with mains power  Grin )
sava
-Given: 1489
-Receive: 56
« Reply #8 on: July 28, 2008, 09:39:24 21:39 »
http://rapidshare.com/files/133159584/Elektor_01__2006.pdf.html
